Home » Archived » BIRT » How do I manipulate two metrics from two data sources in a report ?
How do I manipulate two metrics from two data sources in a report ? [message #63104] Sun, 31 July 2005 21:02 Go to next message
I have row["count(*)"] from data source 1 and row["count(*)"] from data
source 2, I want the difference of both, how do I do that in BIRT single
report ?
Thanks for any answer.
Re: How do I manipulate two metrics from two data sources in a report ? [message #64216 is a reply to message #63104] Wed, 03 August 2005 16:46 Go to previous messageGo to next message
Cross-data set scripting support is rather limited in Birt 1.0. However it
might still possible to do what you are asking for. See attached report for
example. In the afterOpen() method of each data set a global Javascript
variable is used to record the value of the count column. The 3rd data cell
then calculates the different betwee tht 2 variables.
There are probably other ways to achieve similar results. Let me know if
this works for you, and if not, how you'd like to see BIRT enhanced for your
usage scenario (filing a Bugzilla enhancement request is the best way to
make sure that such enhancements are tracked).
regards,
Gary
"JTan" <jamestanms@hotmail.com> wrote in message
news:dcjsbk$cev$1@news.eclipse.org...
> report ?
Re: How do I manipulate two metrics from two data sources in a report ? [message #64235 is a reply to message #64216] Wed, 03 August 2005 16:47 Go to previous message
Forgot the attachment
"Gary Xue" <gxue@actuate.com> wrote in message
news:dcradk$hds$1@news.eclipse.org...
> Hello,
for
cell
your
> regards,
> Gary
> > report ?
Previous Topic:Is it possible to set a jdbc driver at runtime?
Next Topic:charting over grouped aggregate functions?
Current Time: Sun Jul 27 08:34:52 EDT 2025
Powered by FUDForum. Page generated in 0.05229 seconds
