Home » Eclipse Projects » Eclipse Platform » Starting Eclipse linux gtk
Starting Eclipse linux gtk [message #63452] Thu, 05 June 2003 07:01 Go to next message
Originally posted by: andiger.gmx.de
I have problems starting eclipse...
I have SuSe Linux 8.2
i downloaded "eclipse-SDK-2.1-linux-gtk.zip"
starting eclipse I get this:
../eclipse
org.eclipse.swt.SWTException: Unsupported or unrecognized format
at org.eclipse.swt.SWT.error(SWT.java:2332)
at org.eclipse.swt.SWT.error(SWT.java:2262)
at org.eclipse.swt.internal.image.FileFormat.load(FileFormat.ja va:73)
at org.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java:1 24)
at org.eclipse.swt.graphics.ImageData.<init>(ImageData.java:311)
at org.eclipse.jface.resource.URLImageDescriptor.getImageData(U RLImageDescriptor.java:51)
at org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:118)
at org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:94)
at org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:83)
at org.eclipse.jface.action.ActionContributionItem$ImageCache.g etImage(ActionContributionItem.java:117)
at org.eclipse.jface.action.ActionContributionItem.updateImages (ActionContributionItem.java:719)
at org.eclipse.jface.action.ActionContributionItem.update(Actio nContributionItem.java:596)
at org.eclipse.jface.action.ActionContributionItem.fill(ActionC ontributionItem.java:302)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java :542)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java :454)
at org.eclipse.jface.action.MenuManager.fill(MenuManager.java:2 07)
at org.eclipse.jface.action.MenuManager.createMenuBar(MenuManag er.java:144)
at org.eclipse.jface.window.ApplicationWindow.configureShell(Ap plicationWindow.java:244)
at org.eclipse.ui.internal.WorkbenchWindow.configureShell(Workb enchWindow.java:578)
at org.eclipse.jface.window.Window.createShell(Window.java:350)
at org.eclipse.jface.window.Window.create(Window.java:301)
at org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1068)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:874)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1373)
at org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Thank You for any solutions
regards Andre Reiter
Re: Starting Eclipse linux gtk [message #63545 is a reply to message #63452] Thu, 05 June 2003 07:23 Go to previous messageGo to next message
problem solved :-)
thx to all
Andre
Re: Starting Eclipse linux gtk [message #63835 is a reply to message #63545] Thu, 05 June 2003 09:37 Go to previous message
Originally posted by: arnout.standaert.n-o-s-p-a-m.cit.kuleuven.ac.be
Andre Reiter <andiger@gmx.de> wrote:
> problem solved :-)
> thx to all
Could you please describe how you solved the problem? This is likely
to help other people out in the future by searching the newsgroups.
Wald
Previous Topic:Problem with my first update site
Next Topic:Announcement: New IBM Rational ClearQuest integration with Eclipse now available!
Current Time: Fri Jul 25 21:18:57 EDT 2025
Powered by FUDForum. Page generated in 0.03637 seconds
