Home » Archived » Visual Editor (VE) » SWT Application Does Not Display Correctly Until Resized.
SWT Application Does Not Display Correctly Until Resized. [message #63995] |
Sun, 03 October 2004 07:35  |
Originally posted by: eraserman.nospam.gmail.com
I just started experimenting with Visual Editor. I created
a simple application using SWT. This application looks correct
when editing it with the visual editor, however, when I run it,
It does not look right, there is a multiple-line text field, it is
the only widget to show when the application is first run. After
resizing the app, all widgets display correctly. Any ideas on how
to fix this?
The code in question follows, it was generated by Visual
Editor 100% (no hand coding). I am writing and testing
using Linux/GTK. I haven't had a chance to test this under
any other platforms.
* Created on Oct 3, 2004
* TODO To change the template for this generated file go to
* Window - Preferences - Java - Code Style - Code Templates
package net.heffelfinger.vetest;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Text;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Button;
* @author ray
* TODO To change the template for this generated type comment go to Window -
* Preferences - Java - Code Style - Code Templates
public class VisualEditorTest
private org.eclipse.swt.widgets.Shell sShell = null; // @jve:decl-index=0:visual-constraint="0,10"
private Label label = null;
private Text text = null;
private Label label1 = null;
private Text text1 = null;
private Label label2 = null;
private Composite composite = null;
private Button radioButton = null;
private Button radioButton1 = null;
private Button radioButton2 = null;
private Label label3 = null;
private Composite composite1 = null;
private Button checkBox = null;
private Button checkBox1 = null;
private Button checkBox2 = null;
private Button checkBox3 = null;
private Button checkBox4 = null;
private Button checkBox5 = null;
private Button checkBox6 = null;
private Button checkBox7 = null;
* This method initializes composite
private void createComposite() {
GridData gridData11 = new GridData();
GridData gridData10 = new GridData();
GridData gridData9 = new GridData();
GridData gridData8 = new GridData();
GridLayout gridLayout7 = new GridLayout();
composite = new Composite(sShell, SWT.NONE);
radioButton = new Button(composite, SWT.RADIO);
radioButton1 = new Button(composite, SWT.RADIO);
radioButton2 = new Button(composite, SWT.RADIO);
composite.setLayout(gridLayout7);
composite.setLayoutData(gridData8);
gridData8.heightHint = 25;
gridData8.widthHint = 400;
gridData8.grabExcessHorizontalSpace = true;
radioButton.setText("Pan");
radioButton.setLayoutData(gridData9);
gridData9.widthHint = 50;
gridLayout7.numColumns = 3;
gridLayout7.makeColumnsEqualWidth = false;
radioButton1.setText("Hand Tossed");
radioButton1.setLayoutData(gridData10);
gridData10.widthHint = 110;
radioButton2.setText("Thin and Crispy");
radioButton2.setLayoutData(gridData11);
gridData11.widthHint = 130;
* This method initializes composite1
private void createComposite1() {
GridData gridData22 = new GridData();
GridData gridData21 = new GridData();
GridData gridData20 = new GridData();
GridData gridData19 = new GridData();
GridData gridData18 = new GridData();
GridData gridData17 = new GridData();
GridData gridData16 = new GridData();
GridData gridData15 = new GridData();
GridData gridData14 = new GridData();
GridLayout gridLayout13 = new GridLayout();
composite1 = new Composite(sShell, SWT.NONE);
checkBox = new Button(composite1, SWT.CHECK);
checkBox1 = new Button(composite1, SWT.CHECK);
checkBox2 = new Button(composite1, SWT.CHECK);
checkBox3 = new Button(composite1, SWT.CHECK);
checkBox4 = new Button(composite1, SWT.CHECK);
checkBox5 = new Button(composite1, SWT.CHECK);
checkBox6 = new Button(composite1, SWT.CHECK);
checkBox7 = new Button(composite1, SWT.CHECK);
composite1.setLayout(gridLayout13);
composite1.setLayoutData(gridData14);
gridLayout13.numColumns = 4;
gridLayout13.makeColumnsEqualWidth = false;
gridData14.heightHint = 50;
gridData14.grabExcessHorizontalSpace = false;
gridData14.horizontalAlignment = org.eclipse.swt.layout.GridData.FILL;
gridData14.verticalAlignment = org.eclipse.swt.layout.GridData.CENTER;
checkBox.setText("Sausage");
checkBox.setLayoutData(gridData15);
gridData15.widthHint = 80;
checkBox1.setText("Pepperoni");
checkBox1.setLayoutData(gridData16);
gridData16.widthHint = 90;
checkBox2.setText("Mushrooms");
checkBox2.setLayoutData(gridData17);
gridData17.widthHint = 110;
checkBox3.setText("Green Peppers");
checkBox3.setLayoutData(gridData18);
gridData18.widthHint = 120;
checkBox4.setText("Anchovies");
checkBox4.setLayoutData(gridData19);
gridData19.widthHint = 90;
checkBox5.setText("Onions");
checkBox5.setLayoutData(gridData20);
gridData20.widthHint = 90;
checkBox6.setText("Bacon");
checkBox6.setLayoutData(gridData21);
gridData21.widthHint = 80;
checkBox7.setText("Extra Cheese");
checkBox7.setLayoutData(gridData22);
gridData22.widthHint = 110;
public static void main(String[] args)
* Before this is run, be sure to set up the following in the launch
* configuration (Arguments->VM Arguments) for the correct SWT library path.
* The following is a windows example:
* -Djava.library.path=" installation_directory\plugins\org.eclipse.swt.win32_3.0.0\o s\win32\x86 "
org.eclipse.swt.widgets.Display display = org.eclipse.swt.widgets.Display
.getDefault();
VisualEditorTest thisClass = new VisualEditorTest();
thisClass.createSShell();
thisClass.sShell.open();
while (!thisClass.sShell.isDisposed())
if (!display.readAndDispatch())
display.sleep();
display.dispose();
* This method initializes sShell
private void createSShell()
sShell = new org.eclipse.swt.widgets.Shell();
GridLayout gridLayout1 = new GridLayout();
GridData gridData2 = new org.eclipse.swt.layout.GridData();
GridData gridData3 = new GridData();
GridData gridData4 = new GridData();
GridData gridData5 = new org.eclipse.swt.layout.GridData();
GridData gridData6 = new org.eclipse.swt.layout.GridData();
GridData gridData12 = new org.eclipse.swt.layout.GridData();
label = new Label(sShell, SWT.NONE);
text = new Text(sShell, SWT.NONE);
label1 = new Label(sShell, SWT.NONE);
text1 = new Text(sShell, SWT.MULTI | SWT.BORDER);
label2 = new Label(sShell, SWT.NONE);
createComposite();
label3 = new Label(sShell, SWT.NONE);
createComposite1();
text1.setSize(200, 200);
sShell.setSize(new org.eclipse.swt.graphics.Point(600,400));
sShell.setText("Created With Visual Editor");
sShell.setLayout(gridLayout1);
label.setText("Name:");
label.setLayoutData(gridData3);
label.setFont(new org.eclipse.swt.graphics.Font(
org.eclipse.swt.widgets.Display.getDefault(), "Sans", 10,
org.eclipse.swt.SWT.BOLD));
gridLayout1.numColumns = 2;
gridLayout1.makeColumnsEqualWidth = false;
gridData2.grabExcessHorizontalSpace = true;
gridData2.horizontalAlignment = org.eclipse.swt.layout.GridData.FILL;
gridData2.verticalAlignment = org.eclipse.swt.layout.GridData.CENTER;
text.setLayoutData(gridData2);
text.setFont(new org.eclipse.swt.graphics.Font(org.eclipse.swt.widgets.Displa y.getDefault(), "Sans", 10, org.eclipse.swt.SWT.BOLD));
label1.setText("Address:");
label1.setLayoutData(gridData4);
label1.setFont(new org.eclipse.swt.graphics.Font(
gridData3.horizontalAlignment = org.eclipse.swt.layout.GridData.END;
gridData4.horizontalAlignment = org.eclipse.swt.layout.GridData.END;
gridData4.verticalAlignment = org.eclipse.swt.layout.GridData.BEGINNING;
gridData5.horizontalAlignment = org.eclipse.swt.layout.GridData.BEGINNING;
gridData5.verticalAlignment = org.eclipse.swt.layout.GridData.CENTER;
gridData5.verticalSpan = 1;
gridData5.grabExcessVerticalSpace = false;
gridData5.heightHint = 50;
gridData5.grabExcessHorizontalSpace = false;
gridData5.widthHint = 200;
text1.setLayoutData(gridData5);
label2.setText("Crust:");
label2.setLayoutData(gridData6);
label2.setFont(new org.eclipse.swt.graphics.Font(org.eclipse.swt.widgets.Displa y.getDefault(), "Sans", 10, org.eclipse.swt.SWT.BOLD));
gridData6.horizontalAlignment = org.eclipse.swt.layout.GridData.END;
gridData6.verticalAlignment = org.eclipse.swt.layout.GridData.CENTER;
label3.setText("Toppings:");
label3.setLayoutData(gridData12);
label3.setFont(new org.eclipse.swt.graphics.Font(org.eclipse.swt.widgets.Displa y.getDefault(), "Sans", 10, org.eclipse.swt.SWT.BOLD));
gridData12.horizontalAlignment = org.eclipse.swt.layout.GridData.END;
gridData12.verticalAlignment = org.eclipse.swt.layout.GridData.BEGINNING;
Thanks for any help,
Ray.
Re: SWT Application Does Not Display Correctly Until Resized. [message #65114 is a reply to message #64475] |
Tue, 05 October 2004 13:23   |
On Mon, 04 Oct 2004 16:01:25 -0400, Rich Kulp wrote:
> That's the released version.
> That shouldn't of happened. What exact steps, from creating the class
> on, did you do?
I can't remember the exact steps, but it was somewhat like this:
I clicked on the class icon in the toolbar (green circle with a "C+"
inside), clicked on "Visual Class", filled in the source folder,
package and class name, left the default SWT application style and
clicked on "finish".
If I remember correctly, I then changed the layout to GridLayout (BTW,
I might have set the size of the text component myself, through the
properties view, I was experimenting with the different options).
I then set the number of columns for the layout to be two, and
started adding components from the palette. A label, a text field,
another label, a multi-line text field, another label, a composite,
changed the layout for the composite to be GridLayout, set the number of
columns for the composite's layout to be 3, then added some radio buttons
to that composite, another label, another composite, again set the layout
for the new composite to be GridLayout, and set the number of columns to
be 4, added the check buttons to the second composite.
I don't think I did anything out of the ordinary.
In any case, I've been trying the Visual Editor in my spare time,
I'm not working on any super important documents or anything. In my day
job, I'm stuck with an HTML user interface for a J2EE application.
Ray
Re: SWT Application Does Not Display Correctly Until Resized. [message #600603 is a reply to message #64021] |
Mon, 04 October 2004 11:15  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Just for laughs, move
to the very last line in createSShell().
I'm thinking that we are missing a layout do to the size was changed
before we set griddata on anything.
Ray Davis wrote:
> Replying to myself here, but I just had a chance to test the
> code under Windows 2000, and it works fine there. It seems to be
> a Linux/GTK issue.
> Ray.
Rich Kulp
Re: SWT Application Does Not Display Correctly Until Resized. [message #600641 is a reply to message #64231] |
Mon, 04 October 2004 11:48  |
What build of VE do you have?
Do Help->About Eclipse->Feature Details button. Select org.eclipse.ve,
then at the bottom of the dialog it will say "build id: ..." What build
id is listed?
The reason I ask is in the past we had problems with placing the
setSize, but we just tested it and seems to work correctly.
Also, there was a
in createSShell which shouldn't of been there. When you switched to Grid
layout, we should of removed it.
Rich Kulp
Re: SWT Application Does Not Display Correctly Until Resized. [message #600687 is a reply to message #64322] |
Mon, 04 October 2004 09:56  |
> id is listed?
> Also, there was a
Rich,
Here is the Visual Editor information displayed in the
feature details dialog:
Visual Editor
Version: 1.0.1
Build id: 200409191449
Ray
Re: SWT Application Does Not Display Correctly Until Resized. [message #600704 is a reply to message #64231] |
Mon, 04 October 2004 10:04  |
>> a Linux/GTK issue.
>> Ray.
Rich,
Moving sShell.setSize(new org.eclipse.swt.graphics.Point(600,400));
to be the very last line in createSShell() took care of the problem.
I'm not sure why the problem is there in the first place but this is
a fairly easy workaround.
Ray
Re: SWT Application Does Not Display Correctly Until Resized. [message #600910 is a reply to message #64475] |
> on, did you do?
Ray
Re: SWT Application Does Not Display Correctly Until Resized. [message #600985 is a reply to message #65241] |
Thu, 07 October 2004 07:22  |
Rich Kulp wrote:
> Thanks we now see what's going on. I've opened two defects to fix this,
> but the workaround for now is to move the setSize to the end. From that
> point on everything should work fine.
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=75725
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=75726
I saw the bug reports, and I have a question, the bug reports say that
setText() and setSize() must be reversed. According to the workaround,
setSize() must be last in the createSShell() method. Looking at my
code, some components are added right after setText(), it looks like if
setText() and setSize() are reversed, then those components would be
added right after setSize().
This might not fix the problem since the components would still be
added after setSize(). I think Visual Editor
needs to add the setSize() as the last line in createSShell() regardless
of when the user sets the size of the shell.
Let me know if my assumption is correct.
Ray
Re: SWT Application Does Not Display Correctly Until Resized. [message #600990 is a reply to message #65349] |
Thu, 07 October 2004 09:14  |
The "workaround" is to place the setSize() at the end of the createMethod() (last statement).
Top down, VE will keep the setSize() at the end of the method even if you drop new components.
The question become a bit more tricky with this defect; what to do when the code's statement order is wrong.
Assume the following bad order (A should come before C):
C
A
Where do you inser B? before C or after A....
Re: SWT Application Does Not Display Correctly Until Resized. [message #601031 is a reply to message #65472] |
Thu, 07 October 2004 13:46  |
That bug had only to do with our template for creating the class. We
needed to change it so it created the class correctly. The code was
already correct when up in the ve for handling setSize() if setSize()
was last. The other bug listed was for handling when setSize() was not
in the correct place.
Rich Kulp
Re: SWT Application Does Not Display Correctly Until Resized. [message #601086 is a reply to message #65510] |
Fri, 08 October 2004 15:58  |
Hey guys,
I seem to remember that Win32 sends a bogus resize event on Shell.show().
That event causes the layout and explains the different behavior on
non-windows platforms.
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:ck3v3e$kgd$1@eclipse.org...
> Rich Kulp
Re: SWT Application Does Not Display Correctly Until Resized. [message #601201 is a reply to message #65742] |
Mon, 11 October 2004 11:41  |
Randy Hudson wrote:
> Hey guys,
Thanks Randy. In your opinion, should we file a PR against Platform/SWT
with the suggestion that SWT do the same thing across platforms here or
does this fall into SWT's "don't count on event ordering" mantra?
Dave
Dave Orme
Eclipse Visual Editor Project Lead
Advanced Systems Concepts' Chief Architect
http://www.swtworkbench.com http://essentialdata.sf.net
Current Time: Sun Jul 27 01:23:19 EDT 2025
Powered by FUDForum. Page generated in 0.08271 seconds
