Problem [message #63110] |
Mon, 26 November 2007 07:16  |
Hi all,
I created a contextmenu for my treeviewer and a submenu depending on a
collection of actions, for the contextmenu.
Everythings works fine, except the presentation of my submenu. It should
display approx. 20-30 elements, but unfortunately the submenu is cut off
at the bottom edge of the browser window.
Has anybody an idea if it is a known bug, or how to fix this problem.
The code looks like this:
private void hookContextMenu() {
menuMgr = new MenuManager("#ContextMenu");
menuMgr.setRemoveAllWhenShown(true);
menuMgr.addMenuListener(new IMenuListener() {
public void menuAboutToShow(IMenuManager manager) {
fillContextMenu(manager);
Menu menu = menuMgr.createContextMenu(viewer.getControl());
viewer.getControl().setMenu(menu);
getSite().registerContextMenu(menuMgr, viewer);
private void fillContextMenu(IMenuManager manager) {
manager.add(createResourceSubMenu());
manager.add(new Separator());
manager.add(new GroupMarker(IWorkbenchActionConstants.MB_ADDITIONS));
manager.add(addAction);
manager.add(removeAction);
manager.add(editAction);
private MenuManager createResourceSubMenu() {
final MenuManager manager = new MenuManager("&Resource",
"Resource hinzufügen");
if (!typeActions.isEmpty()) {
for (IAction actionObject : typeActions) {
if (!actionObject.equals(null))
manager.add(actionObject);
} else {
logger.info("No Type Actions found");
return manager;
Thanks in advance
Cheers
Thomas
Re: Problem [message #63288 is a reply to message #63213] |
Tue, 27 November 2007 05:47  |
Hi Benny,
thanks for your quick answer.
Benjamin Muskalla schrieb:
> Hi Thomas,
> this really looks like a bug. The problem is that the real bug behind
> this does is not RAP-related but based on the underlying javascript
> library (qooxdoo). So you can open a bug at RAP to track the issue when
> this is fixed in qooxdoo itself.
> Greets
> Benny
> Thomas Hartmann wrote:
>> Hi all,
>> should display approx. 20-30 elements, but unfortunately the submenu
>> is cut off at the bottom edge of the browser window.
>> manager.add(new
>> } else {
>> return manager;
>> Thanks in advance
>> Cheers
>> Thomas
FUDForum. Page generated in 0.04884 seconds
