Home » Modeling » M2T (model-to-text transformation) » com.sun.java.xml.ns.persistence.orm.OrmPackage
com.sun.java.xml.ns.persistence.orm.OrmPackage [message #63427] Wed, 01 July 2009 15:18 Go to next message
I had a functional Xpand workflow using Galileo-RC2. When I upgraded
yesterday, it started failing inside the Xpand template expansion with the
complaint:
ClassNotFoundException for com.sun.java.xml.ns.persistence.orm.OrmPackage
I've gone back and forth between the two Eclipse installs and tried to
insure that they are configured the same way. Has anyone else seen this
behavior?
--Rhett
Re: com.sun.java.xml.ns.persistence.orm.OrmPackage [message #63742 is a reply to message #63427] Mon, 06 July 2009 07:56 Go to previous message
Hi Rhett,
I'm sorry this is because there is an EPackage registered somewhere
(don't know from where it comes), where the corresponbding class is not
there. So there's only the extension-point.
In EMF index we made the fault to eagerly initialize every registered
Ecore package.
We've fixed this already in head and plan to have a maintenance release
(0.7.1) by July 17th.
In the meantime you could use the distro we provide at itemis, where we
have already fixed this issue.
Sorry for the inconvenience,
Sven
> the complaint:
> behavior?
> --Rhett
Previous Topic:Is it possible to reference data in a second model file via Xpand
Next Topic:Why does JET not re-create files on jet2java
Current Time: Wed Jul 30 16:13:32 EDT 2025
Powered by FUDForum. Page generated in 0.03848 seconds
