Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Teneo - I loose my EObject fields
Teneo - I loose my EObject fields [message #63706] |
Tue, 05 December 2006 03:10  |
Originally posted by: mat.loo.gmail.com
I have trouble when adding an EObject to a container (and I think in using
EMF with JPOX in a whole...).
When I perform my AddCommand, undo, redo, undo, redo... Everything works
fine (At this time, I do not use any Teneo facility, since my new EObject
was not stored in any database and only exists in my EMF model instance).
Then I undo and I save.
Then, when I redo, looking at my AddCommand.doRedo, I see my newly created
EObject has all its fields reseted ! (and then, when trying to to store to
the database raises an error because of Diagnosicts on required fields)
Any suggestion ?
Thx
Mat
Re: Teneo - I loose my EObject fields [message #63775 is a reply to message #63706] |
Tue, 05 December 2006 08:54   |
Are the fields already reset before the redo?
The save should not change the object itself, only for isMany features. The list implementation in
the isMany feature is replaced by a persistable list to support lazy loading. Primitive fields
should not be changed.
Can you debug to get more insight in what the redo does (where do the reseted/default values come from)?
gr. Martin
Mat Lo wrote:
> using EMF with JPOX in a whole...).
> EObject was not stored in any database and only exists in my EMF model
> instance).
> created EObject has all its fields reseted ! (and then, when trying to
> to store to the database raises an error because of Diagnosicts on
> required fields)
> Any suggestion ?
> Thx
> Mat
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo - I loose my EObject fields [message #63890 is a reply to message #63868] |
Wed, 06 December 2006 05:36   |
Hi Mat,
Can you debug some further (into the save action) to see what happens? I currently can not say where
this behavior is coming from.
gr. Martin
Mat Lo wrote:
>> Hi
> Yes, I put my breakpoint just before the redo of AddCommand executes and
> the field of my EObject are already deleted.
> Note that the id (Object id, not the OID) is the same from the beginning
> of the first Add and remains the same till it fields are reseted.
> So, it is not another EObject that is created but really "mine", whose
> fields are reseted.
>> features. The
> My feature is an EAttribute, so I guess nothing should interfere...
> I put a breakpoint in a (generated) setters of my EObject and code never
> goes there. So I guess a "jdoSetxxx" method is called (only a thought !).
> When I use the same code in XMI context, everything works great...
> Maybe the problem comes from a bad configuration of Teneo ?
> Is there any annotation I should put on my EAttributes (like oneToMany
> for EReference for instance) ?
>> gr. Martin
> Thx
The Netherlands
Re: Teneo - I loose my EObject fields [message #64288 is a reply to message #63890] |
Mon, 11 December 2006 11:53   |
I don't know if it is linked to my problem, but I found the following
behaviour that surprises me.
In EContainerRepairControl (of org.eclipse.emf.teneo), the repair
functionnality seems to be strange.
Some times, I arrive in the return of the following repair method:
if (!childClass.isAssignableFrom(child.getClass())) {
return; // not handled by this container
In this case, I come from repair where :
for (int i = 0; i < repairList.size(); i++) {
RepairControl repairControl = (RepairControl) repairList.get(i);
if (repairControl.getFeatureID() == correctedFeatureID) {
repairControl.repair((InternalEObject) owner, (InternalEObject) child);
return;
But, in this case, I have correctedFeatureID ==
repairControl.getFeatureID() (obviously !) but it seems to be false
because we are comparing the id of the feature to the id of the opposite
feature in the opposite object. And that's why, some times, when a feature
is a TwoWayContainer (that is when the EReference is a container AND has
an eOpposite) the first repair returns because the expected child class is
not the wanted (!childClass.isAssignableFrom(child.getClass())).
To me, correctedFeatureID should not be initialised like this :
correctedFeatureID = ((EReference) estruct).getEOpposite().getFeatureID()
but like this :
correctedFeatureID = ((EReference) estruct).getFeatureID()
I guess this is not the "real good" solution but I show it to make myself
as clear as possible.
What do you think of this ?
thx
Re: Teneo - I loose my EObject fields [message #64311 is a reply to message #64288] |
Wed, 13 December 2006 03:35   |
Hi Mat,
The correctedFeatureID should be the id of the feature which is in the contained object refering to
the container. For 2-way container the repairlist is built using this constructor:
private static class TwoWayContainer extends RepairControl {
/** Constructor */
TwoWayContainer(EReference containerReference, EReference toContainer) {
super(containerReference, toContainer.getFeatureID());
The feature id is the feature pointing to the container, the repair method is called with the
container feature and to get the correct repair action the featureid of the other side needs to be
determined. So afaics this is correct.
However, what I don't understand directly is why it returns here:
Can you debug to see what the childClass and child classes are?
gr. Martin
Mat Lo wrote:
> repairList.get(i);
> return;
> feature is a TwoWayContainer (that is when the EReference is a container
> AND has an eOpposite) the first repair returns because the expected
> child class is not the wanted
> but like this :
> myself as clear as possible.
> thx
The Netherlands
Re: Teneo - I loose my EObject fields [message #64566 is a reply to message #64311] |
Fri, 15 December 2006 05:17   |
I think I have it !
All I said about eOpposite id seems to be wrong... (I don't know why I
found this but, anyway...).
The point seems to be:
if by any chance, I have, in my Ecore mode, 2 contained EObjects that have
the same id for the feature that links them to their container, sometimes
it works, sometimes not depending on the order the repairList is built.
For example :
Container
|_Child1
|_Child2
Child1
|_xxx
|_xxx
|_xxx
|_Container
Child2
|_xxx
|_xxx
|_xxx
|_Container
The fact that the feature to the Container is 3 in both cases make the
repair lose itself. And then, depending on the repairList, sometimes, when
trying to repair the link Container->Child1, it may arrive in the final
Repair with class of Child2.
For me, the solution is the move some code like this :
repairList.get(i);
/////CHANGE && repairControl.childClass.isAssignableFrom(child.getClass())
return;
And then, in repairControl.repair the
childClass.isAssignableFrom(child.getClass()) is not needed anymore
The test has to be done earlier because otherwise, the call to
repairControl.repair may return doing nothing and the for loop always
returns after repairControl.repair.
What do you think ?
Re: Teneo - I loose my EObject fields [message #64799 is a reply to message #64566] |
Mon, 18 December 2006 16:20   |
Hi Mat,
My reply took a while because of busy work schedules.
Thanks, this seems to be the issue, this is/was for sure a very hidden issue.
I have changed it as you proposed and committed it. This will be in the next release (next week).
gr. Martin
Mat Lo wrote:
> I think I have it !
> have the same id for the feature that links them to their container,
> sometimes it works, sometimes not depending on the order the repairList
> is built.
> For example :
> Container
> |_Child1
> |_Child2
> Child1
> |_xxx
> |_xxx
> |_xxx
> |_Container
> Child2
> |_xxx
> |_xxx
> |_xxx
> |_Container
> when trying to repair the link Container->Child1, it may arrive in the
> final Repair with class of Child2.
> repairList.get(i);
> return;
> What do you think ?
The Netherlands
Re: Teneo - I loose my EObject fields [message #596539 is a reply to message #63706] |
gr. Martin
Mat Lo wrote:
> instance).
> required fields)
> Any suggestion ?
> Thx
> Mat
The Netherlands
Re: Teneo - I loose my EObject fields [message #596588 is a reply to message #63775] |
Wed, 06 December 2006 02:23  |
>Hi
fields are reseted.
Is there any annotation I should put on my EAttributes (like oneToMany for
> gr. Martin
Thx
Re: Teneo - I loose my EObject fields [message #596596 is a reply to message #63868] |
Hi Mat,
gr. Martin
Mat Lo wrote:
>> Hi
> fields are reseted.
>> features. The
>> gr. Martin
> Thx
The Netherlands
Re: Teneo - I loose my EObject fields [message #596770 is a reply to message #63890] |
return;
but like this :
thx
Re: Teneo - I loose my EObject fields [message #596778 is a reply to message #64288] |
Hi Mat,
/** Constructor */
gr. Martin
Mat Lo wrote:
> repairList.get(i);
> return;
> but like this :
> thx
The Netherlands
Re: Teneo - I loose my EObject fields [message #596931 is a reply to message #64311] |
I think I have it !
For example :
Container
|_Child1
|_Child2
Child1
|_xxx
|_xxx
|_xxx
|_Container
Child2
|_xxx
|_xxx
|_xxx
|_Container
repairList.get(i);
return;
What do you think ?
Re: Teneo - I loose my EObject fields [message #597059 is a reply to message #64566] |
Hi Mat,
gr. Martin
Mat Lo wrote:
> I think I have it !
> is built.
> For example :
> Container
> |_Child1
> |_Child2
> Child1
> |_xxx
> |_xxx
> |_xxx
> |_Container
> Child2
> |_xxx
> |_xxx
> |_xxx
> |_Container
> repairList.get(i);
> return;
> What do you think ?
The Netherlands
Current Time: Tue Jul 15 13:19:32 EDT 2025
Powered by FUDForum. Page generated in 0.16209 seconds
