List Databinding [message #63261] |
Mon, 26 November 2007 18:11  |
i've linked a List Object to an Arraylist contained in the model in this
way:
bindingContext.bindList(SWTObservables.observeItems(_listGen re),
BeansObservable.observeList(Realm.getDefault(), model,
"listGenre"), null, null);
_listGenre is the List object
in the model i have put
public ArrayList<String> getListGenre() {
return listGenre;
public void setListGenre(ArrayList<String> listGenre) {
ArrayList<String> old = listGenre;
this.listGenre = listGenre;
changeSupport.firePropertyChange("listGenre", old, listGenre);
In this way no items are added to the arrayList when the _listGenre is
filled with elements. What's wrong?
thanks
Christian
Re: List Databinding [message #63766 is a reply to message #63718] |
Fri, 30 November 2007 11:52  |
Thanks a lot Rudiger,
i've understood where I failed....i'll test your snippet asap.
Bye
Christian
Rüdiger Herrmann ha scritto:
> I would guess that you need to provide an UpdateListStrategy
> BeansObserable#observeList() call.
> Attached is a snippet that shows a List widget that is bound to a model
> that provides the available Locales. UpdateListStrategy, including
> converters, are used there as well.
> However I would rathe recommend to use a ListViewer along with an
> ObservableListContentProvider.
> Cheers,
> Rüdiger
> christian wrote:
>> way:
>> return listGenre;
>> thanks
>> Christian
FUDForum. Page generated in 0.09548 seconds
