Home » Language IDEs » Java Development Tools (JDT) » LibraryClasspathContainer available
LibraryClasspathContainer available [message #63887] Sat, 21 June 2003 08:32 Go to next message
I'm posting this message, because the previous title was not very
descriptive.
In short, download a library classpathcontainer from the thread:
Multiple ClasspathContainers, Settings
You can add a folder in your javaproject settings
*goto: java build path->libraries->add library
*choose library folder.
*browse for a folder
*select/unselect search files in subfolders
I've seen some refreshing problems I can't figure out. It happens sometimes
when you add and remove a library before pressing ok..
Have fun
Joris Verschoor
Re: LibraryClasspathContainer available [message #63958 is a reply to message #63887] Sat, 21 June 2003 10:56 Go to previous messageGo to next message
Curios, what is wrong with Add jar.
martin
Re: LibraryClasspathContainer available [message #64121 is a reply to message #63958] Sat, 21 June 2003 19:12 Go to previous messageGo to next message
It's clutters your project tree when having a lot of jars
For web applications, it's very handy to have a LibraryFolder on for example
docroot/WEB-INF/lib
because that's what the appserver will use.
"Martin M
Re: LibraryClasspathContainer available [message #64286 is a reply to message #64121] Sun, 22 June 2003 05:31 Go to previous messageGo to next message
There is a filter option in package & resource view, *.jar and they
are away of your sight.
>docroot/WEB-INF/lib
Ah, thats true. Having same mechanism is good.
martin
Re: LibraryClasspathContainer available [message #64309 is a reply to message #64286] Sun, 22 June 2003 05:59 Go to previous messageGo to next message
Yes, I've used that, but I found that I occasionally would like to check
some classes/resource inside the jars.
btw, the filter 'hide referenced libraries' seems to work good under
eclipse3.. Before it didn't hide every jarfile
Re: LibraryClasspathContainer available [message #66222 is a reply to message #63887] Tue, 24 June 2003 11:03 Go to previous message
Originally posted by: j.verschoor.nefli.nl
So nobody else has any comments on this?
"Joris Verschoor" <j.verschoor@insomniq.com> wrote in message
news:bd1j89$7ci$1@rogue.oti.com...
> descriptive.
sometimes
> Have fun
> Joris Verschoor
Previous Topic:Organize imports filter
Next Topic:Sharing multiple projects in one CVS module
Current Time: Wed Jul 23 16:54:16 EDT 2025
Powered by FUDForum. Page generated in 0.07874 seconds
