Home » Archived » XML Schema Definition (XSD) » Redefine with extension does not pick up the
Redefine with extension does not pick up the [message #63231] Wed, 14 September 2005 19:08 Go to next message
Originally posted by: abanerjee.vitria.com
The main schema attached below points to the 2nd schema which redefines
the 3rd schema. The XSDComplexTypeDefintion corresponding to “ClaimType”
points to the 2rd schema. The content of the CompleType is instanceof
XSDRedefine and I can call redefine.getResolvedSchema() or
redefine.getIncorporatedSchema() to get the 3rd schema. How can I resolve
the ComplexType so that it includes the elements from schema 2 and schema
3.
-Anindita.
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:include schemaLocation="ClaimType.xsd"/>
<xsd:element name="Claim" type="ClaimType"/>
</xsd:schema>
<xsd:redefine schemaLocation="../../../bom/Claim/ClaimType.xsd">
<xsd:complexType name="ClaimType">
<xsd:complexContent>
<xsd:extension base="ClaimType">
<xsd:sequence>
<xsd:element name="EncounterFlag" type="xsd:boolean" minOccurs="0"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
</xsd:redefine>
</xsd:schema>
<xsd:sequence>
<xsd:element name="AccidentCountryCode" type="xsd:string"
minOccurs="0"/>
<xsd:element name="AccidentDateTime" type="xsd:dateTime" minOccurs="0"/>
<xsd:element name="AccidentStateCode" type="xsd:string" minOccurs="0"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
Re: Redefine with extension does not pick up the [message #63308 is a reply to message #63231] Thu, 15 September 2005 06:07 Go to previous message
--------------080109090309070800050807
Anindita,
When I renamed these files to a.xsd, b.xsd, and c.xsd and load them it
seems to be working nicely:
I.e., the complex type does include elements from both schemas.
What are you trying?
> redefines the 3rd schema. The XSDComplexTypeDefintion corresponding to
> ?ClaimType? points to the 2rd schema. The content of the CompleType is
> instanceof XSDRedefine and I can call redefine.getResolvedSchema() or
> resolve the ComplexType so that it includes the elements from schema 2
> and schema 3.
> -Anindita.
> </xsd:schema>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> </xsd:redefine>
> </xsd:schema>
> <xsd:sequence>
> minOccurs="0"/>
> minOccurs="0"/>
> minOccurs="0"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
Content-Type: multipart/related;
boundary="------------090806080005020705070400"
--------------090806080005020705070400
<html>
<head>
http-equiv="Content-Type">
</head>
Anindita,<br>
<br>
seems to be working nicely:<br>
<blockquote><img src="cid:part1.04010206.05050606@ca.ibm.com" alt=""><br>
</blockquote>
I.e., the complex type does include elements from both schemas. <br>
<br>
What are you trying?<br>
<br>
<br>
<blockquote cite="mid6da0fa1aa487f7d16fecdf9ffb5d13b0$1@www.eclipse.org"
type="cite">The main schema attached below points to the 2nd schema
which redefines the 3rd schema. The XSDComplexTypeDefintion
corresponding to &#65533;ClaimType&#65533; points to the 2rd schema. The content of
the CompleType is instanceof XSDRedefine and I can call
redefine.getResolvedSchema() or redefine.getIncorporatedSchema() to get
the 3rd schema. How can I resolve the ComplexType so that it includes
the elements from schema 2 and schema 3.
<br>
<br>
<br>
-Anindita.
<br>
<br>
&lt;xsd:schema xmlns:xsd=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema">"http://www.w3.org/2001/XMLSchema"</a>&gt;
<br>
Re: Redefine with extension does not pick up the [message #596388 is a reply to message #63231] Thu, 15 September 2005 06:07 Go to previous message
Anindita,
> and schema 3.
> -Anindita.
> </xsd:schema>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> </xsd:redefine>
> </xsd:schema>
> <xsd:sequence>
> minOccurs="0"/>
> minOccurs="0"/>
> minOccurs="0"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
<html>
<head>
</head>
Anindita,<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
-Anindita.
<br>
<br>
<br>
Previous Topic:xs:redefine
Next Topic:Redefine does give the resolved schema
Current Time: Wed Jul 16 04:04:27 EDT 2025
Powered by FUDForum. Page generated in 0.08136 seconds
