a Labell is never added to JPanel. Is that right? [message #63534] |
Thu, 30 September 2004 16:20  |
Eclipse-sdk-3.0.1-win32
EMF SDK 2.0.1
GEF SDK 3.0.1
VE SDK 1.0.1
Here is what I did
1) I created a "visual class" by clicking on the menu. The superclass was
javax.swing.JFrame
That created a JFrame with a JPanel according to the generated source code.
Why is a JPanel added?
2) Then I added with the mouse a JLabel to the JPanel but that is not
reflected in the generated source code. See below. Is that a fault?
If I save and close and reenter into eclipse, I can no longer see my label.
import javax.swing.JFrame;
import javax.swing.JLabel;
* Created on Sep 30, 2004
* TODO To change the template for this generated file go to
* Window - Preferences - Java - Code Style - Code Templates
* @author Administrator
* TODO To change the template for this generated type comment go to
public class FrameC extends JFrame {
private javax.swing.JPanel jContentPane = null;
private JLabel jLabel = null; //
@jve:decl-index=0:visual-constraint="162,6"
* This is the default constructor
public FrameC() {
super();
initialize();
* This method initializes this
* @return void
private void initialize() {
this.setSize(300,200);
this.setContentPane(getJContentPane());
this.setTitle("JFrame");
* This method initializes jContentPane
* @return javax.swing.JPanel
private javax.swing.JPanel getJContentPane() {
if(jContentPane == null) {
jContentPane = new javax.swing.JPanel();
jContentPane.setLayout(new java.awt.BorderLayout());
return jContentPane;
* This method initializes jLabel
* @return javax.swing.JLabel
private JLabel getJLabel() {
if (jLabel == null) {
jLabel = new JLabel();
jLabel.setText("JLabel");
jLabel.setSize(88, 16);
return jLabel;
David Bo Jensen
Re: a Labell is never added to JPanel. Is that right? [message #600269 is a reply to message #63534] |
Thu, 30 September 2004 16:49  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
David Bo Jensen wrote:
> EMF SDK 2.0.1
> GEF SDK 3.0.1
> VE SDK 1.0.1
> Here is what I did
> javax.swing.JFrame
Because JFrame's require a content pane. The JPanel is the content pane.
(Note: Currently we can't handle implicit children. In other words we
can't handle the fact that JFrame already has a content pane, so we need
to explicitly create one).
You didn't add it to the JPanel. It looks like you dropped it on the
freeform (the white area) and not the JPanel.
Rich Kulp
Re: a Labell is never added to JPanel. Is that right? [message #600276 is a reply to message #63558] |
Thu, 30 September 2004 17:00  |
label.
It is correct that the area is white, but during the whole process I see
nothing, but the white area. And then the jpanel which later disapears. Is
that right?
Re: a Labell is never added to JPanel. Is that right? [message #600290 is a reply to message #63580] |
No that is not right. When you create a subclass of JFrame, you should
at least see the JFrame on the white surface. Then inside the JFrame,
assuming it has been sized large enough, will be the content pane. The
content pane is typically gray. You would drop the JLabel there on the
gray content pane. If everything is white then something is wrong.
Rich Kulp
FUDForum. Page generated in 0.05944 seconds
