Home » Archived » BIRT » Problems creating a basic pie chart
Problems creating a basic pie chart [message #63206] Mon, 01 August 2005 05:44 Go to next message
Originally posted by: mugunthal.hexaware.com
I've flat file like
Metal Percentage
iron 33
copper 52
gold 15
I tried creating a pie chart. Th flat file is read thru the output columns
tab of Edit data set dialog box. Then I gave the following values for the
fields :
Base series
Data Definitions : row["Percentage"]
Orthogonal series
Data Definitions : row["Metal"]
Am i correct with the procedure of creating a pie chart. If not pls
correct me
Thanks in advance
Refards
Mugunth
Re: Problems creating a basic pie chart [message #63256 is a reply to message #63206] Mon, 01 August 2005 08:24 Go to previous message
Hi Mugunth,
You have interverted the two series. The base series should be the metal,
and the orthogonal series the percentage. Orthogonal series must be
numerical. Note that since you are using a flat file datasource you need to
specify the column type in the second row, and set "Use second line as data
type indicator" in the datasource.
Metal Percentage
STRING INT
iron 33
copper 52
gold 15
David
"Mugunth" <mugunthal@hexaware.com> wrote in message
news:b76efa6650f687027ec3c48645db46b9$1@www.eclipse.org...
> I've flat file like
> Metal Percentage
> iron 33
> copper 52
> gold 15
> fields :
> Base series
> Orthogonal series Data Definitions : row["Metal"]
> correct me
> Thanks in advance
> Refards
> Mugunth
Previous Topic:Problems with PDF
Next Topic:Cross-platform charting using SWT
Current Time: Tue Jul 15 06:31:24 EDT 2025
Powered by FUDForum. Page generated in 0.04510 seconds
