Home » Eclipse Projects » GEF » Using ChopBoxAnchor in GEF 0206
Using ChopBoxAnchor in GEF 0206 [message #63576] Sat, 08 February 2003 12:23 Go to next message
I download GEF/Logic Editor 0206 and use Eclipse M5.
And i modify a figure (a child of NodeFigure) to use ChopBoxAnchor instead
of FixedConnectionAnchor.
So I just create ChopboxAnchor in the constructor and return that in all the
getConnectionAnchor methods.
But the result connection are not connecting the two MyFigure figures, they
are somewhere in the diagram. Can someone please let me know what did I do
wrong? I use the same logic in the older example (not build 0206), it works.
Thank for any help.
public MyFigure() {
private ConnectionAnchor connectionAnchor = new ChopboxAnchor(this);
public ConnectionAnchor connectionAnchorAt(Point p) {
return connectionAnchor;
public ConnectionAnchor getConnectionAnchor(String terminal) {
public String getConnectionAnchorName(ConnectionAnchor c) {
return "A";
public ConnectionAnchor getSourceConnectionAnchorAt(Point p) {
public ConnectionAnchor getTargetConnectionAnchorAt(Point p) {
Re: Using ChopBoxAnchor in GEF 0206 [message #63599 is a reply to message #63576] Sat, 08 February 2003 13:58 Go to previous messageGo to next message
What I am seeing is After chose the "connection " tool, and I click in on
one of MyFigure, a plug icon shows up,
and I click on it, but it does not draw any line as I move my mouse (I see
this when I click on a CircuitFigure, but not MyFigure) and then I move the
plug icon to another MyFigure and click on it, no line is drawn but the tool
switch to "selection" tool.
Can someone please let me with this problem?
"yinglcs" <yinglcs@netscape.com> wrote in message
news:b23d12$9uh$1@rogue.oti.com...
the
they
works.
> Thank for any help.
> public MyFigure() {
> return "A";
Re: Using ChopBoxAnchor in GEF 0206 [message #63688 is a reply to message #63576] Sat, 08 February 2003 17:09 Go to previous messageGo to next message
There is a bug in BendpointConnectionRouter (actually, in PrecisionPoint)
that is fixed in the CVS stream. You might be seeing something related to
this. Try bending a connection and moving it in the Logic example. If this
is broken, then you aren't doing anything wrong. The next build will fix
this, or you can try connecting to the CVS server if you are brave enough.
BTW, how are you able to compile GEF on M5 given the bug in the JDT
compiler?
the
they
works.
> Thank for any help.
> public MyFigure() {
> return "A";
Re: Using ChopBoxAnchor in GEF 0206 [message #63711 is a reply to message #63688] Sat, 08 February 2003 17:19 Go to previous messageGo to next message
Randy,
Thanks for your response.
I try your suggestion, but I am able to bend the line if I draw a connection
between 2 LEDs.
But if I draw a connection between 2 MyFigure (the rectangles), the
connection is not connected at all. Only a small black traingle show up in
the Editor. (Please refer to the attached Screen shot).
For the compile problem I have yesterday, I just go to the directiory of my
project, remove all *.class file, and refresh the project and then rebuild
the project. The project went away.
Thank you.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b23tq8$i05$1@rogue.oti.com...
this
> compiler?
instead
> the
> they
do
> works.
> > Thank for any help.
> > public MyFigure() {
> > return "A";
  • Attachment: untitled1.jpg
    (Size: 68.99KB, Downloaded 138 times)
Re: Using ChopBoxAnchor in GEF 0206 [message #63779 is a reply to message #63711] Sun, 09 February 2003 13:41 Go to previous message
Randy,
Could you please tell me if it is a problem with the latest GEF or there is
a problem with my code.
Thank you.
news:b23ud2$i8f$1@rogue.oti.com...
> Randy,
connection
> between 2 LEDs.
my
> Thank you.
PrecisionPoint)
to
> this
fix
enough.
> > compiler?
> instead
all
> > the
> > they
I
> do
> > works.
> > > Thank for any help.
> > > public MyFigure() {
> > > return "A";
Previous Topic:How to draw Transparent Figure has a shadow?
Next Topic:GEF build problem
Current Time: Sun Sep 07 19:45:06 EDT 2025
Powered by FUDForum. Page generated in 0.03332 seconds
