Home » Modeling » EMF » [CDO] Problem after CDO Source Installation(Alter the CDO Source Installation i got exceptions with every commit.)
[CDO] Problem after CDO Source Installation [message #634072] |
Wed, 20 October 2010 13:03 |
Vincent Wienecke Messages: 3 Registered: October 2010 |
Junior Member |
Hi, i am new in the CDO world and i try to get feeling for it and experience.
First i installed the CDO client plugins (with net4j Plugins) in a fresh and updated Eclipse (Eclipse Modelling Tools version).
After this i installed the CDO Source accurately after this instruction:
http://wiki.eclipse.org/CDO_Source_Installation
I started the default "CDOServer" Eclipse Application Configuration and it started without an error. I prepared a simple EMF project with the giving instruction (http://wiki.eclipse.org/Preparing_EMF_Models_for_CDO).
With the first commit, which i do after an other instruction (http://wiki.eclipse.org/Using_the_CDO_User_Interface), i got some exceptions. (Output at the end of this post)
I repeaded the steps of the installation instruction, but i got always the same exceptions.
I looks like a incomplete InputSream. I try to isolate the problem in the last IF-loop of the StoreAccessor->write(). Without this IF-loop the commit works, but i get exceptions if i try to load the commited resource (which i expected).
I have no idea, what is going wrong. I make everything after an instruction a the exceptions give no hints to me.
Have anybody an idea, what the problem is ?
Here is the output, which i get, if i try to commit a resource (without any changes in the source code):
### client output ###
org.eclipse.net4j.signal.RemoteException: org.eclipse.net4j.util.WrappedException: java.io.EOFException
at org.eclipse.net4j.util.WrappedException.wrap(WrappedExceptio n.java:50)
at org.eclipse.emf.cdo.spi.server.StoreAccessor.write(StoreAcce ssor.java:223)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext .write(TransactionCommitContext.java:407)
at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLo op(InternalCommitContext.java:40)
at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLo op(InternalCommitContext.java:1)
at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(Pr ogressDistributor.java:96)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication.indicatingCommit(CommitTransactionIndicat ion.java:342)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication.indicating(CommitTransactionIndication.ja va:199)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication.indicating(CommitTransactionIndication.ja va:127)
at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating (IndicationWithMonitoring.java:84)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedIn put(IndicationWithResponse.java:90)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:316)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:63)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(In dicationWithMonitoring.java:63)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:241)
at org.eclipse.net4j.signal.Signal.run(Signal.java:147)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.io.EOFException
at java.io.DataInputStream.readInt(DataInputStream.java:375)
at org.eclipse.emf.cdo.spi.server.StoreAccessor.write(StoreAcce ssor.java:206)
... 17 more
org.eclipse.net4j.signal.RemoteException: org.eclipse.net4j.signal.RemoteException: org.eclipse.net4j.util.WrappedException: java.io.EOFException
... 17 more
at org.eclipse.net4j.signal.RequestWithConfirmation.setRemoteEx ception(RequestWithConfirmation.java:128)
at org.eclipse.net4j.signal.SignalProtocol.handleRemoteExceptio n(SignalProtocol.java:535)
at org.eclipse.net4j.signal.RemoteExceptionIndication.indicatin g(RemoteExceptionIndication.java:53)
at org.eclipse.net4j.signal.Indication.doExtendedInput(Indicati on.java:55)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:315)
at org.eclipse.net4j.signal.Indication.execute(Indication.java: 49)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:240)
at org.eclipse.net4j.signal.Signal.run(Signal.java:146)
Caused by: org.eclipse.net4j.signal.RemoteException: org.eclipse.net4j.util.WrappedException: java.io.EOFException
... 17 more
at org.eclipse.net4j.signal.RemoteExceptionIndication.indicatin g(RemoteExceptionIndication.java:50)
... 8 more
### server output ###
Thread-22 [debug] Writing revision: Institut@OID2:0v1
Thread-22 [debug.sql] prep7: INSERT IGNORE INTO cdo_objects(cdo_id,cdo_class,cdo_created) VALUES (?, ?, ?) {1: 2, 2: 482, 3: 1287576006625};
Thread-22 [debug.sql] prep13: INSERT IGNORE INTO Institut(cdo_id, cdo_version, cdo_branch, cdo_class, cdo_created, cdo_revised, cdo_resource, cdo_container, cdo_feature, Name) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?) {1: 2, 2: 1, 3: 0, 4: 482, 5: 1287576006625, 6: 0, 7: 3, 8: 0, 9: 0, 10: 'Informatik'};
Thread-22 [debug] Writing revision: CDOResource@OID3:0v1
Thread-22 [debug.sql] prep7: INSERT IGNORE INTO cdo_objects(cdo_id,cdo_class,cdo_created) VALUES (?, ?, ?) {1: 3, 2: 441, 3: 1287576006625};
Thread-22 [debug] Created Resource Query: prep14: SELECT cdo_id FROM CDOResourceFolder WHERE cdo_version>0 AND cdo_branch=? AND cdo_container=? AND name =? AND (cdo_revised=0) {1: 0, 2: 0, 3: 'res1'};
Thread-22 [debug] Created Resource Query: prep15: SELECT cdo_id FROM CDOResource WHERE cdo_version>0 AND cdo_branch=? AND cdo_container=? AND name =? AND (cdo_revised=0) {1: 0, 2: 0, 3: 'res1'};
Thread-22 [debug] TypeMapping for folder: writing Revision.null as DB.null
Thread-22 [debug.sql] prep10: INSERT IGNORE INTO CDOResource(cdo_id, cdo_version, cdo_branch, cdo_class, cdo_created, cdo_revised, cdo_resource, cdo_container, cdo_feature, folder, name) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) {1: 3, 2: 1, 3: 0, 4: 441, 5: 1287576006625, 6: 0, 7: 1, 8: 0, 9: 0, 10: NULL, 11: 'res1'};
Thread-22 [debug] Writing value for feature CDOResource.contents index 0 of OID3v1 : OID2
Thread-22 [debug.sql] prep16: INSERT IGNORE INTO CDOResource_contents_list(cdo_source, cdo_branch, cdo_version, cdo_idx, cdo_value) VALUES (?, ?, ?, ?, ?) {1: 3, 2: 0, 3: 1, 4: 0, 5: 2};
Thread-22 [debug] Writing revision: CDOResource@OID1:0v2
Thread-22 [debug.sql] prep17: UPDATE CDOResource SET cdo_revised=? WHERE cdo_id=? AND cdo_branch=? AND cdo_revised=0 {1: 1287576006624, 2: 1, 3: 0};
Thread-22 [debug] Created Resource Query: prep8: SELECT cdo_id FROM CDOResourceFolder WHERE cdo_version>0 AND cdo_branch=? AND cdo_container=? AND name IS NULL AND (cdo_revised=0) {1: 0, 2: 0};
Thread-22 [debug] Created Resource Query: prep9: SELECT cdo_id FROM CDOResource WHERE cdo_version>0 AND cdo_branch=? AND cdo_container=? AND name IS NULL AND (cdo_revised=0) {1: 0, 2: 0};
Thread-22 [debug] TypeMapping for name: writing Revision.null as DB.null
Thread-22 [debug.sql] prep10: INSERT IGNORE INTO CDOResource(cdo_id, cdo_version, cdo_branch, cdo_class, cdo_created, cdo_revised, cdo_resource, cdo_container, cdo_feature, folder, name) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) {1: 1, 2: 2, 3: 0, 4: 441, 5: 1287576006625, 6: 0, 7: 1, 8: 0, 9: 0, 10: NULL, 11: NULL};
Thread-22 [debug] Writing value for feature CDOResource.contents index 0 of OID1v2 : OID3
Thread-22 [debug.sql] prep16: INSERT IGNORE INTO CDOResource_contents_list(cdo_source, cdo_branch, cdo_version, cdo_idx, cdo_value) VALUES (?, ?, ?, ?, ?) {1: 1, 2: 0, 3: 2, 4: 0, 5: 3};
[ERROR] java.io.EOFException
... 17 more
Thread-22 [debug] Rolling back transaction: Transaction[2:1]
Thread-22 [debug] --- DB ROLLBACK ---
Thread-22 [debug.sql] DROP TABLE Person
Thread-22 [debug.sql] DROP TABLE Mitarbeiter
Thread-22 [debug.sql] DROP TABLE Student
Thread-22 [debug.sql] DROP TABLE Institut
Thread-22 [debug.sql] DROP TABLE Vorlesung
Thread-22 [debug.sql] DROP TABLE Vorlesung_Hörer_list
... 17 more
Thread-22 [debug.signal] ================ Requesting: Signal[protocol=cdo, id=-1, name=RemoteExceptionRequest, correlation=1]
Thread-22 [debug.signal] Writing remote exception for signal 5: org.eclipse.net4j.util.WrappedException: java.io.EOFException
Thread-22 [debug.buffer] Obtained Buffer@41[INITIAL]
Thread-22 [debug.buffer.stream] Put signal id -1
Thread-22 [debug.channel] Handling buffer: Buffer@41[PUTTING] --> Channel[1, SERVER]
Thread-22 [debug] Ordering server operation INTEREST WRITE java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:1910] = true
TCPSelector [debug] Executing server operation INTEREST WRITE java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:1910] = true
TCPSelector [debug] Setting interest READ|WRITE (was read)
Thread-22 [debug.buffer] Obtained Buffer@37[INITIAL]
TCPSelector [debug] Writing java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:1910]
TCPSelector [debug.buffer] Writing 4092 bytes
00 00 .... 7f [ERROR] java.io.EOFException
... 17 more
TCPSelector [debug.buffer] Retaining Buffer@41[RELEASED]
TCPSelector [debug] Ordering server operation INTEREST WRITE java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:1910] = false
TCPSelector [debug] Executing server operation INTEREST WRITE java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036 remote=/127.0.0.1:1910] = false
TCPSelector [debug] Setting interest READ (was read|write)
[Updated on: Wed, 20 October 2010 13:07] Report message to a moderator
Re: [CDO] Problem after CDO Source Installation [message #634091 is a reply to message #634072] |
Wed, 20 October 2010 13:51 |
Stefan Winkler Messages: 307 Registered: July 2009 Location: Germany |
Hi Vincent,
can you indicate which version of CDO, which platform and which DB you
are using?
Stefan
> experience.
> ssor.java:223)
> lExecutor.java:908)
> ssor.java:206)
> ... 17 more
> ssor.java:223)
> lExecutor.java:908)
> ssor.java:206)
> ... 17 more
> lExecutor.java:908)
> ssor.java:223)
> lExecutor.java:908)
> ssor.java:206)
> ... 17 more
> ... 8 more
> Thread-22 [debug] Writing revision: mailto:Institut@OID2:0v1
> Thread-22 [debug.sql] prep7: INSERT INTO
> 'Informatik'};
> Thread-22 [debug] Writing revision: mailto:CDOResource@OID3:0v1
> of OID3v1 : OID2
> Thread-22 [debug.sql] prep16: INSERT INTO
> Thread-22 [debug] Writing revision: mailto:CDOResource@OID1:0v2
> of OID1v2 : OID3
> ssor.java:223)
> lExecutor.java:908)
> ssor.java:206)
> ... 17 more
> ssor.java:223)
> lExecutor.java:908)
> ssor.java:206)
> ... 17 more
> Thread-22 [debug.buffer] Obtained mailto:Buffer@41[INITIAL]
> Thread-22 [debug.channel] Handling buffer: mailto:Buffer@41[PUTTING] -->
> Channel[1, SERVER]
> Thread-22 [debug.buffer] Obtained mailto:Buffer@37[INITIAL]
> ssor.java:223)
> lExecutor.java:908)
> ssor.java:206)
> ... 17 more
> TCPSelector [debug.buffer] Retaining mailto:Buffer@41[RELEASED]
Re: [CDO] Problem after CDO Source Installation [message #634106 is a reply to message #634072] |
Wed, 20 October 2010 14:04 |
Hi Vincent,
Comments below...
Am 20.10.2010 15:03, schrieb Vincent Wienecke:
Then you have CDO version X available.
Now you seem to have an additional CDO version from HEAD available.
If you don't ensure that both clients and server are launched from exactly the same set of plugins either version X or HEAD it's likely that you run into trouble. EOFExceptions in protocol signals are an indicator for this situation.
Note that, if you're setting up a development workspace for CDO, you're not expected to install the projects in that workspace as external plugins at the same time!
Cheers
/Eike
http://www.esc-net.de
> ... 17 more
> ... 17 more
> ... 17 more
> ... 8 more
> ... 17 more
> ... 17 more
> Thread-22 [debug.channel] Handling buffer: mailto:Buffer@41[PUTTING] --> Channel[1, SERVER]
> ... 17 more
Cheers
/Eike
Current Time: Fri Apr 26 09:46:59 GMT 2024
Powered by FUDForum. Page generated in 0.04164 seconds
