Agent Controller on Linux [message #63819] |
Tue, 04 April 2006 09:23  |
Originally posted by: thiago.arrais.gmail.com
I am trying to install the latest stable build (4.2.0 M5/200602281515)
on a Fedora Core 4 Linux machine. The instructions on the 'Getting
started with Agent Controller' page talk about a `/bin` directory that
wasn't included on my download (called
tptpdc.linux_ia32.sdk-TPTP-4.2.0-200602281515).
I couldn't find any installation instructions specific to 4.2 on the
tptp docs page. The page I mentioned refers to version 4.1. Was there
any change to the installation process that I am not aware of?
Thiago Arrais
Re: Agent Controller on Linux [message #64015 is a reply to message #63903] |
Tue, 04 April 2006 16:57  |
Thiago Arrais wrote:
> Heidi Gumpert escreveu:
>> I am also using the last stable build on Red Hat Ent. Linux 4. I am
>> using the runtime version instead of the SDK and I have the bin folder
>> with the RAStart/RAStop scripts.
>> (tptpdc.linux_ia32-TPTP-4.2.0-200602281515)
> Thanks, Heidi. I am currently downloading the runtime version.
> The download is much larger. Am I supposed to locally build the SDK
> version? Would this classify as a bug?
> Cheers,
> Thiago Arrais
I filed a bug a while back because the web pages said the SDK was
runtime+what you needed to build against. The resolution was to change
the webpage, as the intent was apparently that you would get the
runtime, and if you wanted to build against it, you'd *add* the SDK.
With that resolution in hand, that's how we're changing the new
technology AC&SDK to be packaged as well. So I think it is debatable
which is "the right way". Nevertheless, you're on track getting things
going if you get the runtime.
Since you're on FC, make sure you don't try running with the default gcj
Java unless you know more about getting that to work than I do... you'll
need a Java download from somewhere else (Sun, IBM, etc.).
Oh, and your last question... the SDK is just stuff to "build against"
.... RAC libraries and include files that allow clients/agents to talk
through the RAC to each other... what are you wanting to do??
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
FUDForum. Page generated in 0.24598 seconds
