Home » Newcomers » Newcomers » Problem with help
Problem with help [message #63918] Fri, 13 May 2005 10:12 Go to next message
Originally posted by: elban.DEL.IT.SPAM.box43.pl
I cannot get any help from the eclipse system. After choosing Help ->
Help Contents I get the "404 http error, The page you are looking for
might have been removed, had its name changed, or is temporarily
unavailable." error.
The installation is copied from the another machine where everything was
fine.
I have checked 127.0.0.1:52365 [the link where eclipse leads after
choosing Help -> Help Contents] link by netstat -a and there is
something that is listening at this port.
I have tried to set up another installation of eclipse, but there was
the same problem.
my system is Windows XP SP 2.
Any tips?
M.
Re: Problem with help [message #64300 is a reply to message #63918] Sat, 14 May 2005 15:47 Go to previous messageGo to next message
Originally posted by: thomas.dirkse.shaw.ca
I've had a similar problem. In my case the solution could be found in the
readme_eclipse file in the eclipse\readme folder. Go to section 3.1.3,
'Known issues with Help' and it suggest putting 'localhost' for the host
name. After a reboot, my Help screen perform normal.
Hope this works for you as well.
Regards, Thomas.
Re: Problem with help [still] [message #64600 is a reply to message #64300] Mon, 16 May 2005 07:53 Go to previous messageGo to next message
> the readme_eclipse file in the eclipse\readme folder. Go to section
> 3.1.3, 'Known issues with Help' and it suggest putting 'localhost' for
> the host name. After a reboot, my Help screen perform normal.
it didnot help, I have change the host name to localhost and port to 80
and turned off all the firewalls, etc.
When it goes to locahost:80 I get "Internal Application Server" text on
white screen for a while and then I get redirected to localhost:80/help
where I get "The document that you have requested is not available. The
link may be wrong, or you may not have the corresponding product feature
installed." message, so nothing changed :(.
Any other tips?
M.
Re: Problem with help [still] [message #65015 is a reply to message #64600] Mon, 16 May 2005 23:02 Go to previous messageGo to next message
Pity that didn't help. Unfortunately, me expertise with eclipse is one
two days old so I can't offer you any further help.
I hope someone else can help you solve it.
Regards, Thomas.
Re: Problem with help [message #92726 is a reply to message #64300] Fri, 05 August 2005 16:24 Go to previous message
Originally posted by: ebridge.humana.com
<br><font size=2 face="sans-serif">Unfortunately, this hasn't helped me.
</font>
<br>
<br><font size=2 face="sans-serif">I have twice started with a fresh download,
once with version 3.02 and then 3.1.</font>
<br><font size=2 face="sans-serif">In all cases the Welcome screen comes
up but the Help Contents always gives the same 404 message that was quoted.</font>
<br>
<br><font size=2 face="sans-serif">There is no firewall on the machine.</font>
<br>
<br><font size=2 face="sans-serif">There is no proxy server.</font>
<br>
<br><font size=2 face="sans-serif">putting localhost or 127.0.0.1 is equally
ineffective.</font>
<br>
<br><font size=2 face="sans-serif">I'm stuck. </font>
<br>
<br><font size=2 face="sans-serif">A colleague at the same company using
the same version of Windows XP has no problem. </font>
<br>
<br><font size=2 face="sans-serif">Is there someone monitoring this newsgroup
who can offer authorotative help here? </font>
<br>
<br><font size=2 face="sans-serif">Ed </font>
Previous Topic:Eclipe 3.1 x86_64 crash on Mandrake 10.2 x86_64
Next Topic:help with "right" mix of plugins - J2EE with Spring
Current Time: Thu Jul 24 18:39:32 EDT 2025
Powered by FUDForum. Page generated in 0.08520 seconds
