How to install xText 1.0.1 on WTP IDE [message #629173] |
Mon, 27 September 2010 12:20 |
I am trying to install xText in a latest WTP IDE. But has been unsuccessful till now.
While installing tmf-xtext-Update-1.0.1, i get following error:
Software being installed: Xtext UI 1.0.1.v201008251220 (org.eclipse.xtext.ui.feature.group 1.0.1.v201008251220)
Missing requirement: Xtext UI 1.0.1.v201008251220 (org.eclipse.xtext.ui.feature.group 1.0.1.v201008251220) requires 'org.eclipse.emf.mwe.ui.feature.group [1.0.0,1.1.0)' but it could not be found
Than i installed, emft-mwe-2-Update-1.0.1. It got successful.
Now while updating for xText 1.0.1 i get following error:
Cannot satisfy dependency:
From: Xtext Runtime 1.0.1.v201008251220 (org.eclipse.xtext.runtime.feature.group 1.0.1.v201008251220)
To: org.eclipse.xtext.generator [1.0.1.v201008251220]
I got some hint from following link: http://www.eclipse.org/forums/index.php?t=msg&goto=51458 3&
So i tried installing from: http://download.eclipse.org/modeling/emft/mwe/updates/milest ones/ . Selected all the features. But now i am getting following errors:
From: com.sap.ide.p2.shipment.eclipse 1.0.0.100911151544
To: org.eclipse.emf.mwe.core.feature.group [0.7.2.v200908120417]
From: SAP NetWeaver Developer Studio Product Internal 8.30.0.100925042502 (com.sap.netweaver.developerstudio.product.complete.extsoa.i nternal 8.30.0.100925042502)
To: com.sap.ide.p2.shipment.eclipse 0.0.0
From: MWE Core (Incubation) 0.7.2.v200908120417 (org.eclipse.emf.mwe.core.feature.group 0.7.2.v200908120417)
To: org.eclipse.emf.mwe.core [0.7.2.v200908120417]
From: MWE Core 1.0.0.v201008100513 (org.eclipse.emf.mwe.core.feature.group 1.0.0.v201008100513)
To: org.eclipse.emf.mwe.core [1.0.0.v201008100513]
How can i get rid of these errors. Somehow updating xText 1.0.1 on WTP has been impossible for me.
I can take latest IDE for xText1.0.1 from http://xtext.itemis.com/xtext-language-development-framework /language=en/23947/downloads . But installing WTP over it becomes a challenge than.
Ashwani Kr Sharma
Re: How to install xText 1.0.1 on WTP IDE [message #629428 is a reply to message #629173] |
Tue, 28 September 2010 09:15 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Ashwani,
please try to use the following update site which is a composite to
simplify the installation process: http://download.itemis.com/updates
If you select MWE2 1.0.1, Xpand 1.0.1 and Xtext 1.0.1 it should work
like a charm. Please let me know if the problem persists.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 27.09.10 14:20, schrieb Ashwani Kr Sharma:
> found
> 8.30.0.100925042502
> Ashwani Kr Sharma
Re: How to install xText 1.0.1 on WTP IDE [message #629472 is a reply to message #629428] |
Tue, 28 September 2010 12:29 |
I selected following:
emft-mwe2 1.0.1 , M2T XPand 1.0.1 , tmf-xtext 1.0.1. But when i proceed, still i get following errors:
Quote: |
Cannot complete the install because one or more required items could not be found.
Software being installed: Xpand Incremental Generation 1.0.1.v201008251147 (org.eclipse.xpand.incremental.feature.group 1.0.1.v201008251147)
Missing requirement: Incremental Generation Extensions for Xpand 1.0.1.v201008251147 (org.eclipse.xpand.incremental 1.0.1.v201008251147) requires 'bundle org.eclipse.emf.compare [1.0.0,2.0.0)' but it could not be found
From: Xpand Incremental Generation 1.0.1.v201008251147 (org.eclipse.xpand.incremental.feature.group 1.0.1.v201008251147)
To: org.eclipse.xpand.incremental [1.0.1.v201008251147]
Meanwhile i was able to update WTP over xtext 1.0.1 distribution. Hence, i am able to work.
But solution to above will be necessary as well.
Ashwani Kr Sharma
[Updated on: Tue, 28 September 2010 12:30] Report message to a moderator
Re: How to install xText 1.0.1 on WTP IDE [message #629521 is a reply to message #629472] |
Tue, 28 September 2010 14:48 |
Hi Ashwani,
did you enable the "Contact all update sites" checkbox in the update dialog?
Sebastian
Am 28.09.10 14:29, schrieb Ashwani Kr Sharma:
> Quote:
>> not be found.
> Ashwani Kr Sharma
FUDForum. Page generated in 0.03109 seconds
