Home » Eclipse Projects » GEF » Change the Select Behaviour in GEF
Change the Select Behaviour in GEF [message #63185] Fri, 07 February 2003 15:40 Go to next message
How can I control the select behaviour in GEF?
For example, when I click on a label, the label is selected and
high-lighted. How can I change that so that it selectes the container of the
label instead?
Re: Change the Select Behaviour in GEF [message #63212 is a reply to message #63185] Fri, 07 February 2003 16:33 Go to previous messageGo to next message
Please give more context to your questions. I'm going to guess that you
have a label as a child of a connection editpart.
There is new API to make an EditPart not selectable. Override
isSelectable(), but you'll have to wait until the next build to be able to
do this.
"yinglcs" <yinglcs@netscape.com> wrote in message
news:b2146q$7sr$1@rogue.oti.com...
the
> label instead?
> Thanks
Re: Change the Select Behaviour in GEF [message #63645 is a reply to message #63212] Sat, 08 February 2003 16:20 Go to previous messageGo to next message
Thanks for your help.
Take Logic Editor as an example.
I put an And Gate inside a Circuit.
I would like to change the select behaviour of And Gate so that whenever
users select that And Gate, the Parent Container (in this case the Circuit)
is selected instead.
thank you.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b217b8$a34$1@rogue.oti.com...
> do this.
> the
> > label instead?
> > Thanks
Re: Change the Select Behaviour in GEF [message #63666 is a reply to message #63645] Sat, 08 February 2003 17:02 Go to previous message
If the User cannot interact with the label, I'm confused about why there is
an EditPart associated with the label. Why doesn't the Circuit just create a
Label figure and add it to its figure.
Anyway, the answer is still override isSelectable() to return false.
news:b23qui$gh2$1@rogue.oti.com...
Circuit)
> thank you.
to
> > do this.
of
> > the
> > > label instead?
> > > Thanks
Previous Topic:Place a SWT figure inside Draw2D figure
Next Topic:How to draw Transparent Figure has a shadow?
Current Time: Tue Jul 15 06:52:45 EDT 2025
Powered by FUDForum. Page generated in 0.03709 seconds
