Debug Menu Was Disabled - Now It's Not! [message #63294] |
Fri, 20 June 2003 13:10 |
Originally posted by: bangham.neocera.com
This is a follow up to a few recent posts regarding a problem where the
debug menu items aren't enabled when a breakpoint hits (Windows 2000). I
had this problem, as did a few others. Here's what I did, which apparently
caused the problem to go away:
1) uninstalled the UML plug in (unrelated, but I was getting ready to try to
reinstall Eclipse).
2) created a directory called C:\myworkspace (was going to move my projects,
which were in C:\eclipse\workspace)
3) restarted eclipse, but now using the -data C:\myworkspace option
4) import a project from C:\eclipse\workspace
5) run the debugger
Now everything works great. So, I'm happy, but clearly there is some sort
of problem with Eclipse in this regard.
Best, Mike
FUDForum. Page generated in 0.02554 seconds
