Home » Language IDEs » AspectJ » Exception: Unable to create this part due to an internal error. Reason for the failure: Editor could
Exception: Unable to create this part due to an internal error. Reason for the failure: Editor could [message #63398] Sun, 02 April 2006 11:53 Go to next message
Originally posted by: thf20022003.yahoo.com
Following the exercise1 from EclipseCon2006, I got the following exception
when I try to re-open the Answer.aj:
Java.lang.AbstractMethodError:
org.eclipse.ajdt.parserbridge.AJCompilationUnitStructureRequ estor.acceptImpo
rt(II[CZI)V
org.eclipse.ajdt.parserbridge.AJSourceElementParser.notifySo urceElementReque
stor(AJSourceElementParser.java:1052)
stor(AJSourceElementParser.java:710)
org.eclipse.ajdt.parserbridge.AJSourceElementParser.parseCom pilationUnit(AJS
ourceElementParser.java:1273)
org.eclipse.ajdt.core.javaelements.AJCompilationUnit.buildSt ructure(AJCompil
ationUnit.java:231)
at org.eclipse.jdt.internal.core.Openable.generateInfos(Openabl e.java:229)
org.eclipse.ajdt.core.javaelements.AJCompilationUnit.generat eInfos(AJCompila
tionUnit.java:179)
org.eclipse.jdt.internal.core.JavaElement.openWhenClosed(Jav aElement.java:50
3)
org.eclipse.jdt.internal.core.BecomeWorkingCopyOperation.exe cuteOperation(Be
comeWorkingCopyOperation.java:38)
org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java
:720)
org.eclipse.jdt.internal.core.JavaModelOperation.runOperatio n(JavaModelOpera
tion.java:779)
org.eclipse.jdt.internal.core.CompilationUnit.becomeWorkingC opy(CompilationU
nit.java:68)
org.eclipse.ajdt.internal.ui.editor.AspectJEditor.doSetInput (AspectJEditor.j
ava:377)
org.eclipse.ui.texteditor.AbstractTextEditor$17.run(Abstract TextEditor.java:
2397)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.jav
a:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:763)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:760)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2262)
org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor
..java:2415)
org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:24
42)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:839)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.jav
a:583)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:372)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReferenc
e.java:557)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:214)
It sounds like the cause of the exception is from the "import figures.*;"
within the following source:
package answers;
import figures.*;
public aspect Answer {
declare error
: get(java.io.PrintStream System.out)
&& within(figures..*)
: "illegal access to System.out";
I am using Eclipse 3.2M5+ajdt_1.4.0(2006-03-30)+WindowsXP
Tong
Re: Exception: Unable to create this part due to an internal error. Reason for t [message #63446 is a reply to message #63398] Sun, 02 April 2006 13:19 Go to previous messageGo to next message
I can't reproduce this. Can you double-check your eclipse + ajdt version
(it might be picking up an old version for example)? Go to Help > About
and note the Eclipse build id, then click on the AJ icon and note the AJDT
build id, and the full AspectJ version.
Matt.
Tong wrote:
> rt(II[CZI)V
> at
> at
> at
> at
> ationUnit.java:231)
> at
> tionUnit.java:179)
> at
> 3)
> at
> at
> :720)
> at
> tion.java:779)
> at
> nit.java:68)
> at
> ava:377)
> at
> 2397)
> at
> a:369)
> at
> at
> at
> ..java:2415)
> at
> 42)
> at
> a:583)
> at
> at
> e.java:557)
> at
> package answers;
> import figures.*;
> declare error
> Tong
Re: Exception: Unable to create this part due to an internal error. Reason for t [message #63490 is a reply to message #63446] Sun, 02 April 2006 13:54 Go to previous messageGo to next message
Here is the info:
Eclipse SDK
Version: 3.2.0
Build id: N20060325-0010
org.aspectj.ajde (1.5.0.20060330094817) "AspectJ"
org.aspectj.runtime (1.5.0.20060330094817) "AspectJ Runtime"
org.aspectj.tutorial.exercises (1.0.1) "AspectJ Tutorial Exercises"
org.aspectj.weaver (1.5.0.20060330094817) "AspectJ Weaver"
org.eclipse.ajdt.core (1.4.0.20060330094817) "AspectJ Development Tools
Core"
org.eclipse.ajdt.examples (1.4.0.20060330094817) "AspectJ Examples"
org.eclipse.ajdt.source (1.4.0.20060330094817) "AspectJ Development Tools
SDK"
org.eclipse.ajdt.ui (1.4.0.20060330094817) "AspectJ Development Tools UI"
org.eclipse.ant.core (3.1.100.N20060325-0010) "Ant Build Tool Core"
[Resolved]
org.eclipse.ant.ui (3.2.0.N20060325-0010) "Ant UI" [Resolved]
org.eclipse.aspectj (1.4.0.20060330094817) "AspectJ Development Tools"
[Resolved]
The steps that I got exception:
1. Create a package called "answers" and a class "Answer" as described in
hand-on.
2. Type in the code as described in hand-on:
package answers;
import figures.*;
declare error
3. Save & Close the file
4. Re-open the file "Answer.aj" from "answers" package
==> Got Exception
Tong
"Matt Chapman" <mpchapman@gmail.com> wrote in message
news:c85fe5dba7db7d09c8625d5fad551b29$1@www.eclipse.org...
> Matt.
> Tong wrote:
> > Hi,
exception
> > rt(II[CZI)V
> > at
> > at
> > at
> > at
> > ationUnit.java:231)
> > at
> > at
> > tionUnit.java:179)
> > at
> > 3)
> > at
> > at
> > :720)
> > at
> > tion.java:779)
> > at
> > nit.java:68)
> > at
> > ava:377)
> > at
> > 2397)
> > at
> > a:369)
> > at
> > at
> > at
> > at
> > at
> > ..java:2415)
> > at
> > 42)
> > at
> > at
> > a:583)
> > at
> > at
> > e.java:557)
> > at
figures.*;"
> > package answers;
> > import figures.*;
> > declare error
> > Regards,
> > Tong
Re: Exception: Unable to create this part due to an internal error. Reason for t [message #63536 is a reply to message #63490] Sun, 02 April 2006 15:09 Go to previous message
Tong wrote:
> Eclipse SDK
> Version: 3.2.0
Aha, that's the problem. That's a recent nightly build, not 3.2M5a. AJDT
is sensitive to eclipse versions - we always try to support the latest
milestone build. So you can either get 3.2M5a, or alternatively get
yesterday's 3.2M6 and then wait for an AJDT for it - should only be a day
or two.
Matt.
Re: Exception: Unable to create this part due to an internal error. Reason for t [message #592869 is a reply to message #63398] Sun, 02 April 2006 13:19 Go to previous message
Matt.
Tong wrote:
> rt(II[CZI)V
> at
> at
> at
> at
> ationUnit.java:231)
> at
> tionUnit.java:179)
> at
> 3)
> at
> at
> :720)
> at
> tion.java:779)
> at
> nit.java:68)
> at
> ava:377)
> at
> 2397)
> at
> a:369)
> at
> at
> at
> ..java:2415)
> at
> 42)
> at
> a:583)
> at
> at
> e.java:557)
> at
> package answers;
> import figures.*;
> declare error
> Tong
Re: Exception: Unable to create this part due to an internal error. Reason for t [message #592896 is a reply to message #63446] Sun, 02 April 2006 13:54 Go to previous message
Here is the info:
Eclipse SDK
Version: 3.2.0
Core"
SDK"
[Resolved]
[Resolved]
hand-on.
package answers;
import figures.*;
declare error
==> Got Exception
Tong
> Matt.
> Tong wrote:
> > Hi,
exception
> > rt(II[CZI)V
> > at
> > at
> > at
> > at
> > ationUnit.java:231)
> > at
> > at
> > tionUnit.java:179)
> > at
> > 3)
> > at
> > at
> > :720)
> > at
> > tion.java:779)
> > at
> > nit.java:68)
> > at
> > ava:377)
> > at
> > 2397)
> > at
> > a:369)
> > at
> > at
> > at
> > at
> > at
> > ..java:2415)
> > at
> > 42)
> > at
> > at
> > a:583)
> > at
> > at
> > e.java:557)
> > at
figures.*;"
> > package answers;
> > import figures.*;
> > declare error
> > Regards,
> > Tong
Re: Exception: Unable to create this part due to an internal error. Reason for t [message #592919 is a reply to message #63490] Sun, 02 April 2006 15:09 Go to previous message
Tong wrote:
> Eclipse SDK
> Version: 3.2.0
or two.
Matt.
Previous Topic:Status and future plans for AspectJ/AJDT? (mustang support in particular)
Next Topic:Eclipse 3.2M6
Current Time: Thu Jul 31 00:40:15 EDT 2025
Powered by FUDForum. Page generated in 0.04159 seconds
