Home » Eclipse Projects » Plugin Development Environment (PDE) » Running as if I were pointed to an installation
Running as if I were pointed to an installation [message #63733] |
Mon, 01 June 2009 03:25  |
Originally posted by: francis.oaklandsoftware.com
In my "RCP" product, I have an API which is distributed through a JAR
file. It has a few top-level API classes, and when you call one of them,
it starts the Eclipse framework using the EclipseStart stuff (through
reflection). This way the caller only needs my little JAR file.
This has all been working great, and I have been sucessfully testing it by
pointing the osgi.instance.area to a real Eclipse deployment of my product
(complete with configuration, plugins, features directories).
The downside of testing like this is that I need to do the batch
build/export to make this kit to point to, rather than pointing directly
to the binaries in my workspace. So now I'm trying to make this work (I
know it's possible, since that's what PDE does when it runs).
What's happening is that it is getting into my code in the Eclipse
install, but it's dying because the org.eclipse.core.resources bundle was
not started. So somehow that's not happening (and probably other things
are not happening as well).
Details of the configuration follow.
Any help is appreciated!
Francis
I'm testing with the following properties:
osgi.noShutdown=true,
eclipse.application=com.oaklandsw.transform.runtime.engine,
osgi.install.area=/home/francis/d/transform/com.oaklandsw.tr ansform.tests.mule/deploy,
osgi.parentClassloader=fwk,
osgi.framework=file:/usr/local/eclipse_deploy/eclipse341/ecl ipse/plugins/org.eclipse.osgi_3.4.2.R34x_v20080826-1230.jar,
osgi.instance.area=/tmp/osdtWorkspace15181.tmp
And the contents of the osgi.install.area is only:
configuration
org.eclipse.equionox.simpleconfigurator
bundles.info
config.ini
dev.properties
My config.ini looks like this:
osgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.core.runtime@start,org.eclipse.equinox.simpleconfigurator@1\:start
osgi.bundles.defaultStartLevel=4
eclipse.p2.profile=OSDTProfile
eclipse.p2.data.area=@config.dir/../p2
My dev.properties is:
com.oaklandsw.transform.external.qizxopen=bin
com.oaklandsw.transform.runtime.api=bin
com.oaklandsw.util=bin
com.oaklandsw.transform.external.xstream=bin
com.oaklandsw.transform.external.mxquery=bin
com.oaklandsw.util.tests=bin
com.oaklandsw.transform.runtime=bin,binexample
com.oaklandsw.transform.external.mule=bin
com.oaklandsw.transform.tests=bin
com.oaklandsw.gui=bin
com.oaklandsw.data.standard.x12.scripts=bin
com.oaklandsw.transform.external.saxon9=bin
com.oaklandsw.transform.external.hibernate33=target/classes
com.oaklandsw.transform.external.saxon9sa=bin
com.oaklandsw.transform.examples=bin
com.oaklandsw.data.standards.x12.3050=bin
com.oaklandsw.base=bin
com.oaklandsw.transform.runtime.servlet=build/classes
com.oaklandsw.util.log4j=bin
com.oaklandsw.gui.tests=bin
com.oaklandsw.transform.external.quickbooks=bin
com.oaklandsw.transform.external.cb2xml=bin
com.oaklandsw.transform=bin
com.oaklandsw.util.log=bin
com.oaklandsw.build=bin
com.oaklandsw.base.tests=bin
@ignoredot@=true
com.oaklandsw.transform.external.qexo=bin
com.oaklandsw.transform.external.saxon89=bin
com.oaklandsw.transform.tests.mule=bin
And my bundles.info has all of the plugins and their locations.
Common Navigator Framework section in Platform Plugin Developer Guide
(Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Re: Running as if I were pointed to an installation [message #63758 is a reply to message #63733] |
Mon, 01 June 2009 03:38   |
A bit more information (still stuck and would like help) :)
I also tried putting the following line into my config.ini (same results,
as I expected, because it's actually finding my classes that are in the
workspace):
osgi.dev=@config.dir/dev.properties
The ...RuntimeFactory class comes from the classpath (it would be in my
little JAR file), the ...RuntimeEngineImpl and AppRuntimeImpl classes come
from the Eclipse installation (and these are getting successfully invoked).
And here is the stack trace of the failure (the interesting stuff is in
the bottom 2 frames, you can pretty much ignore the rest):
org.mule.api.config.ConfigurationException: Initialisation Failure: Error
creating bean with name 'EchoPaypal': Cannot create inner bean '(inner
bean)' of type [org.mule.routing.inbound.DefaultInboundRouterCollection]
while setting bean property 'inboundRouter'; nested exception is
org.springframework.beans.factory.BeanCreationException: Error creating
bean with name '(inner bean)': Cannot create inner bean '(inner bean)' of
type [org.mule.config.spring.factories.InboundEndpointFactoryBean ] while
setting bean property 'endpoints' with key [0]; nested exception is
bean with name '(inner bean)': Cannot resolve reference to bean
'osdt_paypal' while setting bean property 'transformers' with key [0];
nested exception is
bean with name 'osdt_paypal': Invocation of init method failed; nested
exception is java.lang.RuntimeException: Unable to start runtime because
of exception (org.mule.api.lifecycle.InitialisationException)
org.mule.config.builders.AbstractConfigurationBuilder.config ure(AbstractConfigurationBuilder.java:46)
org.mule.config.builders.AbstractResourceConfigurationBuilde r.configure(AbstractResourceConfigurationBuilder.java:78)
org.mule.context.DefaultMuleContextFactory.createMuleContext (DefaultMuleContextFactory.java:79)
org.mule.tck.AbstractMuleTestCase.createMuleContext(Abstract MuleTestCase.java:404)
at org.mule.tck.AbstractMuleTestCase.setUp(AbstractMuleTestCase .java:373)
at junit.framework.TestCase.runBare(TestCase.java:128)
org.mule.tck.AbstractMuleTestCase.runBare(AbstractMuleTestCa se.java:253)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:120)
at org.mule.tck.AbstractMuleTestCase.run(AbstractMuleTestCase.j ava:233)
at junit.framework.TestSuite.runTest(TestSuite.java:230)
at junit.framework.TestSuite.run(TestSuite.java:225)
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:130)
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
Caused by: org.mule.api.lifecycle.InitialisationException: Initialisation
Failure: Error creating bean with name 'EchoPaypal': Cannot create inner
bean '(inner bean)' of type
[org.mule.routing.inbound.DefaultInboundRouterCollection] while setting
nested exception is
of exception
at org.mule.registry.AbstractRegistry.initialise(AbstractRegist ry.java:79)
org.mule.config.spring.SpringXmlConfigurationBuilder.createS pringRegistry(SpringXmlConfigurationBuilder.java:98)
org.mule.config.spring.SpringXmlConfigurationBuilder.doConfi gure(SpringXmlConfigurationBuilder.java:69)
org.mule.config.builders.AbstractConfigurationBuilder.config ure(AbstractConfigurationBuilder.java:39)
... 19 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error
nested exception is
of exception
org.springframework.beans.factory.support.BeanDefinitionValu eResolver.resolveInnerBean(BeanDefinitionValueResolver.java: 230)
org.springframework.beans.factory.support.BeanDefinitionValu eResolver.resolveValueIfNecessary(BeanDefinitionValueResolve r.java:122)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.applyPropertyValues(AbstractAutowireCapable BeanFactory.java:1245)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.populateBean(AbstractAutowireCapableBeanFac tory.java:1010)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFac tory.java:472)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.ja va:409)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.createBean(AbstractAutowireCapableBeanFacto ry.java:380)
org.springframework.beans.factory.support.AbstractBeanFactor y$1.getObject(AbstractBeanFactory.java:264)
org.springframework.beans.factory.support.DefaultSingletonBe anRegistry.getSingleton(DefaultSingletonBeanRegistry.java:22 2)
org.springframework.beans.factory.support.AbstractBeanFactor y.doGetBean(AbstractBeanFactory.java:261)
org.springframework.beans.factory.support.AbstractBeanFactor y.getBean(AbstractBeanFactory.java:185)
org.springframework.beans.factory.support.AbstractBeanFactor y.getBean(AbstractBeanFactory.java:164)
org.springframework.beans.factory.support.DefaultListableBea nFactory.preInstantiateSingletons(DefaultListableBeanFactory .java:429)
org.springframework.context.support.AbstractApplicationConte xt.finishBeanFactoryInitialization(AbstractApplicationContex t.java:728)
org.springframework.context.support.AbstractApplicationConte xt.refresh(AbstractApplicationContext.java:380)
org.mule.config.spring.SpringRegistry.doInitialise(SpringReg istry.java:87)
at org.mule.registry.AbstractRegistry.initialise(AbstractRegist ry.java:71)
... 22 more
creating bean with name '(inner bean)': Cannot create inner bean '(inner
bean)' of type
nested exception is
of exception
org.springframework.beans.factory.support.BeanDefinitionValu eResolver.resolveManagedList(BeanDefinitionValueResolver.jav a:287)
org.springframework.beans.factory.support.BeanDefinitionValu eResolver.resolveValueIfNecessary(BeanDefinitionValueResolve r.java:126)
org.springframework.beans.factory.support.BeanDefinitionValu eResolver.resolveInnerBean(BeanDefinitionValueResolver.java: 219)
... 39 more
creating bean with name '(inner bean)': Cannot resolve reference to bean
nested exception is
of exception
org.springframework.beans.factory.support.BeanDefinitionValu eResolver.resolveReference(BeanDefinitionValueResolver.java: 275)
org.springframework.beans.factory.support.BeanDefinitionValu eResolver.resolveValueIfNecessary(BeanDefinitionValueResolve r.java:104)
... 49 more
creating bean with name 'osdt_paypal': Invocation of init method failed;
nested exception is java.lang.RuntimeException: Unable to start runtime
because of exception
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.initializeBean(AbstractAutowireCapableBeanF actory.java:1338)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFac tory.java:473)
org.springframework.beans.factory.support.AbstractBeanFactor y.doGetBean(AbstractBeanFactory.java:283)
org.springframework.beans.factory.support.BeanDefinitionValu eResolver.resolveReference(BeanDefinitionValueResolver.java: 269)
... 59 more
Caused by: java.lang.RuntimeException: Unable to start runtime because of
exception
com.oaklandsw.transform.runtime.RuntimeFactory.createRuntime (RuntimeFactory.java:293)
com.oaklandsw.transform.external.mule.OaklandCommon.initiali se(OaklandCommon.java:140)
com.oaklandsw.transform.external.mule.OaklandTransformer.ini tialise(OaklandTransformer.java:74)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapa bleBeanFactory.java:1414)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.invokeInitMethods(AbstractAutowireCapableBe anFactory.java:1375)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.initializeBean(AbstractAutowireCapableBeanF actory.java:1335)
... 67 more
Caused by: java.lang.RuntimeException: Plug-in
"com.oaklandsw.transform.runtime" was unable to instantiate class
"com.oaklandsw.transform.runtime.RuntimeEngineImpl".
com.oaklandsw.transform.runtime.RuntimeFactory.createRuntime (RuntimeFactory.java:250)
... 76 more
Caused by: org.eclipse.core.runtime.CoreException: Plug-in
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:172)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:188)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
com.oaklandsw.transform.runtime.RuntimeFactory.createRuntime (RuntimeFactory.java:243)
... 76 more
Caused by: java.lang.IllegalStateException: Workspace is closed.
org.eclipse.core.resources.ResourcesPlugin.getWorkspace(Reso urcesPlugin.java:339)
at com.oaklandsw.base.AppRuntimeImpl.<init>(AppRuntimeImpl.java:173)
com.oaklandsw.transform.runtime.RuntimeEngineImpl.<init>(RuntimeEngineImpl.java:147)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:4 94)
at java.lang.Class.newInstance0(Class.java:350)
at java.lang.Class.newInstance(Class.java:303)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:170)
... 88 more
On Mon, 01 Jun 2009 00:25:01 -0700, Francis Upton
> them, it starts the Eclipse framework using the EclipseStart stuff
> (through reflection). This way the caller only needs my little JAR file.
> by pointing the osgi.instance.area to a real Eclipse deployment of my
> product (complete with configuration, plugins, features directories).
> was not started. So somehow that's not happening (and probably other
> things are not happening as well).
> Francis
> configuration
> bundles.info
> config.ini
> dev.properties
> @ignoredot@=true
Re: Running as if I were pointed to an installation [message #63919 is a reply to message #63758] |
Tue, 02 June 2009 16:31   |
I notice the root exception:
> at
Which seems odd, because org.eclipse.core.resources is lazily started,
and its bundle activator start() sets up the workspace.
However, bundles will not get started until their start level is met,
even if classes are loaded earlier. Also:
If a class is loaded from a lazy activated bundle before its start-level
is met and then later the bundle's start-level is met the bundle will
not activate. It will only activate if a class is loaded from it while
its start-level is met.
So it seems that
is happening before reaching start level 4.
-Andrew
> results, as I expected, because it's actually finding my classes that
> are in the workspace):
> come from the Eclipse installation (and these are getting successfully
> invoked).
> Error creating bean with name 'EchoPaypal': Cannot create inner bean
> of type [org.mule.config.spring.factories.InboundEndpointFactoryBean ]
> while setting bean property 'endpoints' with key [0]; nested exception
> is org.springframework.beans.factory.BeanCreationException: Error
> nested exception is
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Initialisation Failure: Error creating bean with name 'EchoPaypal':
> Cannot create inner bean '(inner bean)' of type
> nested exception is
> of exception
> at
> at
> at
> at
> ... 19 more
> nested exception is
> of exception
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 22 more
> Error creating bean with name '(inner bean)': Cannot create inner bean
> nested exception is
> of exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 39 more
> Error creating bean with name '(inner bean)': Cannot resolve reference
> to bean 'osdt_paypal' while setting bean property 'transformers' with
> of exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 49 more
> Error creating bean with name 'osdt_paypal': Invocation of init method
> failed; nested exception is java.lang.RuntimeException: Unable to start
> runtime because of exception
> at
> at
> at
> at
> at
> at
> at
> at
> ... 59 more
> of exception
> at
> at
> at
> at
> at
> at
> at
> at
> ... 67 more
> at
> ... 76 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 76 more
> at
> at
> Method)
> at
> at
> at
> ... 88 more
>> it by pointing the osgi.instance.area to a real Eclipse deployment of
>> my product (complete with configuration, plugins, features directories).
>> directly to the binaries in my workspace. So now I'm trying to make
>> this work (I know it's possible, since that's what PDE does when it
>> runs).
>> Thanks,
>> Francis
>> configuration
>> bundles.info
>> config.ini
>> dev.properties
>> @ignoredot@=true
Re: Running as if I were pointed to an installation [message #63966 is a reply to message #63943] |
Tue, 02 June 2009 17:39  |
Ignore the previous post, see the thread in equinox for what's going on.
I won't continue with this thread.
On Tue, 02 Jun 2009 14:16:03 -0700, Francis Upton
> On Tue, 02 Jun 2009 13:31:09 -0700, Andrew Niefer <aniefer@ca.ibm.com>
> wrote:
>> So it seems that
> Thanks Andrew! And sorry for the double posting.
> The RuntimeFactory.createRuntime() is what actually calls the
> EclipseStarter through reflection. However the RuntimeEngineImpl
> constructor is what touches the resources. This is the class that is
> defined by the application extension point. Is there a way to get this
> class to run at a start level that's higher than 4?
> Francis
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: Running as if I were pointed to an installation [message #597998 is a reply to message #63733] |
workspace):
nested exception is
nested exception is
of exception
... 19 more
nested exception is
of exception
... 22 more
bean)' of type
nested exception is
of exception
... 39 more
nested exception is
of exception
... 49 more
... 59 more
exception
... 67 more
... 76 more
... 76 more
... 88 more
> Francis
> configuration
> bundles.info
> config.ini
> dev.properties
> @ignoredot@=true
Re: Running as if I were pointed to an installation [message #598056 is a reply to message #63758] |
> at
So it seems that
-Andrew
> invoked).
> nested exception is
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> nested exception is
> of exception
> at
> at
> at
> at
> ... 19 more
> nested exception is
> of exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 22 more
> nested exception is
> of exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 39 more
> of exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 49 more
> at
> at
> at
> at
> at
> at
> at
> at
> ... 59 more
> of exception
> at
> at
> at
> at
> at
> at
> at
> at
> ... 67 more
> at
> ... 76 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 76 more
> at
> at
> Method)
> at
> at
> at
> ... 88 more
>> runs).
>> Thanks,
>> Francis
>> configuration
>> bundles.info
>> config.ini
>> dev.properties
>> @ignoredot@=true
Re: Running as if I were pointed to an installation [message #598063 is a reply to message #63919] |
Tue, 02 June 2009 17:16  |
wrote:
> So it seems that
Francis
Re: Running as if I were pointed to an installation [message #598069 is a reply to message #63943] |
> wrote:
>> So it seems that
> Francis
Current Time: Sun Aug 31 23:46:38 EDT 2025
Powered by FUDForum. Page generated in 0.29345 seconds
