Home » Language IDEs » Java Development Tools (JDT) » Performance problems
Performance problems [message #63149] Fri, 20 June 2003 11:31 Go to next message
Originally posted by: jlavoie.electrad.ca
Hi there,
Is anybody experiencing performance problems with Eclipse? By performance
problems I mean Eclipse hangs for several seconds and even minutes for no
apparent reason (e.g. in the middle of typing some code or even
comments...). I noticed that the hard drive is working like crazy when it
happens. The longer my Eclipse session has been on, the worse it gets (more
frequent, longer hangs). I suspect that the Java garbage collector is
working during the hangs but if it's the case, I wonder what produces that
much garbage...
Any ideas? It's driving me nuts. I'm even thinking about dropping Eclipse
and go back to emacs and the JDE.
My environment is:
Athlon 1 GHz
256 MRAM
HD 30G, 7200 RPM ATA100
Windows 2000 Pro
Eclipse version: 2.1.0
Build id: 200303272130
java.version=1.4.1_01
Jean
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
Re: Performance problems [message #63200 is a reply to message #63149] Fri, 20 June 2003 11:43 Go to previous messageGo to next message
"Jean Lavoie" <jlavoie@electrad.ca> wrote in message
news:oprq2n2vuaam8xrn@news.eclipse.org...
(more
> frequent, longer hangs).[...]
Yes - same here - except for the hard drive access.
Sometimes it just sits there redrawing the title bar millions of times.
> Any ideas? [...]
IBM bugs, I reckon.
Ironically I'm reading news while Eclipse hangs around.
It's been about five minutes so far.
I usually reboot it around now.
The current M1 seems to be worse than 2.1 was in this respect.
__________
|im |yler http://timtyler.org/ tim@tt1.org
Re: Performance problems [message #63340 is a reply to message #63200] Fri, 20 June 2003 14:28 Go to previous messageGo to next message
Originally posted by: pdrolet.mac.com
On a PowerBook G4, 1GIG, 512 RAM: same pauses. But usually between 2 to
10 seconds. I tends to happen less frequently and for shorter periods
since I increased the JVM memory to 150MEGS min.
Yes, I feel too that M1 is worse than 2.1.1 was.
Patrice Drolet
Re: Performance problems [message #63363 is a reply to message #63149] Fri, 20 June 2003 14:36 Go to previous messageGo to next message
Never had such Problems.
>My environment is:
>Athlon 1 GHz
>256 MRAM
Seems not much.
Just in case, are you running other programms too?
Perhaps win is swapping, would match your hdd access. Check your
memory situation.
I kow from winxp that it swaps memory from minimized apps to hdd.
Perhpas true for win2k.
martin
Re: Performance problems [message #63451 is a reply to message #63149] Fri, 20 June 2003 15:05 Go to previous messageGo to next message
Originally posted by: burner.zclipse.org
On Fri, 20 Jun 2003 11:31:33 -0400, Jean Lavoie wrote:
> 256 MRAM
This is your problem. I could barely fit windows XP in memory, let alone
eclipse. Get another 256M and you'll be much happier (I grabbed a 512
SODIMM for my P42.0Ghz laptop and it made all the difference in both WinXP
and Debian).
> Jean
Re: Performance problems [message #63726 is a reply to message #63451] Fri, 20 June 2003 19:44 Go to previous messageGo to next message
On Fri, 20 Jun 2003 15:05:57 -0400, Michael R Head <burner@zclipse.org>
>> 256 MRAM
> WinXP
> and Debian).
Well, I may be out of phase but IMHO, a single app that requires that much
memory gets 2 strikes against it. I can easily understand that performances
may not be snappy but hanging during one minute because I have "only" 256M
of RAM is ridiculous. I think that Eclipse team should slow down on
features and invest more time in performance tuning.
Anyway, even if I complain 'til tomorrow, Eclipse will remain a memory hog
and I won't have more memory in my machine. I guess I have to make a
decision here.
Thank you very much for your answer,
Jean
Re: Performance problems [message #65253 is a reply to message #63726] Mon, 23 June 2003 13:01 Go to previous messageGo to next message
Originally posted by: dcorbin.imperitek.com
>>> 256 MRAM
>> WinXP
>> and Debian).
> much memory gets 2 strikes against it. I can easily understand that
> performances may not be snappy but hanging during one minute because I
> have "only" 256M of RAM is ridiculous. I think that Eclipse team should
> slow down on features and invest more time in performance tuning.
I disagree entirely. RAM is cheap. As someone who uses Eclipse 8-12
hours a day, I'm not the least bit worried about memory consumption, as
a long as a machine less than 5 years old can hold what's required.
Eclipse does some incredibly slick things, and I sit there and think
about how much RAM had to be used to keep that information "ready in
case", and then I say, "who cares".
David
> hog and I won't have more memory in my machine. I guess I have to make a
> decision here.
> Jean
Re: Performance problems [message #65358 is a reply to message #65253] Mon, 23 June 2003 14:12 Go to previous messageGo to next message
On Mon, 23 Jun 2003 13:01:09 -0400, David Corbin <dcorbin@imperitek.com>
wrote:
>>>> 256 MRAM
>>> alone
>>> WinXP
>>> and Debian).
> hours a day, I'm not the least bit worried about memory consumption, as a
> David
I don't know about you but Eclipse is not the only app I need to run while
developing. I have Opera running, Outlook, emacs, Total Commander, etc. All
these apps have can do very slick things too and, together, they're using
less than half the memory used by Eclipse.
When I was developing in C++, I was using Visual Studio 6 on machines with
only 128M and it was a charm to use, always responsive and as great as
Eclipse in terms of features.
Imagine for a second if all the apps that are doing very slick things were
to consume as much memory as Eclipse does...
Jean
>> decision here.
>> Jean
Re: Performance problems [message #65507 is a reply to message #65358] Mon, 23 June 2003 15:48 Go to previous messageGo to next message
news:oprq8finn1am8xrn@news.eclipse.org...
> wrote:
> >>>> 256 MRAM
> >>> alone
> >>> WinXP
> >>> and Debian).
a
> > David
All
> Jean
Surely Visual studio 6 is nowhere near Eclipse in featureset. When I first
used Visual Studio more than 2 years ago I was impressed by the featureset
but when I recently had a chance to use it again, it seemed positively
primitive in comparison to Eclipse.
Anyway, that's a side observation. I dont know if it's possible to shrink
down Eclipse much without stripping away features or spending a lot of time
writing better code at the expense of incorporating new features.
I find myself having to keep a close watch on memory consumption even with
640MB RAM in my machine. I have to periodically restart some apps to keep
memory usage from ballooning. The culprit is frequently Internet explorer on
my machine not Eclipse though. Eclipse doesnt grow beyond about 200MB. RAM
being as cheap as it is, if I had to choose between features or small memory
footprint, I'd choose features anyday. I think we should be pragmatic about
this and not pursue perfection in one direction (small memory footprint) at
the expense of all others.
Re: Performance problems [message #65658 is a reply to message #63149] Mon, 23 June 2003 23:19 Go to previous messageGo to next message
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
I've experienced (and reported with bugzilla) some pauses like this though
my longest were about 15 seconds. It seems to be related to Windows having
most of the JVM's memory paged out, while the JVM is trying to do garbage
collection. One thing that helped a lot was tweaking the JVM's maximum heap
size parameter. Try running eclipse.exe with the option:
-vmargs -Xmx128m
128m (MB) is just a suggestion. Try a higher or lower number and see what
works best for you. The next biggest help for performance is to keep
projects closed in your workspace that you're not currently using.
With 256MB memory going for as little as $30 at newegg.com (maybe cheaper
elsewhere, try your favorite price search engine), you might want to
consider a small upgrade whether or not you're using Eclipse. XP, Visual
Studio.Net, Outlook, and other newer programs seem to assume more and more
memory with each new release.
Ed Burnette, co-author Eclipse in Action (www.manning.com/gallardo)
(more
> much garbage...
Re: Performance problems [message #66263 is a reply to message #65658] Tue, 24 June 2003 11:22 Go to previous messageGo to next message
Originally posted by: timkuntz.javapriest.com
Thanks Ed. I'm running under Win2K with 512 in memory and have this same
problem and it really does seem to be a paging problem.
Are there any other performance tips you can give? Is there a
recommended JVM or optional shipped plug-ins that can be easily removed?
> -vmargs -Xmx128m
Re: Performance problems [message #67799 is a reply to message #66263] Wed, 25 June 2003 23:17 Go to previous messageGo to next message
If you're really having problems with performance you can turn off
decorators (Preferences > Label Decorations), and turn off automatic
rebuilds (Preferences > Workbench > Perform build automatically). Eclipse
does a lot of disk I/O so put everything on local drives (not on the
network) and keeping them defragged helps a lot (a lot = 10x faster
refactoring in my tests).
Plugins that are not used will not be loaded so don't worry about removing
things. Just use the latest JVM available, generally they get faster with
each release. Developerworks has an article about improved GC in the IBM 1.4
JVM but I haven't tried it (mainly because I haven't found a download
And of course, report performance problems through bugzilla. There's an
ongoing project to monitor and improve Eclipse performance.
Ed
"Tim Kuntz" <timkuntz@javapriest.com> wrote in message
news:bd9qaa$198$1@rogue.oti.com...
Re: Performance problems [message #68323 is a reply to message #67799] Thu, 26 June 2003 14:24 Go to previous messageGo to next message
Thanks. A recent defrag did seem to help. I may try your other suggestions
if I become too frustrated.
> location :).
I think I read the same article but had the impression that 1.4.x was
only available for the "server" OS's, as there current download page
seems to indicate.
http://www-106.ibm.com/developerworks/ibm/library/i-gctroub/
http://www-106.ibm.com/developerworks/java/jdk/index.html
Re: Performance problems [message #68365 is a reply to message #63726] Thu, 26 June 2003 16:40 Go to previous messageGo to next message
Originally posted by: faust.acm.org
$30 for 256Mb of RAM. www.pricewatch.com
Randy
news:oprq3awcs0am8xrn@news.eclipse.org...
> >> 256 MRAM
> > WinXP
> > and Debian).
performances
> decision here.
> Jean
Re: Performance problems [message #71037 is a reply to message #67799] Tue, 01 July 2003 13:38 Go to previous message
Thank you very much Ed! Just the kind of help I was looking for.
I will apply these advices and see if performance improves.
Thanks again,
Jean
On Wed, 25 Jun 2003 23:17:43 -0400, Ed Burnette
> removing
> 1.4
> location :).
> Ed
Previous Topic:Starting ANT with keyboard shortcut
Next Topic:Is it possible to contribute a library classpath entry to a new java project?
Current Time: Sat Jul 26 03:07:15 EDT 2025
Powered by FUDForum. Page generated in 0.07160 seconds
