Home » Eclipse Projects » Nebula » Synchronise TreeListener-Events between two Grids
Synchronise TreeListener-Events between two Grids [message #63091] Tue, 28 April 2009 07:52 Go to next message
probably you remember. Currently i am using two Grids (side by side) to
accomplish the need of fixed columns. Now i have to synchronise the
MouseClick on the "+".
I saw there is a TreeListener which provides the needed events. The Event
carries a GridItem. But what is the best way forward this event to the
scrollable Grid. The GridItem-Objects aren't the same. Only the fixed Grid
contains a column which is showed as tree (setTree(true)).
Any help/tipps/hints is greatly appreciated,
Thomas E.-E.
Re: Synchronise TreeListener-Events between two Grids [message #63119 is a reply to message #63091] Tue, 28 April 2009 08:13 Go to previous message
asked this question 5 minutes to early ... but hej now you can participate
in the solution ;-)
// synchronise the "+" click
fixedViewer.addTreeListener(new ITreeViewerListener (){
public void treeCollapsed(TreeExpansionEvent event) {
scrollableViewer.collapseToLevel(
event.getElement(), 1 /* open one level */);
public void treeExpanded(TreeExpansionEvent event) {
scrollableViewer.expandToLevel(
event.getElement(), 1 /* close one level */);
Re: Synchronise TreeListener-Events between two Grids [message #594584 is a reply to message #63091] Tue, 28 April 2009 08:13 Go to previous message
in the solution ;-)
Previous Topic:Synchronise TreeListener-Events between two Grids
Next Topic:Textalignment in ColumnGroupHeader
Current Time: Wed Jul 16 23:51:42 EDT 2025
Powered by FUDForum. Page generated in 0.04379 seconds
