Home » Modeling » TMF (Xtext) » [XText] Edit model fragment
[XText] Edit model fragment [message #63258] Mon, 27 July 2009 13:54 Go to next message
I'm using a GMF Editor to display a part of my model, but when the user
clicks a particular node, I'd like more complexity to be revealed in an
XTextEditor type view, allowing the user fine-grained control. My question
is:
How do I go from the selected node in GMF, to loading it in the XText
view? I gather there is some addressing mechanism I should look at for
this? Any help would be appreciated.
Thanks!
Maurice
Re: [XText] Edit model fragment [message #99724 is a reply to message #63258] Mon, 27 July 2009 14:44 Go to previous messageGo to next message
Hi Maurice,
actually Jan is going to publish the code for the example that he
developed in his blog.
I currently do not have access to the source but you may try to reuse
the
org.eclipse.xtext.ui.common.editor.hyperlinking.OpenDeclarat ionAction.
It takes the uri of the EObject and a LocationInFileProvider as
argument. The latter can be retrieved via google guice.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 27.07.2009 19:54 Uhr, schrieb Maurice:
> question is:
> Thanks!
> Maurice
Re: [XText] Edit model fragment [message #145372 is a reply to message #99724] Mon, 27 July 2009 15:31 Go to previous messageGo to next message
Originally posted by: ogucuk.gmail.com
Hi Sebastian,
sorry to popup in every discussion but what Maurice describes is very
similar to what I am trying to do.
I have been waiting for Jan publishing his code for a long time now and
I am running of time for my project.
Is there somewhere more documentation to this issue?
Currently I have a grammar, and an Xtext parser, generated from it. I
have written a tiny class which
takes the Xtext parser(via an injector),
my model file as an InputStream,
and parses the input stream.
I have difficulties with understanding the archictecture behind the
Xtext parser (the structure of the AST) and I am failing to see the
bridge to the GMF editor.
More documentation on this would be a great help. I would be happy to
provide you with my information, also.
myName
Sebastian Zarnekow schrieb:
> Hi Maurice,
> the
> Sebastian
Re: [XText] Edit model fragment [message #146906 is a reply to message #145372] Mon, 27 July 2009 15:33 Go to previous messageGo to next message
I mean "with _more_ information", of course.
Re: [XText] Edit model fragment [message #277008 is a reply to message #145372] Mon, 27 July 2009 18:20 Go to previous messageGo to next message
Hi myName,
please find my comments below.
Am 27.07.2009 21:31 Uhr, schrieb myName:
> Hi Sebastian,
I think Jan will publish the example as soon as he finds the time.
It is a very specific problem. I'm afraid there is not much
documentation available for navigating to an EObject that has been
instantiated by an Xtext parser.
Sounds reasonable.
The GMF editor simply visualizes the contents of the resource which has
been created by an xtext parser. This objects are refered to as semantic
objects. They are linked to the AST via an EAdapter. That's basically
the structure that the parser produces.
Hope that helps,
Sebastian
> Thanks
> myName
>> Hi Maurice,
>> the
>> Regards,
>> Sebastian
Re: [XText] Edit model fragment [message #362115 is a reply to message #277008] Tue, 28 July 2009 09:56 Go to previous message
Hi myName,
have a look at Jan's blog to find the sources:
http://koehnlein.blogspot.com/2009/07/source-code-for-screen cast-of-xtext-and.html
Sebastian
Am 28.07.2009 0:20 Uhr, schrieb Sebastian Zarnekow:
> Hi myName,
>> Hi Sebastian,
> Sounds reasonable.
> Hope that helps,
> Sebastian
Previous Topic:Xtext replace internal model instance
Next Topic:Hidden Terminals
Current Time: Fri Nov 14 15:14:01 EST 2025
Powered by FUDForum. Page generated in 0.04828 seconds
