Home » Language IDEs » C / C++ IDE (CDT) » CDT installation error with Eclipse 2.0.2/Linux
CDT installation error with Eclipse 2.0.2/Linux [message #63413] Sun, 02 March 2003 11:41 Go to next message
Originally posted by: andy.piper.freeuk.com
I've got Eclipse 2.0.2 for Linux/GTK2 installed.
The 1.0.1 build of the CDT is showing up as in error when I look in the
Update Manager. "Show Status" reveals:
Plugin "org.eclipse.cdt.linux.gtk" version "1.0.1" referenced by this
feature is missing.
Included feature "org.eclipse.cdt_1.0.0" is missing.
Any ideas what is causing this?
Andy Piper - Farnborough, Hampshire (UK)
andy.piper@freeuk.com
http://www.andypiper.co.uk/
Re: CDT installation error with Eclipse 2.0.2/Linux [message #63508 is a reply to message #63413] Mon, 03 March 2003 15:34 Go to previous messageGo to next message
"Andy Piper" <andy.piper@freeuk.com> wrote in message
news:pan.2003.03.02.16.41.29.897486@freeuk.com...
| feature is missing.
Hi Andy,
I do not mean to be rude, but this has been answered a number of times in
this newsgroup.
You should be able to find it in a search from the Eclipse main website.
-Judy
Re: CDT installation error with Eclipse 2.0.2/Linux [message #63648 is a reply to message #63508] Mon, 03 March 2003 18:54 Go to previous messageGo to next message
> this newsgroup.
Not rude at all, I apologise for not checking - most unlike me - thanks
for the pointer.
Andy
Re: CDT installation error with Eclipse 2.0.2/Linux [message #63672 is a reply to message #63508] Mon, 03 March 2003 19:41 Go to previous messageGo to next message
> this newsgroup.
Forgive me, but I'm afraid the posts don't really resolve the problem
for me (and the search engine didn't prove to be very effective, I ended
up browsing the past newsgroup messages).
You've posted quite a detailed workaround but in the Linux case it doesn't
help. The Update Manager with "Show disabled features" shows the CDT for
Linux GTK but underneath it there is an entry "%featureName (not
installed)"
When I install the CDT it is enabled, but with a red cross; I've tried
disabling, restarting and re-enabling and it's now giving an error:
Error creating feature
" file:/home/andyp/eclipse/eclipse202/features/org.eclipse.cdt _1.0.1.jar "
[java.io.FileNotFoundException:
/home/andyp/eclipse/eclipse202/features/org.eclipse.cdt_1.0. 1.jar/feature.xml (No such file or directory)]
(actually this does match with the other reports)
Either way I'm not clear as to what the impact is here? It doesn't seem to
be an identical problem to the Windows install errors.
Re: CDT installation error with Eclipse 2.0.2/Linux [message #64124 is a reply to message #63672] Fri, 07 March 2003 09:59 Go to previous messageGo to next message
Originally posted by: nospam.nospam.com
I have the same problem on Linux.
I solved it by copying the features/org.eclipse.cdt_1.0.1 folder to
features/org.eclipse.cdt_1.0.1.jar.
I think this is safer than merely leaving the older CDT version in place.
Chris
news:pan.2003.03.04.00.40.57.659176@freeuk.com...
in
> > this newsgroup.
> installed)"
Re: CDT installation error with Eclipse 2.0.2/Linux [message #64146 is a reply to message #64124] Fri, 07 March 2003 18:32 Go to previous messageGo to next message
This seems to get rid of the error, but I no longer see the CDT referenced
anywhere in the Update perspective. The tooling seems to be there, though.
Re: CDT installation error with Eclipse 2.0.2/Linux [message #64479 is a reply to message #64124] Fri, 14 March 2003 11:28 Go to previous message
"Chris Trobridge" <nospam@nospam.com> wrote in message
news:b4ac7q$jt4$1@rogue.oti.com...
One question ... are you installing a newer version fo the CDT over an older
existing version?
If so please do not or you will get a corrupted installation.
You must completely remove all previous traces of the earlier version of
CDT.
-Judy
| Chris
| in
| > > this newsgroup.
website.
doesn't
| > installed)"
to
Previous Topic:Autosave source in CDT ?
Next Topic:Remote debugging development in CDT
Current Time: Mon Jul 21 21:55:13 EDT 2025
Powered by FUDForum. Page generated in 0.06555 seconds
