Home » Eclipse Projects » Plugin Development Environment (PDE) » 'Cloud' PDE style on our product in 3.5RC2
'Cloud' PDE style on our product in 3.5RC2 [message #63597] Thu, 28 May 2009 15:10 Go to next message
I am trying to apply the 'Cloud' PDE approach demonstrated here by Niefer:
http://aniefer.blogspot.com/2009/03/building-p2-rcp-products -in-eclipse.html
to our RCP Product on SDK 3.5RC2.
* Our Product is Feature-based.
* I've removed all our plugins from the feature save our branding plugin.
* I use Niefers build.properties and buildProduct.xml.
* The Product Dependencies are as follows:
[our feature]
org.eclipse.rcp
org.eclipse.equinox.p2.user.ui
org.eclipse.platform
org.eclipse.cdt.platform
org.eclipse.cvs
org.eclipse.help
org.eclipse.equinox.executable
* I've stripped out all Start level items and VM arguments from the
Product Configuration panels.
The console shows the following runDirector error during build:
runDirector:
[echo] !SESSION 2009-05-28 14:08:29.161
[echo] eclipse.buildId=I20090522-1710
[echo] java.version=1.6.0_07
[echo] java.vendor=Sun Microsystems Inc.
[echo] BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
[echo] Framework arguments: -application
org.eclipse.equinox.p2.director.app.application --launcher.suppressErrors
-flavor ${p2.flavor} -installIU com.analog.visualdsp.product -version
1.0.0.200905281407 -p2.os win32 -p2.ws win32 -p2.arch x86 -roaming
-profile profile -profileProperties
org.eclipse.update.install.features=true -metadataRepository
file:C:\eclipse\VisualDSP_3.5_3_feature\workspace\builder/bu ildDirectory/buildRepo
-artifactRepository
-destination
C:\eclipse\VisualDSP_3.5_3_feature\workspace\builder/buildDi rectory/tmp/eclipse
-bundlepool
[echo] Command-line arguments: -application
-consoleLog -flavor ${p2.flavor} -installIU com.analog.visualdsp.product
-version 1.0.0.200905281407 -p2.os win32 -p2.ws win32 -p2.arch x86
-roaming -profile profile -profileProperties
-artifactRepository
-destination
-bundlepool
[echo]
[echo] !ENTRY org.eclipse.equinox.p2.directorywatcher 4 0
2009-05-28 14:08:51.464
[echo] !MESSAGE The installable unit
org.eclipse.ui.win32.translated_host_properties is missing the filename
property.
[echo] This application is deprecated. Please use the
org.eclipse.equinox.p2.director application.
[echo] Installing com.analog.visualdsp.product 1.0.0.200905281407.
[echo] Operation completed in 31293 ms.
1) The runDirector error "missing filename property" looks like Bugzilla
275274. Is it harmless? Workaround?
2) The product contains the expected files [our product].exe and [our
product].ini, but also an extra file 'launcher.exe'. How do we avoid that?
3) Help, About, Installation, Features, shows two entries for each
Feature. This seems like Bugzilla 275523. Harmless? Workaround?
Thanks for any insight into these issues,
MSacarny
Re: 'Cloud' PDE style on our product in 3.5RC2 [message #63824 is a reply to message #63597] Mon, 01 June 2009 15:18 Go to previous message
that?
launcher.exe is coming from org.eclipse.equinox.executable, you don't
need to add this to your .product file. This feature contains unbranded
executables, due to a change in how rootfiles from features are
contributed to product, you shouldn't include this feature directly.
PDE/Build will automatically brand the executables for your product and
include them for you, which is how you got the product.exe.
I'm not sure about (1) and (3).
-Andrew
> * Our Product is Feature-based. * I've removed all our plugins from the
> * I use Niefers build.properties and buildProduct.xml. * The Product
> [our feature]
> org.eclipse.rcp
> org.eclipse.cvs
> org.eclipse.help
> runDirector:
> --launcher.suppressErrors -flavor ${p2.flavor} -installIU
> com.analog.visualdsp.product -version 1.0.0.200905281407 -p2.os win32
> -p2.ws win32 -p2.arch x86 -roaming -profile profile -profileProperties
> -artifactRepository
> -destination
> -bundlepool
> --launcher.suppressErrors -consoleLog -flavor ${p2.flavor} -installIU
> -artifactRepository
> -destination
> -bundlepool
> [echo] [echo] !ENTRY
> org.eclipse.equinox.p2.directorywatcher 4 0 2009-05-28 14:08:51.464
> property.
> MSacarny
Re: 'Cloud' PDE style on our product in 3.5RC2 [message #598019 is a reply to message #63597] Mon, 01 June 2009 15:18 Go to previous message
that?
-Andrew
> [our feature]
> org.eclipse.rcp
> org.eclipse.cvs
> org.eclipse.help
> runDirector:
> -artifactRepository
> -destination
> -bundlepool
> -artifactRepository
> -destination
> -bundlepool
> property.
> MSacarny
Previous Topic:'Cloud' example build on 3.5RC2
Next Topic:Basic update site maintenance question
Current Time: Sun Aug 31 22:39:10 EDT 2025
Powered by FUDForum. Page generated in 0.05603 seconds
