Home » Archived » Test and Performance Tools Platform (TPTP) » testing tools : java.lang.NumberFormatException: For input string: "p"
testing tools : java.lang.NumberFormatException: For input string: "p" [message #63792] |
Tue, 04 April 2006 08:47  |
Originally posted by: anthonycrowtheralwyn.hotmail.com
Hey everyone,
Since I've moved from Tomcat 4 to Tomcat 5, I can record but I can't run
my TPTP tests anymore without having a java.lang.NumberFormatException.
Here's my configuration :
Eclipse 3.2 M5
JDK 1.5.0_06
Tomcat 5.5.15
Here's one of the JUnits that fails, it only tries to connect to a page at
the address "/TOK/PAT.do?enter=1"
When debbuging, it stops at line "executeRequest(request);"
in Recording.c1GETLocalhost()
saying java.lang.NumberFormatException: For input string: "p"
The variable causing that is the integer "rc". It's value is -1 instead of
a normal integer... I can't go deeper in the code because it's in
http.runner.jar.
JUnit :
package test;
import java.util.Random;
import junit.extensions.RepeatedTest;
import junit.framework.Test;
import org.eclipse.hyades.test.common.junit.DefaultTestArbiter;
import org.eclipse.hyades.test.common.junit.HyadesTestCase;
import org.eclipse.hyades.test.common.junit.HyadesTestSuite;
import org.eclipse.hyades.test.http.runner.HttpCookieCache;
import org.eclipse.hyades.test.http.runner.HttpExecutor;
import org.eclipse.hyades.test.http.runner.HttpHeader;
import org.eclipse.hyades.test.http.runner.HttpRequest;
import org.eclipse.hyades.test.http.runner.HttpResponse;
import org.eclipse.hyades.test.http.runner.internal.util.HttpTestUt il;
* Generated code for the test suite <b>recording</b> located at
* <i>/Servers/recording.testsuite</i>.
public class Recording extends HyadesTestCase {
* Constructor for Recording.
* @param name
public Recording(String name) {
super(name);
* Returns the JUnit test suite that implements the <b>recording</b>
* definition.
public static Test suite() {
HyadesTestSuite recording = new HyadesTestSuite("recording");
recording.setArbiter(DefaultTestArbiter.INSTANCE).setId(
"DCD296796B927EB81AA5C4A0C3D611DA");
HyadesTestSuite loop1 = new HyadesTestSuite("Loop 1");
recording.addTest(new RepeatedTest(loop1, 1));
loop1.setId("DCD296796B927EB81AA5C4A4C3D611DA");
HyadesTestSuite pageLocalhost_TOK_PAT_do_enter_1 = new HyadesTestSuite(
"Page localhost/TOK/PAT.do?enter=1");
loop1.addTest(new RepeatedTest(pageLocalhost_TOK_PAT_do_enter_1, 1));
.setId("DCD296796B927EB81AA835A0C3D611DA");
.addTest(new Recording("c1GETLocalhost")
.setId("DCD296796B927EB81AAAA6A0C3D611DA")
.setTestInvocationId("DCD296796B927EB81AAAA6A4C3D611DA"));
return recording;
* @see junit.framework.TestCase#setUp()
protected void setUp() throws Exception {
* @see junit.framework.TestCase#tearDown()
protected void tearDown() throws Exception {
* 1 GET localhost
* @throws Exception
public void c1GETLocalhost() throws Exception {
HttpRequest request = new HttpRequest();
request.setMethod("GET");
request.setVersion("1.1");
request.setHost("localhost");
request.setPort(8000);
request.setAbsolutePath("/TOK/PAT.do?enter=1");
request.setPageNumber(1);
request.setPageOrder(HttpRequest.PAGE_START);
request.setSecure(false);
HttpHeader header;
header = new HttpHeader();
header.setName("Accept");
header
.setValue("image/gif, image/x-xbitmap, image/jpeg, image/pjpeg,
application/x-shockwave-flash, application/vnd.ms-excel,
application/vnd.ms-powerpoint, application/msword, */*");
request.addHeader(header);
header.setName("Accept-Language");
header.setValue("fr");
header.setName("Accept-Encoding");
header.setValue("gzip, deflate");
header.setName("User-Agent");
header
.setValue("Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1;
NET CLR 1.1.4322)");
header.setName("Host");
header.setValue("localhost:8000");
header.setName("Connection");
header.setValue("Keep-Alive");
* Member variables *
static protected HttpCookieCache[] m_httpCookieCache;
static protected HttpExecutor[] m_httpExecutor;
protected Random rand = new Random();
* Extra Methods *
public void populateCookieCache(HttpCookieCache cookies) {
//By default, the cookie cache is created empty. To add new cookies,
use the following
//cookies.AddCookie(name, value, domain, path, expires, bSecure);
protected void executeRequest(HttpRequest request) throws Exception {
if (m_httpExecutor == null || m_httpCookieCache == null)
initializeTest();
int nUser = HttpTestUtil.getCurrentUser(this);
m_httpCookieCache[nUser].DynamicGetCookie(request);
HttpResponse response = m_httpExecutor[nUser].execute(request);
String text = "rc=" + Integer.toString(response.getCode());
if (response.getDetail() != null)
text = "\n\n" + response.getDetail();
//If (response.getCode() < 0) then there was an error when executing the
request
if (response.getCode() < 0)
throw new Exception(text);
try {
m_httpCookieCache[nUser].DynamicSetCookie(request, response);
} catch (Exception e) {
//If (response.getCode() < 400) then the request has failed.
assertTrue(text, response.getCode() < 400 && response.getCode() > 0);
synchronized protected void initializeTest() {
int nTotal = HttpTestUtil.getTotalUsers(this);
if (m_httpCookieCache == null) {
m_httpCookieCache = new HttpCookieCache[nTotal];
for (int i = 0; i < nTotal; i++) {
m_httpCookieCache[i] = new HttpCookieCache();
populateCookieCache(m_httpCookieCache[i]);
if (m_httpExecutor == null) {
m_httpExecutor = new HttpExecutor[nTotal];
m_httpExecutor[i] = new HttpExecutor();
protected long calcThinkTime(long think, int var) {
if (var > 0 && var <= 99) {
long delta = think * var / 100;
if (delta <= 0)
delta = 1;
think += (rand.nextInt((int) delta * 2) - delta);
return think;
Thanks by advance for your help!
Anthony Crowther-Alwyn
Re: testing tools : java.lang.NumberFormatException: For input string: "p" [message #64296 is a reply to message #63792] |
Wed, 05 April 2006 07:22  |
Hi Anthony,
This appears to be a defect. Please open a TPTP Bugzilla for this issue
with Tomcat V5.x. However, if you do not have a lot of custom code in your
JUnit test class, try re-recording the test using Tomcat V5.x.
Paul
"Anthony Crowther-Alwyn" <anthonycrowtheralwyn@hotmail.com> wrote in message
news:9fb2397095c219aeb394ddda92be5404$1@www.eclipse.org...
> Hey everyone,
> Eclipse 3.2 M5
> JDK 1.5.0_06
> Tomcat 5.5.15
> http.runner.jar.
> JUnit :
> package test;
> * @param name
> super(name);
> * definition.
> return recording;
> * 1 GET localhost
> * @throws Exception
> HttpHeader header;
> header
> header
> * Extra Methods *
> use the following
> initializeTest();
> request
> try {
> if (delta <= 0)
> delta = 1;
> return think;
Current Time: Thu Jul 17 20:51:19 EDT 2025
Powered by FUDForum. Page generated in 0.22679 seconds
