Home » Archived » BIRT » Hiding duplicate records in detail row
Hiding duplicate records in detail row [message #63151] Mon, 01 August 2005 03:41 Go to next message
I have one column that displays duplicate records and I just want to
display it again only if the value is different with the previous one..how
can i possibly do it...
Wins
Re: Hiding duplicate records in detail row [message #63327 is a reply to message #63151] Mon, 01 August 2005 08:47 Go to previous messageGo to next message
Try typing in an expression like this for the duplicate column Y (assuming
that you want to display its value only if it's different from another
column X):
row["Y"] == row["X"] ? "" : row["Y"]
Does this give what you wanted?
Gary
"wins" <winstonguadiz@yahoo.com> wrote in message
news:6058a245704472d39cd5123db4aa5245$1@www.eclipse.org...
> Wins
Re: Hiding duplicate records in detail row [message #63551 is a reply to message #63327] Mon, 01 August 2005 22:46 Go to previous messageGo to next message
Hi Gary,
Thank a lot for your support..duplicate records can now be hidden...btw,
the ROM Scrpting specs did not mention anything on how to hide duplicate
records..how did you come up on that expression..i mean where can i find
help topics like that?..and find out how does it work?..
Thanks again
Wins
> column X):
> Gary
Re: Hiding duplicate records in detail row [message #63596 is a reply to message #63551] Tue, 02 August 2005 02:29 Go to previous messageGo to next message
Hi Gary,
I thought I have already resolved my problem in hiding the duplicate
records with the script expression you've given me but it didn't solve my
problem yet. What happened is that i typed some scripts in visibility hide
element check box earlier to hide it and forgot to remove it and thought
it's your script that hid it....but my script is not good enough to solve
my problem...
Here is the expression that I typed in hide element check box that made me
think your script works.
false;
if (row[0] > 0) {
true;
I apologized for this..still waiting for your help....
Here is an example of what I want to accomplish...
Region Country
Asia<display Malaysia
Asia<-hide Japan
Asia<-hide Philippines
Asia <-hide Singapore
Europe<-display Italy
Europe<-hide France
Europe<-hide Germany
Wins
Re: Hiding duplicate records in detail row [message #63667 is a reply to message #63596] Tue, 02 August 2005 12:22 Go to previous messageGo to next message
--------------090807030306080201020501
It looks like adding a group and using the "drop" property on your
Region column would accomplish this. See the attached example, notice
the cell for the "Territory" row has the "Drop" property set to "Detail".
Michael
> Region Country
> Asia<-hide Japan
> Europe<-hide France Europe<-hide Germany
> Wins
Content-Type: text/xml;
name="group_wins.rptdesign"
Content-Disposition: inline;
filename="group_wins.rptdesign"
<!-- Written by Eclipse BIRT 1.0 -->
<report xmlns=" http://www.eclipse.org/birt/2005/design" version="1">
<property name="createdBy">Eclipse BIRT Designer Version 1.0.0 Build &lt;20050601-0809></property>
<property name="units">in</property>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.sampledb" name="Data Source"/>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="Data Set">
<property name="dataSource">Data Source</property>
<property name="queryText">select *
from CLASSICMODELS.OFFICES</property>
</oda-data-set>
</data-sets>
<page-setup>
<simple-master-page name="Simple MasterPage">
<page-footer>
<text>
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table name="table1">
<property name="width">100%</property>
<property name="dataSet">Data Set</property>
<column>
<property name="width">33.3%</property>
</column>
<column>
</column>
<column>
<property name="width">33.4%</property>
</column>
<header>
<row>
<cell>
<label>
<text-property name="text">TERRITORY</text-property>
</label>
</cell>
<cell>
<label>
<text-property name="text">COUNTRY</text-property>
</label>
</cell>
<cell>
<label>
<text-property name="text">CITY</text-property>
</label>
</cell>
</row>
</header>
<group>
<property name="groupName">Territory</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression name="keyExpr">row["TERRITORY"]</expression>
<header>
<row>
<cell>
<property name="drop">detail</property>
<data>
<expression name="valueExpr">row["TERRITORY"]</expression>
</data>
</cell>
<cell/>
<cell/>
</row>
</header>
<footer>
<row>
<cell/>
<cell/>
<cell/>
</row>
</footer>
</group>
<detail>
<row>
<cell>
<property name="drop">none</property>
</cell>
<cell>
<data>
<expression name="valueExpr">row["COUNTRY"]</expression>
</data>
</cell>
<cell>
<data>
<expression name="valueExpr">row["CITY"]</expression>
</data>
</cell>
</row>
</detail>
<footer>
<row>
<cell/>
<cell/>
<cell/>
</row>
</footer>
</table>
</body>
</report>
--------------090807030306080201020501--
Re: Hiding duplicate records in detail row [message #63825 is a reply to message #63667] Tue, 02 August 2005 23:35 Go to previous messageGo to next message
Michael,
Thanks a lot! I finally resolved it with your help...I'm not really aware
that this DROP property can use to hide duplicate records..I suggest BIRT
to provide examples on their documentation for the sake of the report
writers specially for a beginner like me..
Thanks again..
Wins
Re: Hiding duplicate records in detail row [message #63870 is a reply to message #63825] Wed, 03 August 2005 02:19 Go to previous message
When setting the DROP property = "detail" of group header I found out that
when choosing PDF format my report will print a blank page first before it
prints the report content.....any solution for this?
thanks,
wins
wins wrote:
> Michael,
> Thanks again..
> Wins
When choosing PDF format
Previous Topic:Re: How do I manipulate two metrics from two data sources in a report ?
Next Topic:How to create a report programmatically
Current Time: Sat Jul 26 18:43:00 EDT 2025
Powered by FUDForum. Page generated in 0.21732 seconds
