antlr/TokenStream error [message #63631] |
Wed, 10 October 2007 03:36  |
Hello all,
i have this error when i try the Author2Person tutorial of ATL. I have
found mails that say that the reason is antlr.jar is missing in the engine
plugin so i put the (renamed) last antlr.jar in
org.eclipse.m2m.atl.engine_2.0.0 and i have allways the same error
here is the stack trace
java.lang.NoClassDefFoundError: antlr/TokenStream
org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:244)
org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:201)
org.atl.engine.injectors.ebnf.EBNFInjector2.inject(EBNFInjec tor2.java:78)
org.eclipse.gmt.am3.dsls.km3.KM3Projector.getKM3FromFile(KM3 Projector.java:236)
org.eclipse.gmt.am3.dsls.km3.KM3Projector.getEMFKM3FromFile( KM3Projector.java:216)
at org.eclipse.gmt.am3.dsls.km3.actions.KM32Ecore$1.run(KM32Eco re.java:58)
any ideas ?
Vincent
Re: [ATL] Re: antlr/TokenStream error [message #63829 is a reply to message #63808] |
Fri, 12 October 2007 04:37   |
William Piers wrote:
> Hello,
> Perhaps is your Eclipse corrupted, or not up to date. Could you try to
> launch it with the -clean option ?
i just tried this but it change nothing...
Vincent
>>> OK, so how did you install ATL ?
>>> In the last version (see : http://www.eclipse.org/m2m/atl/download/)
>>> there is no need to manually install antlr.jar because only
>>> antlr-runtime.jar is required, and is included into ATL.
>>> Installing ATL via update-site, or binaries build should work.
>> I have tried both :(
>> Vincent
>>> Regards
>>>> Hello,
>>>> in fact i placed the antlr.jar file in the two directories (just in
>> Vincent
>>> Regards
>>>> Hello,
Re: [ATL] Re: antlr/TokenStream error [message #64053 is a reply to message #63851] |
Mon, 15 October 2007 09:37  |
> It is strange, it works fine for me...
> Could you tell please me if you use Eclipse 3.3 and EMF 2.3, and send me
> your KM3 file ?
> To avoid this error, you can also directly use ecore files instead of
> KM3, i.e. create the metamodel using EMF editor.
>>> Hello,
>> Hello,
>> Vincent
>>>> Vincent
>>>>> Regards
>>>>>> Hello,
>>>> Vincent
>>>>> Regards
>>>>>> Hello,
i just try the same conf on a pc windows ad it works (all the precedent
tests were on a MacBook with mac OS X) maybe there is something there ?
Vincent
FUDForum. Page generated in 0.03500 seconds
