Default location of the runtime configuration [message #63204] |
Mon, 25 May 2009 20:44  |
If you run a new RCP application or if you create a new runtime
configuration for a plug-in the runtime configuration is populated with
some values.
I would like to change the default value for the location of the runtime
configuration.
Currently the location in which the Eclipse application is started
defaults to:
${workspace_loc}/../runtime-NAMEOFPROJECT.application
I would like to change the default ${workspace_loc}/.. to another place,
e.g. c:\temp\
Is this possible?
Best regards, Lars
Re: Default location of the runtime configuration [message #63367 is a reply to message #63344] |
Wed, 27 May 2009 01:19  |
Hi Ankur,
thanks you, works perfectly. Best regards, Lars
Ankur Sharma wrote:
> Lars Vogel wrote:
>> with some values.
>> runtime configuration.
>> defaults to:
>> place, e.g. c:\temp\
>> Is this possible?
>> Best regards, Lars
> There is a trick.
> Go to Window -> Preferences -> Run/Debug -> String Substitution
> Add a new variable by the name workspace_loc and give a value
> C:\temp\dummy (this way ${workspace_loc}/.. will resolve to c:\temp)
> However, in case you have used this variable in launch arguments, that
> will be impacted too. So be careful.
Re: Default location of the runtime configuration [message #597865 is a reply to message #63227] |
Tue, 26 May 2009 11:23  |
thanks for the reply, but unfortunately this was not my question.
I would like to know if the default workspace location in a new runtime
configuration can be changed.
Of course I can change the default workspace location every time manually
but it would like to change it once for all future runtime configurations.
Best regards, Lars
Re: Default location of the runtime configuration [message #597881 is a reply to message #63204] |
Tue, 26 May 2009 15:15  |
Lars Vogel wrote:
> some values.
> configuration.
> defaults to:
> e.g. c:\temp\
> Is this possible?
> Best regards, Lars
There is a trick.
Add a new variable by the name workspace_loc and give a value C:\temp\dummy (this way
However, in case you have used this variable in launch arguments, that will be impacted too. So be
careful.
hth,
Ankur..
Re: Default location of the runtime configuration [message #597885 is a reply to message #63344] |
Hi Ankur,
Ankur Sharma wrote:
> Lars Vogel wrote:
>> with some values.
>> defaults to:
>> Is this possible?
>> Best regards, Lars
> There is a trick.
FUDForum. Page generated in 0.45719 seconds
