Home » Language IDEs » C / C++ IDE (CDT) » "helloworld" project from FAQ does not run
"helloworld" project from FAQ does not run [message #63066] Tue, 25 February 2003 09:06 Go to next message
Originally posted by: gthaker.atl.lmco.com
I am on Eclipse 2.0.2 and CDT 1.0.1 on Redhat 8.1beta. I am using latest
Java SDK, 1.4.1_01-b01.
I have been running this eclipse for a few days without problems, but I
can not run the CDT FAQ's Helloworld example.
Since there are no Linux specific instructions I followed the windows
directions which are as follows:
"Creating a simple C++ Project -- "Hello World on a Windows Platform"
This section will use an example to create the familiar "Hello World!" C++
program. First, ensure that you have the CDT installed within Eclipse, as
described above. Open a C/C++ Perspective and complete the following steps:
1. In the C/C++ Projects View right click and select "New Project ..."
2. Select "C++" in the left pane and the select "Standard Make C++
Project"
3. Enter a name for the new project and select Finish. Note: you can
determine the "Build Settings" from this dialog, but we will do so later,
in the build section."
When I hit the "Finish" button here Eclipse hangs. THe processor pegs at
100%. After about 5 minutes I killed Eclipse. I tried to look for log
files but found none.
Should CDT 1.0.1 work on eclipse 2.0.2 on Linux 8.1beta? (Eclipse without
CDT works ok.)
thanks (i am a newbie)
Re: "helloworld" project from FAQ does not run [message #63555 is a reply to message #63066] Mon, 03 March 2003 15:42 Go to previous messageGo to next message
"Gautam Thaker" <gthaker@atl.lmco.com> wrote in message
news:b3ft8e$lg8$1@rogue.oti.com...
| Hi,
steps:
| Project"
| CDT works ok.)
The CDT should work fine.
This is definately not a good thing.
Can you run any C/C++ projects?
How is your environment set up with respect to the gcc and make utilities?
-Judy
Re: "helloworld" project from FAQ does not run [message #64049 is a reply to message #63555] Thu, 06 March 2003 06:01 Go to previous message
Originally posted by: fudge.planetarion.com
"Judy N. Green" <jgreen@qnx.com> writes:
> | CDT works ok.)
I had the same problem when I first tried Eclipse a while ago. The
reason was that I was running a very recent Gtk+, which caused Eclipse
to hang like this every time a progress bar was done.
I changed to Eclipse 2.1rc1, and it worked fine.
Erlend Simonsen - <fudge@planetarion.com>
Previous Topic:Load command progress help req
Next Topic:gdb configuration
Current Time: Fri Jul 18 19:15:18 EDT 2025
Powered by FUDForum. Page generated in 0.05863 seconds
