Re: Running ETL examples [message #632806 is a reply to message #632690] |
Thu, 14 October 2010 09:56 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Henning,
I'm afraid I can't reproduce this on my Mac. I've checked out the two
projects, ran the launch.xml ANT file and everything worked as expected.
Are you using the stable or the interim version of Epsilon?
Dimitris
Steffen Zschaler wrote:
> Hi Henning,
> I believe, Eclipse tends to interpret absolute paths without the file:
> protocol as URIs relative to the workspace. So it would have searched
> for a project Users with a folder henning/... in it, which obviously did
> not exist. The file: protocol tells it, I believe, to take seriously the
> fact that this is an absolute URI.
> Cheers,
> Steffen
> On 13/10/2010 21:35, Henning wrote:
>> Yes I did check that option and the projects are both located in the
>> workspace. I was able to resolve this error by changing the
>> epsilon.loadModel parameter modelFile to:
>> <epsilon.loadModel name="Tree" type="EMF">
>> <parameter name="modelFile" value="
>> file:/Users/henning/Documents/workspaces/diplom/org.eclipse.
>> epsilon.examples.tree2graph/tree.model "/>
>> I tried this because of
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=285559 and seemed to
>> solve this problem even though it is supposed to be fixed since 0.8.7
>> Is this the indented usage of the parameter?
>> Greetings from Germany,
>> Henning
FUDForum. Page generated in 0.04383 seconds
