VE and third party components [message #63737] |
Fri, 01 October 2004 07:25  |
I want to use JGraph with VE, and was wondering how to include it within
the VE framework as a component available to the user. Are third party
components supported, or can the VE currently only handle the standard
component provided by Java and SWT?
Thanks...
Mike
Re: VE and third party components [message #63831 is a reply to message #63783] |
Fri, 01 October 2004 20:27  |
Hi Jeff, thanks for the help. Worked first time.
Jeff Myers wrote:
> Michael Ansley wrote:
>> Thanks...
>> Mike
> Yes, you should be able to drop and visualize any component with a
> public no-argument constructor that extends java.awt.Component, or in
> SWT org.eclipse.swt.widgets.Control. Any non-visual class with a public
> no-argument constructor can be dropped on the free form surface (white
> background area in the design pane). This can be accomplished using the
> Choose Bean function in the VE. How well you can customize and
> configure the component after it's dropped depends on whether the
> component follows the Java Beans spec. You can add your own Beaninfo
> for the components you're using to define things like enumerated values
> on the property sheet and property editors/customizers. See the VE help
> docs for more info on this.
> Good luck!
> - Jeff
Re: VE and third party components [message #600389 is a reply to message #63737] |
Fri, 01 October 2004 09:43  |
> Thanks...
> Mike
Good luck!
- Jeff
Re: VE and third party components [message #600410 is a reply to message #63783] |
>> Thanks...
>> Mike
> Good luck!
> - Jeff
FUDForum. Page generated in 0.08115 seconds
