Parameterized product builds [message #63390] |
Wed, 27 May 2009 05:49  |
I'm trying to understand how we can move some strings out of the product
definition file (*.product). The primary things are the product name and
product versions:
<product name="Fantastic Product" version="42.4711.0">
</product>
When building this either headlessly using the PDE build scripts, or
from inside Eclipse, I would like to be able to maintain a separate
file containing the product names and versions. I tried doing
<product name="%productName" ... >
</product>
But that just made the product be called "%productName".
Is there a way to do this without resorting to automatically patching
the product definition file before building?
/Jesper
Re: Parameterized product builds [message #63459 is a reply to message #63437] |
Wed, 27 May 2009 07:34  |
Originally posted by: mickael.istria.openwide.fr
Jesper Eskilson a écrit :
> Mickael Istria wrote:
>> Hello,
>> You can externalize most of your string into the plugin.properties
>> file, that must be in the same folder as the .product file.
> I did do that. The plugin.properties file contained
> productName=Fantastic Product
> But when launching the product, I still got "%productName" as the name.
Ok,
Also ensure that
* You have a "Bundle-Localization: plugin" entry in your MANIFEST.MF
* plugin.properties is included in your build (build.properties must
contain plugin.properties in the bin.includes field)
Mickael
Re: Parameterized product builds [message #597900 is a reply to message #63390] |
Wed, 27 May 2009 06:16  |
You can externalize most of your string into the plugin.properties file,
HTH
Mickael
> product versions:
> </product>
> </product>
> /Jesper
Re: Parameterized product builds [message #597907 is a reply to message #63415] |
Wed, 27 May 2009 06:33  |
> Hello,
Is there any documentation anywhere on this?
/Jesper
Re: Parameterized product builds [message #597915 is a reply to message #63437] |
>> Hello,
Ok,
Also ensure that
Mickael
FUDForum. Page generated in 0.03138 seconds
