Home » Language IDEs » PHP Development Tools (PDT) » Xdebug - breakpoints don't work
Xdebug - breakpoints don't work [message #63722] Fri, 21 December 2007 00:12 Go to next message
Originally posted by: alexf.itechwebhosting.com
I can't get breakpoints to work with xdebug. I'm using M1 on Windows
Vista. I'm trying to debug a simple PHP script using the CLI version of
PHP. I have the "PHP -> PHP Executables" settings set properly. But the
IDE will not store the settings that I set under "PHP -> Debug". I set
Xdebug as my PHP Debugger and set the Default PHP executable, and hit
"Apply" and then "OK". But when I come back to those settings, they are
back at default with the "Zend Debugger".
Alex
Re: Xdebug - breakpoints don't work [message #63744 is a reply to message #63722] Fri, 21 December 2007 05:34 Go to previous messageGo to next message
Hi Alex, so just to clarify, you cannot define an executable with the PHP Debugger set to XDebug ?
every time you do, when you go back it has been reset to the Zend Debugger ?
How did you get M1 ? was it the all in one ? did you get it via the update site through eclipse
Install/Update ? or did you download the plugin package and installed it yourself.
Anyway, the case you have described was bug which was fixed before M1 was released. I have just
downloaded M1 (all in one) and I can define an exe with xdebug, so the fix is there in that version.
Try starting eclipse with the -clean option (eg eclipse -clean) to see if that helps it could be
you have old versions of the plugins present.
Dave Kelsey
> Alex
Re: Xdebug - breakpoints don't work [message #63836 is a reply to message #63744] Mon, 24 December 2007 23:40 Go to previous messageGo to next message
Sorry for the late response... my answers are below:
I can define a PHP Executable without any issue. The PHP executable
settings have Xdebug defined in the PHP.ini file and that is the one
being pointed to.
The problem is setting the PHP Debug settings (PHP/Debug in the menu
tree). I set PHP Debugger to XDebug, and Default PHP Executable to the
one I have defined. I then hit "Apply" and "OK". When I go back to the
same panel, the settings reverted back to the default.
> Debugger ?
Yes.
Yes. All-in-one file.
> update site through eclipse Install/Update ? or did you download the
I downloaded the entire Zip file for Windows and unzipped it in my C:\
path. All the Eclipse files are under C:\eclipse
> was released. I have just downloaded M1 (all in one) and I can define an
I downloaded the M1 file on 12/18. Is it possible that the fix did not
make it into the Windows version? Again, I have no problem defining an
Exe. It's the setting for Debug that's an issue.
I unzipped M1 into a clean directory. I even deleted my workspace
directory but I still have the same problem. Using "-clean" does not help.
> Thanks
> Dave Kelsey
>> Alex
->Buttons(Restore Defaults/Apply) of 'PHP Debug' preference don't work [message #63882 is a reply to message #63836] Tue, 25 December 2007 04:38 Go to previous messageGo to next message
(No one calls listener)
You can add bug report into Bugzilla.
Re: Xdebug - breakpoints don't work [message #63904 is a reply to message #63836] Wed, 26 December 2007 06:42 Go to previous messageGo to next message
Originally posted by: dkel50.hotnospmail.com
Hi Alex, ok I see the bug you are describing. I suggest you raise a
bugzilla about it.
However you should be able to still debug a script using xdebug. If you
click the PHP Executables tab in preferences and define your php
executable and select it to be XDebug that should stay as xdebug (This
was the bug I was refering to, this also used to reset back to zend).
When you create a script launch, you will be able to select the PHP
Debugger as XDebug and the PHP Executable will be available from the one
you defined in preferences.
This works for me.
Dave Kelsey
> being pointed to.
>> Debugger ?
> Yes.
>> Thanks
>> Dave Kelsey
>>> Alex
Re: Xdebug - breakpoints don't work [message #63927 is a reply to message #63836] Wed, 26 December 2007 07:15 Go to previous messageGo to next message
I guess you are trying to "Debug As-->PHP Script", and that isn't
working. So what you need to do is to select the "Run" Menu and Select
"Open Debug Dialog...". Hightligt PHP Script and press the "New" Button.
This panel will let you create the debug launch for your script and you
should be able to select XDebug as the PHP Debugger, the PHP Executable
you defined should then appear in the next field and you can then select
the PHP File you wish to debug.
I hope this helps.
But please raise a defect on bugzilla with what you have found
Cheers
Dave Kelsey
Re: Xdebug - breakpoints don't work [message #75874 is a reply to message #63722] Mon, 14 July 2008 10:52 Go to previous messageGo to next message
Opened bug and proposed patch in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=240140
> Alex
Re: Xdebug - breakpoints don't work [message #75954 is a reply to message #75874] Mon, 14 July 2008 22:22 Go to previous messageGo to next message
Originally posted by: euthanasia_waltz.yahoo.co.jp.localhost
The issue of this thread consisted in PDT 1.0.2 and it had been fixed on
1.0.3.
You should not mix up 1.0.x and 2.0(not yet released).
Re: Xdebug - breakpoints don't work [message #75968 is a reply to message #75954] Mon, 14 July 2008 23:59 Go to previous message
Oops, Sorry, this is my mistake.
Previous Topic:syntax error, unexpected 'version'
Next Topic:debugging questions
Current Time: Sat Jul 26 14:39:14 EDT 2025
Powered by FUDForum. Page generated in 0.24754 seconds
