Re: can scope provider call sort of super and filter obtained matches? [message #630993 is a reply to message #630956] |
Tue, 05 October 2010 18:57 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Henrik,
strict validation and loose scoping is a common pattern to improve the
error messages. If you want to filter the proposals for cross references
in a generic way, feel free to override
AbstractJavaBasedContentProposalProvider.getProposalFactory( String,
ContentAssistContext)
and return your own subtype of the DefaultProposalCreator. Please note
that you should try to not resolve any proxies when you filter the
descriptions.
Hope that helps,
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 05.10.10 17:53, schrieb Henrik Rentz-Reichert:
> I just realized, it is not so easy.
> The ICompletionProposal doesn't give me the proposed EObject, only a
> String to be inserted...
> What is the proper way to treat this issue?
> Henrik
> Am 05.10.2010 17:20, schrieb Henrik Rentz-Reichert:
>> thanks for the hint! That works fine.
>> Now I encounter a more semantic problem:
>> If type A has a reference of type B in general any element of type B is
>> a valid object.
>> This is restricted only by my model semantics which is imposed e.g. by a
>> corresponding validation check.
>> If now my scope provider filters out invalid references in the semantic
>> sense I may see an error mark with a message "reference not found".
>> Strictly speaking this is not true since the reference is found but not
>> valid.
>> So what I would like to have is a general scope but a strict validation,
>> which is quite simple to achieve.
>> But my proposals on the other hand should contain only valid references.
>> Can I implement that along the lines of
>> http://www.eclipse.org/Xtext/documentation/latest/xtext.html #contentAssist
>> by calling the super class implementation with an acceptor delegating
>> only if the proposal is valid?
>> Thanks,
>> Henrik
>> Am 05.10.2010 11:28, schrieb Christian Dietrich:
>>> Hi,
>>> have a look at the simple arithmetics example. there is a sample
>>> implementation of a filtering scope.
>>> ~Christian
FUDForum. Page generated in 0.03765 seconds
