Home » Archived » BIRT » Creating a chart using the design engine
Creating a chart using the design engine [message #63349] |
Mon, 01 August 2005 09:39  |
Has anyone created a chart programmatically using the design engine API's?
If so, please could you give me an example of how to go about doing so.
Thanks and Regards,
Nathan
Re: Creating a chart using the design engine [message #63642 is a reply to message #63574] |
Tue, 02 August 2005 11:48   |
Hi Nina,
Thanks for the help, it allowed me to create a basic line chart without
too much fuss, however I am still having some trouble trying to add a
series grouping key to my chart. Is there a simple way to do this?
Nathan
Nina Li wrote:
> Hi Nathan,
> Attached is a chart example created by using DE API and chart engine API.
> I'm sorry that it looks a little bit ugly. However, it is able to make the
> chart nicer by setting the relevant properties.
> The examples of setting chart properties could be checked out from
> org.eclipse.birt.chart.examples plugin.
> Cheers.
> Nina
> "Nathan McKeown" <nathan.mckeown@scapatech.com> wrote in message
> news:dcl8as$f3s$2@news.eclipse.org...
>>Hi,
>>Thanks and Regards,
>>Nathan
Re: Creating a chart using the design engine [message #63803 is a reply to message #63642] |
Tue, 02 August 2005 23:32   |
Hi Nathan,
The series grouping key could be set as follows:
SeriesDefinition seGroup = SeriesDefinitionImpl.create();
Query query = QueryImpl.create("row[\"Month\"]");
seGroup.setQuery(query);
yAxisPrimary.getSeriesDefinitions().add(seGroup);
seGroup.getSeries().add(bs);
------and please delete the following code in the original class------------
SeriesDefinition sdY = SeriesDefinitionImpl.create();
sdY.getSeries().add(bs);
yAxisPrimary.getSeriesDefinitions().add(sdY);
Cheers. ^-^
Nina
news:dco473$kum$1@news.eclipse.org...
> Hi Nina,
> Nathan
> Nina Li wrote:
>> Hi Nathan,
>> the chart nicer by setting the relevant properties.
>> Cheers.
>> Regards,
>> Nina
>>>Hi,
>>>API's?
>>>Thanks and Regards,
>>>Nathan
Re: Creating a chart using the design engine [message #64013 is a reply to message #63803] |
Wed, 03 August 2005 09:04  |
Hi Nina,
That works a treat!
Nathan
Nina Li wrote:
> Hi Nathan,
> Cheers. ^-^
> Nina
>>Hi Nina,
>>Nathan
>>Nina Li wrote:
>>>Hi Nathan,
>>>Cheers.
>>>Regards,
>>>Nina
>>>>Hi,
>>>>API's?
>>>>Thanks and Regards,
>>>>Nathan
Current Time: Sat Jul 26 09:16:24 EDT 2025
Powered by FUDForum. Page generated in 0.04715 seconds
