Home » Archived » BIRT » Script engine error: TypeError: [JavaPackage org.eclipse.birt.util.VarianceFactory] is not a functio
Script engine error: TypeError: [JavaPackage org.eclipse.birt.util.VarianceFactory] is not a functio [message #63780] Tue, 02 August 2005 21:23 Go to next message
When I tried to run a scripted data source I encounter the following :
A Birt exception occurred.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Data Engine
Plug-in ID:org.eclipse.birt.data
Version:1.0.0
Error Code:data.engine.JSScriptInvalid
Error Message:Invalid Javascript expression. Source: DataSet:Data
Set.open, line: 0, Expression:
function_prefix_1123029193460();function
function_prefix_1123029193460(){count = 0;
vf = new Packages.org.eclipse.birt.util.VarianceFactory();
v = vf.createVariance();}
org.eclipse.birt.util.VarianceFactory] is not a function. (DataSet:Data
Set.open#1)
I copied all my classes into ActuateBIRT1\BIRT Report
Designer\eclipse\plugins\org.eclipse.birt.report.viewer_1.0. 0\birt\WEB-INF\c
lasses\org\eclipse\birt\util
What else do I need to setup ?
Re: Script engine error: TypeError: [JavaPackage org.eclipse.birt.util.VarianceFactory] is not a fun [message #66283 is a reply to message #63780] Tue, 09 August 2005 18:22 Go to previous message
Does VarianceFactory call any other class that is external to your Package?
If so make sure all the jars are in the lib under web-inf
Jason Weathersby
BIRT PMC
"JTan" <jamestanms@hotmail.com> wrote in message
news:dcp6au$6u0$1@news.eclipse.org...
> Version:1.0.0
> Set.open#1)
Previous Topic:BIRT charts really sluggish on Linux
Next Topic:Highlights on Chart
Current Time: Mon Jul 14 14:03:33 EDT 2025
Powered by FUDForum. Page generated in 0.03485 seconds
