Home » Eclipse Projects » Mylyn » Mylyn/Bugzilla Headless Usage
Mylyn/Bugzilla Headless Usage [message #63085] Mon, 08 December 2008 03:20 Go to next message
I'm currently looking at the Bugzilla headless example. I'm interested
in querying a repository in headless mode on a regularly basis, i.e. I'd
like to setup a repository, fetch all issues for a specific project and
then only fetch the modifications (eg. hourly).
I wonder if there is some more API that I can re-use for that. As far as
I understand, Mylyn already does that in the UI. Ideally, I'd like to
reuse at much as possible without inheriting the UI code.
Any ideas/pointers?
-Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: Mylyn/Bugzilla Headless Usage [message #63198 is a reply to message #63085] Mon, 08 December 2008 18:54 Go to previous message
The logic for synchronization is coupled to the task list which is currently
only available through internals. If you create an instance of TaskList and
add the queries that you want to synchronize you should be able to update
tasks periodically through SynchronizeRepositoriesJob.
Steffen
PS: It's best to ask development related questions on the dev or integrators
mailing list: http://www.eclipse.org/mylyn/developers/.
Re: Mylyn/Bugzilla Headless Usage [message #595340 is a reply to message #63085] Mon, 08 December 2008 18:54 Go to previous message
Steffen
Previous Topic:Integrating Jira using mylyn
Next Topic:Could not update Mylyn weekly on Eclipse 3.5 (m3)
Current Time: Fri Jul 18 00:41:58 EDT 2025
Powered by FUDForum. Page generated in 0.28631 seconds
