Query Bundles.info for installed plugin and version [message #629564] |
Tue, 28 September 2010 17:07 |
Originally posted by: MrBob.bob.bob
I'm looking for a simple way using P2 to query whether or not a plugin
is installed, AND if so, what its version is.
The code, will start with only a path to the bundles.info (this is the
one piece of information I have).
Is there a P2 util class to do this? Or can someone point me to some
starter code, or a class to use that will lead me to the right solution.
I suppose, the other option, is to write a little bit of custom java
code to open the file, and directly inspect for the information.
However.. I'd like to use existing API if possible.
Re: Query Bundles.info for installed plugin and version [message #629579 is a reply to message #629577] |
Tue, 28 September 2010 18:11 |
Thanks for reply.
Any java package I should specifically start my look at? Is there a wiki
that maybe shows an example of how I might do a query?
Henrik Lindberg wrote:
> There are predefined queries as well as a comprehensive query API
> available in p2.
> - henrik
>> solution.
Re: Query Bundles.info for installed plugin and version [message #629613 is a reply to message #629577] |
Tue, 28 September 2010 22:29 |
Thanks for reply.
> available in p2.
> - henrik
>> solution.
FUDForum. Page generated in 0.03586 seconds
