[XText] Edit model fragment [message #63258] |
Mon, 27 July 2009 13:54  |
I'm using a GMF Editor to display a part of my model, but when the user
clicks a particular node, I'd like more complexity to be revealed in an
XTextEditor type view, allowing the user fine-grained control. My question
is:
How do I go from the selected node in GMF, to loading it in the XText
view? I gather there is some addressing mechanism I should look at for
this? Any help would be appreciated.
Thanks!
Maurice
Re: [XText] Edit model fragment [message #277008 is a reply to message #145372] |
Mon, 27 July 2009 18:20   |
Hi myName,
please find my comments below.
Am 27.07.2009 21:31 Uhr, schrieb myName:
> Hi Sebastian,
> sorry to popup in every discussion but what Maurice describes is very
> similar to what I am trying to do.
> I have been waiting for Jan publishing his code for a long time now and
> I am running of time for my project.
I think Jan will publish the example as soon as he finds the time.
> Is there somewhere more documentation to this issue?
It is a very specific problem. I'm afraid there is not much
documentation available for navigating to an EObject that has been
instantiated by an Xtext parser.
> Currently I have a grammar, and an Xtext parser, generated from it. I
> have written a tiny class which
> takes the Xtext parser(via an injector),
> my model file as an InputStream,
> and parses the input stream.
Sounds reasonable.
> I have difficulties with understanding the archictecture behind the
> Xtext parser (the structure of the AST) and I am failing to see the
> bridge to the GMF editor.
The GMF editor simply visualizes the contents of the resource which has
been created by an xtext parser. This objects are refered to as semantic
objects. They are linked to the AST via an EAdapter. That's basically
the structure that the parser produces.
> More documentation on this would be a great help. I would be happy to
> provide you with my information, also.
Hope that helps,
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
> Thanks
> myName
> Sebastian Zarnekow schrieb:
>> Hi Maurice,
>> actually Jan is going to publish the code for the example that he
>> developed in his blog.
>> I currently do not have access to the source but you may try to reuse
>> the
>> org.eclipse.xtext.ui.common.editor.hyperlinking.OpenDeclarat ionAction.
>> It takes the uri of the EObject and a LocationInFileProvider as
>> argument. The latter can be retrieved via google guice.
>> Regards,
>> Sebastian
Re: [XText] Edit model fragment [message #362115 is a reply to message #277008] |
Tue, 28 July 2009 09:56  |
Hi myName,
have a look at Jan's blog to find the sources:
http://koehnlein.blogspot.com/2009/07/source-code-for-screen cast-of-xtext-and.html
Sebastian
Am 28.07.2009 0:20 Uhr, schrieb Sebastian Zarnekow:
> Hi myName,
>> Hi Sebastian,
> Sounds reasonable.
> Hope that helps,
> Sebastian
FUDForum. Page generated in 0.07804 seconds
