Home » Eclipse Projects » GEF » Logic Editor Example 0206
Logic Editor Example 0206 [message #63233] Fri, 07 February 2003 17:47 Go to next message
I try build and run the logic Editor example 0206 with eclipse 2.1 M5. But
I got this
java.lang.AbstractMethodError:
org.eclipse.gef.ui.actions.ActionBarContributor.buildActions ()V
Could some one please tell me how to resolve this?
Thank you.
Command-line arguments: -dev bin -feature org.eclipse.platform -data
C:\eclipse0207\eclipse\runtime-workspace -os win32 -ws win32 -arch x86 -nl
en_US -configuration
file:C:/eclipseWorkSpace2/workspace/.metadata/.plugins/org.e clipse.pde.core/
C__eclipse0207_eclipse_runtime-workspace/platform.cfg -install
file:C:/eclipse0207/eclipse/
!ENTRY org.eclipse.ui 4 4 Feb 07, 2003 16:37:06.909
!MESSAGE Unhandled exception caught in event loop.
!ENTRY org.eclipse.ui 4 0 Feb 07, 2003 16:37:06.919
!MESSAGE org.eclipse.gef.ui.actions.ActionBarContributor.buildActions ()V
!STACK 0
org.eclipse.gef.ui.actions.ActionBarContributor.init(ActionB arContributor.ja
va:86)
org.eclipse.ui.part.EditorActionBarContributor.init(EditorAc tionBarContribut
or.java:113)
org.eclipse.ui.internal.EditorManager.createEditorActionBars (EditorManager.j
ava:167)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:585)
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:
637)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager
..java:430)
org.eclipse.ui.internal.EditorManager.openEditorFromInput(Ed itorManager.java
:304)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:395)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:1990)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:1828)
org.eclipse.gef.examples.logicdesigner.LogicWizardPage1.fini sh(LogicWizardPa
ge1.java:111)
org.eclipse.gef.examples.logicdesigner.LogicCreationWizard.p erformFinish(Log
icCreationWizard.java:30)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:570)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:308)
at org.eclipse.jface.dialogs.Dialog$1.widgetSelected(Dialog.jav a:417)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:87)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :77)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:836)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1692)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1410)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:561 )
at org.eclipse.jface.window.Window.open(Window.java:541)
at org.eclipse.ui.actions.NewExampleAction.run(NewExampleAction .java:119)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:804 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:450)
org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionCont
ributionItem.java:398)
org.eclipse.jface.action.ActionContributionItem.access$0(Act ionContributionI
tem.java:392)
org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(A
ctionContributionItem.java:72)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1289)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1272)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:247)
at org.eclipse.core.launcher.Main.run(Main.java:703)
at org.eclipse.core.launcher.Main.main(Main.java:539)
Re: Logic Editor Example 0206 [message #63257 is a reply to message #63233] Fri, 07 February 2003 17:48 Go to previous messageGo to next message
What I don't understand is I compile it with no error in my Eclipse
environment.
But when I run it, I got a "java.lang.AbstractMethodError".
"yinglcs" <yinglcs@netscape.com> wrote in message
news:b21bkb$cfl$1@rogue.oti.com...
But
> I got this
> Thank you.
> !STACK 0
> at
> va:86)
> at
> or.java:113)
> at
> ava:167)
> at
> at
> 637)
> at
> .java:430)
> at
> :304)
> at
> at
> at
> at
> ge1.java:111)
> at
> at
> at
> at
> at
> at
> at
> tem.java:392)
> at
> at
> a:845)
> at
> at
> .java:25)
Re: Logic Editor Example 0206 [message #63306 is a reply to message #63257] Fri, 07 February 2003 18:13 Go to previous messageGo to next message
I figure out what is the problem. Sorry for the previous positing.
news:b21bns$chn$1@rogue.oti.com...
> environment.
> But
> > I got this
> > Thank you.
x86 -nl
> > !STACK 0
> > at
> > va:86)
> > at
> > or.java:113)
> > at
> > ava:167)
> > at
> > at
> > 637)
> > at
> > .java:430)
> > at
> > :304)
> > at
> > at
> > at
> > at
> > ge1.java:111)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > tem.java:392)
> > at
> > at
> > a:845)
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at
> > at
> > .java:25)
Re: Logic Editor Example 0206 [message #63374 is a reply to message #63306] Fri, 07 February 2003 19:18 Go to previous messageGo to next message
Originally posted by: jim.azeltine.indus.com
You should post what the solution was...
> \"yinglcs\" <yinglcs@netscape.com> wrote in message
> > What I don\'t understand is I compile it with no error in my Eclipse
> > environment.
> > But when I run it, I got a \"java.lang.AbstractMethodError\".
> > But
> > > I got this
> > > Thank you.
> > > C:\\eclipse0207\\eclipse\\runtime-workspace -os win32 -ws win32 -arch
> x86 -nl
> > > !STACK 0
> > > at
> > > va:86)
> > > at
> > > or.java:113)
> > > at
> > > ava:167)
> > > at
> > > at
> > > 637)
> > > at
> > > .java:430)
> > > at
> > > :304)
> > > at
> > > at
> > > at
> > > at
> > > ge1.java:111)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > tem.java:392)
> > > at
> > > at
> > > a:845)
> > > at
> > > at
> > > .java:25)
Re: Logic Editor Example 0206 [message #63506 is a reply to message #63233] Sat, 08 February 2003 08:41 Go to previous messageGo to next message
It sounds like M5 has some problems. You should always do a manual rebuild
all when upgrading.
But
> I got this
> Thank you.
> !STACK 0
> at
> va:86)
> at
> or.java:113)
> at
> ava:167)
> at
> at
> 637)
> at
> .java:430)
> at
> :304)
> at
> at
> at
> at
> ge1.java:111)
> at
> at
> at
> at
> at
> at
> at
> tem.java:392)
> at
> at
> a:845)
> at
> at
> .java:25)
Re: Logic Editor Example 0206 [message #63553 is a reply to message #63374] Sat, 08 February 2003 12:16 Go to previous message
I remove all the .class file and do a clean build.
"jim azeltine" <jim.azeltine@indus.com> wrote in message
news:b21icr$g2t$1@rogue.oti.com...
> > > environment.
M5.
> > > But
> > > > I got this
> > > > Thank you.
win32 -arch
> > x86 -nl
> > > > !MESSAGE
> > > > !STACK 0
> > > > at
> > > > va:86)
> > > > at
> > > > or.java:113)
> > > > at
> > > > ava:167)
> > > > at
> > > > at
> > > > 637)
> > > > at
> > > > .java:430)
> > > > at
> > > > :304)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > ge1.java:111)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > tem.java:392)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > a:845)
> > > > at
> > > > at
> > > > .java:25)
Previous Topic:ActionBarContributor help (eclipse 2.1 M5 & GEF 2/4/2003)
Next Topic:Place a SWT figure inside Draw2D figure
Current Time: Tue Jul 15 23:28:50 EDT 2025
Powered by FUDForum. Page generated in 0.12307 seconds
