Home » Eclipse Projects » Eclipse Platform » Cannot connect to vm
Cannot connect to vm [message #64017] Thu, 05 June 2003 12:13 Go to next message
Originally posted by: rene.grohmann.web.de
i have a big problem with debugging in eclipse.
If i start my main method in the normal running mode, everthing works fine.
But if i try to start the same method in debug mode eclipse shows me the
following error:
"Cannot connect to VM"
In the console:
err:: No such file or directory
FATAL ERROR in native method: No transports initialized
Error [2] in connect() call!
Socket transport failed to init.
Transport dt_socket failed to initialize, rc = -1.
Increasing the debug timeout has no effect.
Re: Cannot connect to vm [message #65710 is a reply to message #64017] Fri, 06 June 2003 11:48 Go to previous messageGo to next message
Originally posted by: jed_anderson.us.ibm.com
Rene,
Are you running a firewall on your machine? It could be blocking the port.
jkca
Rene G. wrote:
> Hello,
> following error:
> In the console:
> Í use version:
> Version: 2.1.0
> Build id: 200303272130
> And
> j2sdk1.4.1_03
> Does anybod has an idea how to solve this problem?
> thanks & regards Rene G.
Re: Cannot connect to vm [message #77355 is a reply to message #65710] Wed, 18 June 2003 02:38 Go to previous message
Oh shit,
you are right. Thanks for the hint.
Bye Ren
Previous Topic:Makefiles and migrating to Eclipse
Next Topic:Plugins and org/w3c/dom/ls/DOMBuilder
Current Time: Sun Aug 31 23:07:15 EDT 2025
Powered by FUDForum. Page generated in 0.03535 seconds
