Problems view always empty [message #63714] |
Thu, 12 May 2005 16:55  |
Originally posted by: arthur_allen.hotmail.com
I'm a newbie to eclipse (3.0.2) on suse 9.3 (download
eclipse-SDK-3.0.2-linux-gtk.zip) and java sdk 1.4..
I'm working through the java tutorial, and finding that errors
are not being logged in the problems view, nor in the task view.
They are however being flagged with icons as expected, and when I hover
over
a problem spot the error message appears.
Could this be a 3.0.2 issue, and should I try 3.0.1 instead. This is a real
killer for me.
Thanks, A.
My config follows:
** Date: 5/12/05 1:43 PM
*** Platform Details:
*** System properties:
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M200503110845
eclipse.commands=-os
linux
-ws
gtk
-arch
x86
-showsplash
/home/aallen/eclipse/eclipse -showsplash 600
-exitdata
/home/aallen/eclipse/eclipse -exitdata 260002
-vm
/usr/bin/java
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1115924748878
eclipse.vm=/usr/bin/java
eclipse.vmargs=-cp
/home/aallen/eclipse/startup.jar
org.eclipse.core.launcher.Main
eof=eof
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/home/aallen/eclipse/startup.jar
java.class.version=48.0
java.endorsed.dirs=/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre/ lib/endorsed
java.ext.dirs=/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre/lib/e xt
java.home=/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre
java.io.tmpdir=/tmp
java.library.path=/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre/l ib/i386/client:/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre/lib/ i386:/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre/../lib/i386
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.4.2_06-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.4
java.util.prefs.PreferencesFactory=java.util.prefs.FileSyste mPreferencesFactory
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.4.2_06
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.4.2_06-b03
line.separator=
org.eclipse.jdt.debug.ui.scrapbookActive=false
org.osgi.framework.executionenvironment=
org.osgi.framework.language=en
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.11.4-20a-default
org.osgi.framework.processor=i386
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.2.0
org.xml.sax.driver=org.apache.crimson.parser.XMLReaderImpl
os.arch=i386
os.name=Linux
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=/home/aallen/eclipse/configuration/org.ecli pse.osgi/bundles
osgi.configuration.area=file:/home/aallen/eclipse/configurat ion/
osgi.framework=file:/home/aallen/eclipse/plugins/org.eclipse .osgi_3.0.1/
osgi.framework.beginningstartlevel=1
osgi.framework.version=3.0.0
osgi.frameworkClassPath=core.jar, console.jar, osgi.jar, resolver.jar,
defaultAdaptor.jar, eclipseAdaptor.jar
osgi.install.area=file:/home/aallen/eclipse/
osgi.instance.area=file:/home/aallen/workspace/
osgi.logfile=/home/aallen/workspace/.metadata/.log
osgi.manifest.cache=/home/aallen/eclipse/configuration/org.e clipse.osgi/manifests
osgi.nl=en_US
osgi.os=linux
osgi.splashLocation=/home/aallen/eclipse/plugins/org.eclipse .platform_3.0.2/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.ws=gtk
path.separator=:
sun.arch.data.model=32
sun.boot.class.path=/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre /lib/rt.jar:/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre/lib/i18 n.jar:/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre/lib/sunrsasig n.jar:/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre/lib/jsse.jar: /usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre/lib/jce.jar:/usr/li b/jvm/java-1.4.2-sun-1.4.2.06/jre/lib/charsets.jar:/usr/lib/ jvm/java-1.4.2-sun-1.4.2.06/jre/classes
sun.boot.library.path=/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/j re/lib/i386
sun.cpu.endian=little
sun.cpu.isalist=
sun.io.unicode.encoding=UnicodeLittle
sun.java2d.fontpath=
sun.os.patch.level=unknown
user.country=US
user.dir=/home/aallen
user.home=/home/aallen
user.language=en
user.name=aallen
user.timezone=US/Mountain
vendor=Apache Software Foundation
vendor-url=http://xml.apache.org/xalan-j
version=2.4.1
*** Features:
org.eclipse.jdt (3.0.2) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.0.2) "Eclipse Java Development Tools SDK"
org.eclipse.pde (3.0.2) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.0.2) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.0.2) "Eclipse Platform"
org.eclipse.platform.source (3.0.2) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.sdk (3.0.2) "Eclipse Project SDK"
*** Plug-in Registry:
org.apache.ant (1.6.2) "Apache Ant"
org.apache.lucene (1.4.3) "Apache Lucene"
org.eclipse.ant.core (3.0.0) "Ant Build Tool Core"
org.eclipse.ant.ui (3.0.2) "Ant UI"
org.eclipse.compare (3.0.0) "Compare Support"
org.eclipse.core.boot (3.0.0) "Core Boot"
org.eclipse.core.expressions (3.0.0) "Expression Language"
org.eclipse.core.filebuffers (3.0.1) "File Buffers"
org.eclipse.core.resources (3.0.1) "Core Resource Management"
org.eclipse.core.resources.linux (3.0.0) "Core Resource Management Linux
Fragment"
org.eclipse.core.runtime (3.0.2) "Core Runtime"
org.eclipse.core.runtime.compatibility (3.0.0) "Core Runtime Plug-in
Compatibility"
org.eclipse.core.variables (3.0.0) "Core Variables"
org.eclipse.debug.core (3.0.2) "Debug Core"
org.eclipse.debug.ui (3.0.2) "Debug UI"
org.eclipse.help (3.0.0) "Help System Core"
org.eclipse.help.appserver (3.0.0) "Help Application Server"
org.eclipse.help.base (3.0.2) "Help System Base"
org.eclipse.help.ide (3.0.0) "Help System IDE"
org.eclipse.help.ui (3.0.2) "Help System UI"
org.eclipse.help.webapp (3.0.2) "Help System Webapp"
org.eclipse.jdt.core (3.0.2) "Java Development Tools Core"
org.eclipse.jdt.debug (3.0.2) "JDI Debug Model"
org.eclipse.jdt.debug.ui (3.0.2) "JDI Debug UI"
org.eclipse.jdt.doc.isv (3.0.1) "Eclipse JDT Plug-in Developer Guide"
org.eclipse.jdt.doc.user (3.0.1) "Eclipse Java Development User Guide"
org.eclipse.jdt.junit (3.0.1) "Java Development Tools JUnit support"
org.eclipse.jdt.junit.runtime (3.0.2) "Java Development Tools JUnit
runtime support"
org.eclipse.jdt.launching (3.0.2) "Java Development Tools Launching
Support"
org.eclipse.jdt.ui (3.0.2) "Java Development Tools UI"
org.eclipse.jface (3.0.2) "JFace"
org.eclipse.jface.text (3.0.2) "JFace Text"
org.eclipse.ltk.core.refactoring (3.0.1) "Refactoring Core"
org.eclipse.ltk.ui.refactoring (3.0.1) "Refactoring UI"
org.eclipse.osgi (3.0.1) "OSGi System Bundle"
org.eclipse.osgi.services (3.0.0) "OSGi Release 3 Services"
org.eclipse.osgi.util (3.0.0) "OSGi R3 Utility Classes"
org.eclipse.pde (3.0.1) "Eclipse Plug-in Development Environment"
org.eclipse.pde.build (3.0.1) "Plug-in Development Environment Build
Support"
org.eclipse.pde.core (3.0.2) "Plug-in Development Core"
org.eclipse.pde.doc.user (3.0.0) "Eclipse Plug-in Development User Guide"
org.eclipse.pde.junit.runtime (3.0.0) "PDE JUnit Plug-in Test"
org.eclipse.pde.runtime (3.0.1) "Plug-in Development Environment Runtime"
org.eclipse.pde.ui (3.0.2) "Plug-in Development UI"
org.eclipse.platform.doc.isv (3.0.1) "Eclipse Platform Plug-in Developer
Guide"
org.eclipse.platform.doc.user (3.0.1) "Eclipse Workbench User Guide"
Resources"
org.eclipse.platform.source.linux.gtk.x86 (3.0.2) "Eclipse Platform
Plug-in Developer Resources"
org.eclipse.search (3.0.1) "Search Support"
org.eclipse.swt (3.0.2) "Standard Widget Toolkit"
org.eclipse.swt.gtk (3.0.2) "Standard Widget Toolkit for GTK 2.0"
org.eclipse.team.core (3.0.0) "Team Support Core"
org.eclipse.team.cvs.core (3.0.1) "CVS Team Provider Core"
org.eclipse.team.cvs.ssh (3.0.0) "CVS SSH Core"
org.eclipse.team.cvs.ssh2 (3.0.0) "CVS SSH2"
org.eclipse.team.cvs.ui (3.0.1) "CVS Team Provider UI"
org.eclipse.team.ui (3.0.1) "Team Support UI"
org.eclipse.text (3.0.1) "Text"
org.eclipse.tomcat (4.1.30) "Tomcat Wrapper"
org.eclipse.ui (3.0.2) "Eclipse UI"
org.eclipse.ui.cheatsheets (3.0.1) "Cheat Sheets"
org.eclipse.ui.console (3.0.0) "Console"
org.eclipse.ui.editors (3.0.1) "Default Text Editor"
org.eclipse.ui.externaltools (3.0.1) "External Tools"
org.eclipse.ui.forms (3.0.0) "Eclipse Forms"
org.eclipse.ui.ide (3.0.2) "Eclipse IDE UI"
org.eclipse.ui.intro (3.0.2) "Intro Plugin"
org.eclipse.ui.presentations.r21 (3.0.1) "R21 Presentation Plug-in"
org.eclipse.ui.views (3.0.0) "Views"
org.eclipse.ui.workbench (3.0.2) "Workbench"
org.eclipse.ui.workbench.compatibility (3.0.0) "Workbench Compatibility"
org.eclipse.ui.workbench.texteditor (3.0.1) "Text Editor Framework"
org.eclipse.update.configurator (3.0.0) "Install/Update Configurator"
org.eclipse.update.core (3.0.2) "Install/Update Core"
org.eclipse.update.core.linux (3.0.1) "Install/Update Core for Linux"
org.eclipse.update.scheduler (3.0.1.1) "Automatic Updates Scheduler"
org.eclipse.update.ui (3.0.1.1) "Install/Update UI"
org.junit (3.8.1) "JUnit Testing Framework"
*** User Preferences:
#Thu May 12 13:43:59 MDT 2005
/instance/org.eclipse.jdt.ui/hoverModifierMasks=org.eclipse. jdt.ui.BestMatchHover;0;org.eclipse.jdt.internal.debug.ui.Ja vaDebugHover;0;org.eclipse.jdt.ui.ProblemHover;0;org.eclipse .jdt.ui.JavadocHover;0;org.eclipse.jdt.ui.JavaSourceHover;26 2144;org.eclipse.jdt.ui.AnnotationHover;0;
@org.eclipse.team.ui=3.0.1
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Mo nospace|10|0|GTK|1|;
/instance/org.eclipse.ui/showIntro=false
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=6
@org.eclipse.ui=3.0.2
/instance/org.eclipse.jdt.ui/semanticHighlighting.enabled=tr ue
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.templat es_migrated=true
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 13,1115848104774 "
defaultVMConnector\="">\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\n<vm
id\="1115848104774" name\="java-1.4.2"
path\="/usr/lib/jvm/java-1.4.2-sun-1.4.2.06"
javadocURL\="http\://java.sun.com/j2se/1.4.2/docs/api"/>\n</vmType>\n</vmSettings>\n
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRC=/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/src.z ip
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/instance/org.eclipse.help.base/default_browser=org.eclipse. help.base.custombrowser
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_LIB=/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre/l ib/rt.jar
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.help.base/custom_browser_path=firefox %1
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
version\="1.0" encoding\="UTF-8"?>\n<templates/>
@org.eclipse.jdt.ui=3.0.2
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRCROOT=
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time =false
/instance/org.eclipse.jdt.ui/hoverModifiers=org.eclipse.jdt. ui.BestMatchHover;0;org.eclipse.jdt.internal.debug.ui.JavaDe bugHover;\!0;org.eclipse.jdt.ui.ProblemHover;\!0;org.eclipse .jdt.ui.JavadocHover;\!0;org.eclipse.jdt.ui.JavaSourceHover; Ctrl;org.eclipse.jdt.ui.AnnotationHover;\!0;
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.JUnit|org.eclipse.jdt.launching.JRE_CONTAINER= <?xml
version\="1.0" encoding\="UTF-8"?>\n<classpath>\n<classpathentry
sourcepath\="/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/src.zip" kind\="lib"
path\="/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre/lib/rt.jar"/ >\n<classpathentry
path\="/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre/lib/sunrsasign.jar "/>\n<classpathentry
path\="/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre/lib/jsse.jar "/>\n<classpathentry
path\="/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre/lib/jce.jar "/>\n<classpathentry
path\="/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre/lib/charsets.jar "/>\n<classpathentry
kind\="lib"
path\="/usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre/lib/ext/dnsns.jar "/>\n<classpathentry
kind\="lib"
path\=" /usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre/lib/ext/sunjce_prov ider.jar "/>\n<classpathentry
kind\="lib"
path\=" /usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre/lib/ext/ldapsec.jar "/>\n<classpathentry
kind\="lib"
path\=" /usr/lib/jvm/java-1.4.2-sun-1.4.2.06/jre/lib/ext/localedata. jar "/>\n</classpath>\n
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.visibilityCheck=enabled
/instance/org.eclipse.jdt.ui/Refactoring.ErrorPage.severityT hreshold=2
@org.eclipse.help.base=3.0.2
/instance/org.eclipse.jdt.ui/fontPropagated=true
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
file_export_version=3.0
@org.eclipse.jdt.launching=3.0.2
@org.eclipse.jdt.core=3.0.2
*** Update Manager Log:
Configuration=Wed May 11 16:29:52 MDT 2005
Is current configuration=true
FUDForum. Page generated in 0.09861 seconds
