Home » Modeling » TMF (Xtext) » Getting started: predefined set of simple types
Getting started: predefined set of simple types [message #63184] Mon, 27 July 2009 11:59 Go to next message
Originally posted by: panajotes.gmx.de
To become more familiar with the Xtext grammar syntax I started to play
around with your "getting started" example of Entities and their Properties.
There is only one small thing I want to change but horribly fail in doing
so. Instead of letting the user define SimpleTypes in the model with the
keyword "type", I want to predefine the set of simple types in my grammar.
So if the user wants to create a new property the code-assistance feature of
the generated editor should not only provide the names of already created
entities but also the predefined types like e.g. String, Integer...
All approaches of using enums or predefing the name attribute, like below,
failed.
Property:
name=ID ":" type=[Type]";";
Type:
SimpleType | Entity;
SimpleType:
name=("String" | "Int" | "Boolean");
Do you have a hint for me?
Thanks and Regards,
Thomas.
Re: Getting started: predefined set of simple types [message #63210 is a reply to message #63184] Mon, 27 July 2009 12:12 Go to previous messageGo to next message
Hi Thomas,
to provide some default values for simple types you can either try to
implement a scope provider that provides access to your built in types
or your can try to use an alternative for the type assignment in your
property.
Property:
name=ID ":" (type=[Type] | simpleType=("String"|"Int"));
Please not that it not considered best practice to hard code the data
types in your language.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 27.07.2009 17:59 Uhr, schrieb Thomas:
> Properties. There is only one small thing I want to change but horribly
> fail in doing so. Instead of letting the user define SimpleTypes in the
> model with the keyword "type", I want to predefine the set of simple
> types in my grammar. So if the user wants to create a new property the
> code-assistance feature of the generated editor should not only provide
> the names of already created entities but also the predefined types like
> below, failed.
> Property:
> Type:
> SimpleType:
> Thanks and Regards,
> Thomas.
Re: Getting started: predefined set of simple types [message #345339 is a reply to message #63210] Tue, 28 July 2009 03:05 Go to previous messageGo to next message
Hi Sebastian,
thanks again for your help.
I tried the alternative type assignment too but what I really want would be
something like this:
Property:
name=ID ":" type=([Type] | "String" | "Int");
The problem with that seems to be, that no type can be infered which matches
all three alternatives, right? This it at least what I understand from the
error message. But actually this is not clear for me, because the value of
the cross-reference as well as "String" and "Int" should be of type STRING.
Concerning the best practices thing. So what would you suggest if I want to
model a language like Java for example? There you have a list of predefined
simple types, too. Isn't modeling them in the grammar instead of code, like
you would have to when using the scope provider approach, the more
convenient way?
Thomas.
"Sebastian Zarnekow" <Sebastian.Zarnekow@itemis.de> wrote in message
news:h4kjlb$bpj$1@build.eclipse.org...
> Hi Thomas,
> implement a scope provider that provides access to your built in types or
> property.
> Property:
> Regards
> Sebastian
>> below, failed.
>> Property:
>> Type:
>> SimpleType:
>> Thanks and Regards,
>> Thomas.
Re: Getting started: predefined set of simple types [message #347895 is a reply to message #345339] Tue, 28 July 2009 04:12 Go to previous messageGo to next message
Hi Thomas,
please see below.
Am 28.07.2009 9:05 Uhr, schrieb Thomas:
> Hi Sebastian,
> be something like this:
> Property:
> matches all three alternatives, right? This it at least what I
> understand from the error message. But actually this is not clear for
> me, because the value of the cross-reference as well as "String" and
The error message is right. While "String" and "Int" are keywords (from
a grammar's perspective) they will be assigned as ecore::EString to the
attribute type of the eClass Property. The cross reference [Type] on the
other hand is a yourmetamodel::Type and not an EString. Type and EString
are not compatible because the first is an EClass while the latter is an
EDataType which leads to the fact, that Property.type must be both an
EReference and an EAttribute.
> to model a language like Java for example? There you have a list of
> predefined simple types, too. Isn't modeling them in the grammar instead
> of code, like you would have to when using the scope provider approach,
> the more convenient way?
Well Java is not designed in a best practice way in each and every
corner case. Have a look at Smalltalk for a better example :-)
A custom implementation of the scope provider may introduce an implicit
import of a resource called AllDatatypes.dsl which contains the simple
types as String, Int etc. This would model them in the DSL and neither
in the grammar directly nor in code.
Hope that helps,
Sebastian
> Thomas.
>> Hi Thomas,
>> property.
>> Property:
>> Regards
>> Sebastian
>>> Hi,
>>> below, failed.
>>> Property:
>>> Type:
>>> SimpleType:
>>> Thanks and Regards,
>>> Thomas.
Re: Getting started: predefined set of simple types [message #348950 is a reply to message #347895] Tue, 28 July 2009 04:41 Go to previous messageGo to next message
Hi Sebastian,
see comments below.
news:h4mbt7$se0$1@build.eclipse.org...
> Hi Thomas,
> please see below.
>> Hi Sebastian,
>> Property:
> The error message is right. While "String" and "Int" are keywords (from a
Thanks for the detailed description. This is clear now :-)
> Well Java is not designed in a best practice way in each and every corner
> types as String, Int etc. This would model them in the DSL and neither in
Sounds like a good compromise. I will try this.
Thanks again and regards,
Thomas.
> Hope that helps,
> Sebastian
>> Regards,
>> Thomas.
>>> Hi Thomas,
>>> property.
>>> Property:
>>> Regards
>>> Sebastian
>>>> Hi,
>>>> like
>>>> below, failed.
>>>> Property:
>>>> Type:
>>>> SimpleType:
>>>> Thanks and Regards,
>>>> Thomas.
Re: Getting started: predefined set of simple types [message #369110 is a reply to message #348950] Tue, 28 July 2009 12:36 Go to previous messageGo to next message
Sorry to get into your thread, but the subject is of great interest to me
too.
When facing the same problem, I chose the following approach :
Property :
name = ID ":" type=Typer;
Typer :
PrimitiveTyper | TypeReference
enum PrimitiveTypeKind :
'String' | 'Int'
PrimitiveTyper :
kind = PrimitiveTypeKind
TypeReference :
referenced = [Type]
While this solution works rather well it introduces an additional
indirection, does it seem acceptable to you or do you have any
recommendation against it ?
Thomas wrote:
> Hi Sebastian,
>>> Property:
Re: Getting started: predefined set of simple types [message #372090 is a reply to message #63210] Wed, 29 July 2009 04:34 Go to previous messageGo to next message
Hi Sebastian and Thomas,
Sorry Thomas for hijacking your thread, but I face similar problems as
yours.
Sebastian Zarnekow wrote:
> Hi Thomas,
I tried to take this approach for one of my example but faced two problems
1) As I didn't want to parse a file providing primitive types (int &
string in this example) again & again, I chose to create these instances
as static members of a dedicated java class and to extend the
ScopeProvider to always return those.
It turns out that works fine when I statically parse my files & use the
resulting (meta)model instance. On the other hand, it generates errors
when I use this in the dynamic xtext based editor. As a matter of fact, at
validation, the Validator checks that all referenced EObject instances are
contained in a resource, which is not the case for those instances I
created.
2) Some of my types are created only when an instance using them is
encountered. For example, the array types, that references another type
(what's contained in the array).
With my previous approach that introduced an additional indirection (as
explained in my other message on this thread), that was not a problem.
There were two kind of indirection, either
Variable=>PrimitiveDatatyper=>PrimitiveDatatypeKind in the case of
primitive types, Variable=>DatatypeReference->Type in the case of user
defined types and
Variable=>ArrayDatatyper=>[PrimitiveDatatyper|DatatypeReference|ArrayDatatyper]
in the case of an array (=> are containment, -> are not).
An approach would be to lazily create array types when required, make them
contained by my root element and reference them from variable using them.
However, taking that approach in xtext will likely make me face the same
kind of problems as described in the "Processing ecore with
non-containment references" thread.
> Regards
> Sebastian
Julien
Re: Getting started: predefined set of simple types [message #372478 is a reply to message #372090] Wed, 29 July 2009 05:22 Go to previous messageGo to next message
Hi Julien
please see below.
Am 29.07.2009 10:34 Uhr, schrieb Julien Bigot:
> yours.
>> Hi Thomas,
> problems :
> at validation, the Validator checks that all referenced EObject
> instances are contained in a resource, which is not the case for those
> instances I created.
It is not a good idea to create eobjects that are not contained in any
resource. It is a better idea to add them to a resource and keep that
one in memory.
> defined types and
> them contained by my root element and reference them from variable using
> them. However, taking that approach in xtext will likely make me face
> the same kind of problems as described in the "Processing ecore with
I do not understand why PrimitiveDatatypeKind should be contained in the
PrimitiveDatatyper. I guess this one should be a cross ref, shouldn't it?
Regarding your Array problem. I don't think that this is the same
problem as in the mentioned thread. How do nested array types look like
in your concrete syntax? Maybe we can come up with a grammar that will
parse this one gracefully without any reference/containment problem. I
guess the Variable=>ArrayDatatyper .. notation visualizes the (frozen)
structure of your metamodel?
>> Regards
>> Sebastian
> Julien
Sebastian
Re: Getting started: predefined set of simple types [message #372886 is a reply to message #372478] Wed, 29 July 2009 07:52 Go to previous messageGo to next message
Hi Sebastian,
Thank you for your answers, additional comments and question are below.
> Hi Julien
> please see below.
>> yours.
>>> Hi Thomas,
>> problems :
> one in memory.
Ok, then I guess I should create a Resource that is not an XtextResource
since it hasn't been parsed by xtext. But should I add it to the
ResourceSet or should I keep it out of it ? I'm quite new to EMF and thus
I don't fully get what concepts Resource's and ResouceSet's capture.
Another question is what URI I should set for this in-memory Resource.
>> defined types and
This is not a containing reference but an attribute, since
PrimitiveDatatypeKind is an enumeration. Anyway, that shouldn't make any
difference.
To summarize, my actual ecore metamodel looks like that (is there an
official DSL for ecore models ?):
eclass Datatyper (interface) {} // basically a reference to a type
enum PrimitiveDatatypeKind { INT, STRING }
eclass PrimitiveDatatyer extends Datatyper {
attr kind: PrimitiveDatatypeKind ([1..1]);
eclass Type { // user defined types
attr name: EString([1..1]);
eclass DatatypeReference extends Datatyper {
ref referenced: Type ([1..1] non-containing);
eclass ArrayDatatyper extends Datatyper {
ref subType: Datatyper ([1..1] containing);
eclass Variable {
attr name: EString ([1..1]);
ref type: Datatyper ([1..1] containing);
as I said, the Datatyper acts as a reference to a type, handling the cases
where the type is described by an enumeration and thus referenced by an
attribute (primitive types) and the case where the type is created on the
fly and thus not referenced without containment (array)
An exemple of Array variable in the DSL could be:
int[] myVar;
and the associated xtext grammar:
Variable:
type=Datatyper name=ID ';'
Datatyper:
(PrimitiveDatatyper|DatatypeReference) ({ArrayDatatyper.subType=current}
enum PrimitiveDatakind :
INT='int'|STRING='string'
PrimitiveDatatyper:
kind=PrimitiveDatakind
DatatypeReference:
referenced=[Type]
My current grammar works rather well, except it introduces this additional
indirection when referring to types : Variable=>TypeReference->Type
instead of Variable->Type as one would expect.
You gave me the first half of the solution by solving the problem with
primitive types (create a fixed number of instances of Type statically).
This means that now, for a user defined type, I have
Variable->UserDefinedType and for a primitive type,
Variable->PrimitiveType where both UserDefinedType and PrimitiveType
extend Type.
The only problem remaining is the case of arrays.
One approach would be to modify the metamodel to put the fact that the
variable stands for an array in the Variable meta-class. Something like
Variable[array=true]->Type.
That doesn't seem any cleaner than my current solution however. I don't
model array variables of a given type, but variables whose type is array
of something.
>>> Regards
>>> Sebastian
>> Regards,
>> Julien
> Sebastian
Julien
Re: Getting started: predefined set of simple types [message #373291 is a reply to message #372886] Wed, 29 July 2009 09:38 Go to previous messageGo to next message
Hi Julien,
please see below.
Am 29.07.2009 13:52 Uhr, schrieb Julien Bigot:
> Hi Sebastian,
>> Hi Julien
>> please see below.
>>> yours.
>>>> Hi Thomas,
>>> problems :
>> one in memory.
> thus I don't fully get what concepts Resource's and ResouceSet's
> capture. Another question is what URI I should set for this in-memory
> Resource.
You can use an XtextResource as well. The fact that it uses a parser to
load a file and a serializer to save it back to the file system does not
matter. Actually XMLResources tend to use a parser as well :-)
The EMF book is a quite good starter to get used to the concepts of the
framework.
Personally I'ld prefer to add the resouce to the resource set. This way
you built in types may be collected by the garbage collector and
resources in the same resource set will help the framework to find
existing instances.
>>> defined types and
>> the PrimitiveDatatyper. I guess this one should be a cross ref,
>> shouldn't it?
> difference.
Try to google for emfatic. But it has a rather noisy syntax. Java-like
pseudocode is fine for me.
> eclass Variable {
> cases where the type is described by an enumeration and thus referenced
> by an attribute (primitive types) and the case where the type is created
> on the fly and thus not referenced without containment (array)
>> like in your concrete syntax?
> int[] myVar;
> Variable:
> Datatyper:
> PrimitiveDatatyper:
> DatatypeReference:
> referenced=[Type]
>> Maybe we can come up with a grammar that will parse this one
>> gracefully without any reference/containment problem. I guess the
>> Variable=>ArrayDatatyper .. notation visualizes the (frozen) structure
>> of your metamodel?
> additional indirection when referring to types :
> Variable=>TypeReference->Type instead of Variable->Type as one would
> expect.
This indirection is a common approach. You'll end up with
SomethingDeclaration and SomethingReference in many languages.
> extend Type.
> of something.
You are right, the fact "Variable's type is an array" does not belong to
the variable directly, but to its type. ArrayType should be a sibling of
UserDefinedType and PrimitiveType and refer to its component type as a
Type. That's actually the way you modeled it in your grammar.
>>>> Regards
>>>> Sebastian
>>> Regards,
>>> Julien
>> Regards,
>> Sebastian
> Julien
Hope that helps,
Sebastian
Re: Getting started: predefined set of simple types [message #374560 is a reply to message #373291] Wed, 29 July 2009 12:49 Go to previous messageGo to next message
Hi Sebastian,
First, thanks for all the clarifications.
There are still a few things not completely clear to me as you'll find
below.
Fell free to tell me to just check the EMF Book however. I guess I'm
focusing on tiny details now that don't have much importance.
> Hi Julien,
> please see below.
I was rather thinking about a simple ResourceImpl that doesn't support any
kind of serialization.
> framework.
Thank you for the advice, I will consider buying it.
> existing instances.
I'll go that way until I better understand Resources and ResourceSets then
>> expect.
>> extend Type.
>> of something.
Not exactly, in my grammar ArrayType is a sibling of TypeReference, not of
UserDefinedType and PrimitiveType.
This is due to the fact that I need ArrayTypes to be contained by Variable
instances.
I cannot create all the ArrayTypes instances somewhere and only reference
them without containment from Variables. There is a possibly infinite
number of ArrayTypes.
In order to break that lack of symmetry between ArrayTypes and other
Types, I thought about lazily instantiating ArrayTypes when they are used
by Variables, but make them contained by the root element or something
like that.
That would be very complicated for only little benefits however.
As I don't think I am the first one to encounter that problem I just
wanted to know if there is a best practice in that case ?
> Hope that helps,
> Sebastian
Re: Getting started: predefined set of simple types [message #375457 is a reply to message #374560] Wed, 29 July 2009 15:37 Go to previous messageGo to next message
Hi Julien,
please see below.
Am 29.07.2009 18:49 Uhr, schrieb Julien Bigot:
> Hi Sebastian,
> below.
>> Hi Julien,
>> please see below.
>> to load a file and a serializer to save it back to the file system
>> does not matter. Actually XMLResources tend to use a parser as well :-)
> any kind of serialization.
Ok, that should work :-)
>> the framework.
It's definitly worth it as it gives a very good introduction in the EMF
concepts and is a quite good reference.
>> way you built in types may be collected by the garbage collector and
>> existing instances.
> then !
>>> expect.
>>> extend Type.
>>> of something.
>> to the variable directly, but to its type. ArrayType should be a
>> sibling of UserDefinedType and PrimitiveType and refer to its
>> component type as a Type. That's actually the way you modeled it in
>> your grammar.
> of UserDefinedType and PrimitiveType.
> Variable instances.
> reference them without containment from Variables. There is a possibly
> infinite number of ArrayTypes.
> used by Variables, but make them contained by the root element or
> something like that.
Usually one would override ILinkingService#getLinkedObjects to
instantiate objects lazily - if it's definitly necessary. In your case a
combination of
ArrayTypeReference extends DatatypeReference {
arrayType: ArrayType
and
ArrayType extends Type {
componentType: Type;
should work out very well.
>> Hope that helps,
>> Sebastian
Sebastian
Re: Getting started: predefined set of simple types [message #425986 is a reply to message #375457] Thu, 30 July 2009 09:45 Go to previous message
Hi Sebastian,
Thank you for all you your very insightful answers.
I'll give a try to the approach you proposed.
I think I get a better understanding of some concepts in EMF now, but that
should get even better after reading the EMF Book.
Thank you again,
Julien
Previous Topic:Xtext import hassle
Next Topic:Change LazyLinking to EagerLinking
Current Time: Sat Jul 26 09:19:31 EDT 2025
Powered by FUDForum. Page generated in 0.08294 seconds
