Home » Eclipse Projects » GEF » Put a FlowPage within a ScrollPane
Put a FlowPage within a ScrollPane [message #63899] Mon, 10 February 2003 01:03 Go to next message
I am trying to create a FlowPage figure with vertical scroll bar (I don't
need hort scroll bar since the text will be wrapped around automatically in
FlowPage). So I create a Figure based on CircuitFigure in
LogicEditorExample, and I put the flowPage to the pane (the freeformLayer)
and have a ScrollPane sets its view to the pane (same as CircuitFigure).
But I can only see the first word in my FlowPage and there is NO scroll bar.
Could some one please tell me how to get a scroll bar in FlowPage?
Thank you.
pane = new FreeformLayer();
pane.setLayoutManager(new FreeformLayout());
setLayoutManager(new StackLayout());
ScrollPane scrollpane = new ScrollPane();
add(scrollpane);
scrollpane.setViewport(new FreeformViewport());
// createFlowPage is based on the FlowPage example in draw2d cvs.
IFigure flowPage = createFlowPage();
scrollpane.setView(pane);
pane.add(flowPage);
Re: Put a FlowPage within a ScrollPane [message #63922 is a reply to message #63899] Mon, 10 February 2003 10:56 Go to previous messageGo to next message
You should put the FlowPage directly in the Viewport, without a Freeform
anything.
Then, Viewport.setContentsMatchWidth(true);
"Hal" <otaconss2@hotmail.com> wrote in message
news:b28fkb$71n$1@rogue.oti.com...
in
bar.
> Thank you.
> add(scrollpane);
> pane.add(flowPage);
Re: Put a FlowPage within a ScrollPane [message #63967 is a reply to message #63922] Mon, 10 February 2003 11:41 Go to previous messageGo to next message
Thanks, but it gives me a Hort Scroll bar, instead of a Vertical Scroll bar.
I try calling Viewport.setContentsMatchHeight(true) also, but it gives me
Both Hort and Vert scroll bar.
Basically what I want is text wrap around the width of the figure and gives
me a vertical scroll bar is the FlowPage is higher than the figure
Here is what I changed:
pane = createPane();
add(scrollpane);
Viewport viewport= new Viewport();
viewport.setContentsTracksHeight(true);
scrollpane.setViewport(viewport);
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b28glf$7t4$1@rogue.oti.com...
> anything.
> > Hi,
don't
> in
freeformLayer)
> bar.
> > Thank you.
> > add(scrollpane);
> > pane.add(flowPage);
Re: Put a FlowPage within a ScrollPane [message #64012 is a reply to message #63967] Mon, 10 February 2003 13:44 Go to previous messageGo to next message
news:b28jas$aes$1@rogue.oti.com...
bar.
gives
> add(scrollpane);
should be setContentsTracksWidth(true).
Where is the FlowPage? It needs to be set as the contents to the Viewport.
Download TextExample from the CVS server. It's in draw2d.examples project.
> > anything.
> > > Hi,
> don't
automatically
> > in
> freeformLayer)
CircuitFigure).
scroll
> > bar.
> > > Thank you.
> > > add(scrollpane);
> > > pane.add(flowPage);
Re: Put a FlowPage within a ScrollPane [message #64079 is a reply to message #64012] Mon, 10 February 2003 14:50 Go to previous messageGo to next message
Originally posted by: radienssmgs2.hotmail.com
Randy,
Could you please help me with my question as well? I have a similar
question.
I would like to put a SWT TreeTable inside a Container Figure (e.g.
CircuitFigure).
Thanks for any help.
In my constructor of CircuitFigure()
setLayoutManager(new FlowLayout());
Shell shell = new Shell(Display.getCurrent());
final TableTree tableTree = new TableTree(shell, SWT.FULL_SELECTION);
// populate my tableTree
FigureCanvas fc = new FigureCanvas(tableTree);
fc.setViewport(new FreeformViewport());
fc.setContents(pane);
add(fc.getContents());
news:b28qfr$gu4$1@rogue.oti.com...
> bar.
me
> gives
> > add(scrollpane);
Viewport.
project.
Freeform
> > > anything.
> > > > Hi,
> > don't
> automatically
> > > in
> > freeformLayer)
> CircuitFigure).
> scroll
> > > bar.
> > > > Thank you.
> > > > add(scrollpane);
> > > > pane.add(flowPage);
Re: Put a FlowPage within a ScrollPane [message #64098 is a reply to message #64079] Mon, 10 February 2003 15:35 Go to previous messageGo to next message
You would probably need a proxy figure that positions the TreeTable in
response to its setBounds method. You would have to jump through hoops to
get keyboard and focus handled properly. What are you trying to display?
"Jack R." <radienssmgs2@hotmail.com> wrote in message
news:b28ubo$jv0$1@rogue.oti.com...
> Randy,
> question.
> CircuitFigure).
Scroll
> > bar.
> me
> > gives
> > > add(scrollpane);
> Viewport.
> project.
> Freeform
> > > > anything.
> > > > > Hi,
(I
> > > don't
> > automatically
> > > > in
> > > freeformLayer)
> > CircuitFigure).
> > scroll
> > > > bar.
> > > > > Thank you.
> > > > > add(scrollpane);
> > > > > pane.add(flowPage);
Re: Put a FlowPage within a ScrollPane [message #64122 is a reply to message #64098] Mon, 10 February 2003 16:07 Go to previous message
I am trying to display a TreeTable, in which I click on the parent, it will
expand/collapse its children within a draw2D figure.
news:b2910h$m22$1@rogue.oti.com...
> > Randy,
> > question.
> > CircuitFigure).
> Scroll
> > > bar.
gives
> > me
and
> > > gives
> > > > add(scrollpane);
> > Viewport.
> > project.
> > Freeform
> > > > > anything.
> > > > > > Hi,
> (I
> > > > don't
> > > automatically
> > > > > in
> > > > freeformLayer)
> > > CircuitFigure).
> > > scroll
> > > > > bar.
FlowPage?
> > > > > > Thank you.
> > > > > > add(scrollpane);
cvs.
> > > > > > pane.add(flowPage);
Previous Topic:GEF release in CVS broken?
Next Topic:Logic Example
Current Time: Sun Aug 31 12:24:25 EDT 2025
Powered by FUDForum. Page generated in 0.10630 seconds
