Home » Language IDEs » PHP Development Tools (PDT) » 'Publish files to Server" checkbox disappeared
'Publish files to Server" checkbox disappeared [message #63048] Wed, 12 December 2007 11:18 Go to next message
Originally posted by: januzz.freestart.hu
It was possible to use a checkbox on the Run Configuration page to
"Publish files to Server" up to version 20071001.
But from newer PDT versions this checkbox is missing.
Can anyone please help how to publish files to (local) server now?
And what is the directory mapping in the server configuration?
Andras
Re: 'Publish files to Server" checkbox disappeared [message #63859 is a reply to message #63048] Tue, 25 December 2007 04:14 Go to previous messageGo to next message
You can try 'FileSync' plugin.
http://andrei.gmxhome.de/filesync/links.html
You can add 'Builder' to your project.
FOR EXAMPLE,
1. Open project properties
2. Select 'Builders' and click New button
3. Set in Main tab
"C:\windows\system32\xcopy.exe" to Location
"${project_loc} c:\yourserver\yourdirectory /s /i /y" to Arguments
4. Do in Build Options tab
uncheck "Allocate console"
check "During auto builds"
You can add Linked Folder in your project.
1. Create local project in the workspace
2. Add(New) Folder > click 'Advanced' > check 'Link to...' > input target
directory under web root
You can add 'Alias' in your httpd.conf.
You can create project in your web directory.
Cheers.
Re: 'Publish files to Server" checkbox disappeared [message #63997 is a reply to message #63859] Mon, 31 December 2007 07:41 Go to previous messageGo to next message
Thanks for the tip, Toshihiro, it sounds good, I might try it.
I still would like to hear from a PDT developer however if publishing
functionality is still supported by PDT.
I would be very surprised if this very useful feature would be removed
from PDT. I hope I just don't know how to configure it in the new releases.
Re: 'Publish files to Server" checkbox disappeared [message #64218 is a reply to message #63997] Mon, 07 January 2008 04:02 Go to previous messageGo to next message
I am looking for this feature too. It is available in PDT 1.0.1v20071001
but missing (maybe intentionally removed?) in the latest PDT 1.0.1 release.
Publishing projects to server is a very useful feature to me, so now I
have to stay in the old version until a solution is found.
Andras: you mentioned a tip from Toshihiro, but I didn't find his post in
this thread. Could you please share it with me? Is it working? Thanks in
advance.
Re: 'Publish files to Server" checkbox disappeared [message #64351 is a reply to message #64218] Wed, 09 January 2008 10:04 Go to previous messageGo to next message
Raymond,
Toshihiro's message was disappeared for a few days but now is visible
again for me.
Can you see it in the thread? If not I can re-post it.
This publishing request was posted several times in this newsgroup (for
example:
http://www.eclipse.org/newsportal/article.php?id=1615&gr oup=eclipse.tools.pdt#1615)
but it was never answered by any PDT support people. I wonder if ever
will be.
It seems like there is no PDT support...
The new server directory mapping feature, which maybe took the place of
publishing, is not documented anywhere, and we cannot get any support
about it here either, so I don't know what to do. We are stuck.
I am not updating PDT since version 20071001 because I need publishing.
Re: 'Publish files to Server" checkbox disappeared [message #66930 is a reply to message #64351] Tue, 04 March 2008 17:19 Go to previous messageGo to next message
Originally posted by: artemis.mendrinos.com
I am also facing the same problem, I really cannot see a way for
publishing files to the docroot with the PDT 1.0.2.
Re: 'Publish files to Server" checkbox disappeared [message #67010 is a reply to message #66930] Sat, 08 March 2008 05:11 Go to previous messageGo to next message
Try http://wiki.eclipse.org/TM_and_RSE_FAQ
Ralph
Re: 'Publish files to Server" checkbox disappeared [message #67350 is a reply to message #67010] Fri, 21 March 2008 12:29 Go to previous messageGo to next message
Thanks for your reply. I will test it.
Do you mean also that Eclipse PDT will permenently remove the the simple
feature of publishing (copying files to the apache docroot) when running?
Re: 'Publish files to Server" checkbox disappeared [message #68703 is a reply to message #67350] Mon, 14 April 2008 19:02 Go to previous messageGo to next message
Have anyone so far found the way to publish files to the server? Caroline
Maynard said in thread "PDT 1.0.2 Milestone 1 is ready!"
Andras Janurik has already pointed out that the "Publish to Server" checkbox
has disappeared, .
I'd appreciate a simple example of how the new relationships are >supposed<
to be used, (which I don't think is yet documented?), quite possibly not the
way I found by experimentation. For example, let's say I have:
- a local project in %MY_WORKSPACE%\ProjectName
- a publish target of %XAMPP_HOME%\htdocs\SomeStuff\ProjectName
- a corresponding URL of http://localhost/SomeStuff/ProjectName
what would be the standard way to configure the PHP Server parameters? Is it
ever right to configure the Server URL ("the URL that points to the document
root of this server") to include "SomeStuff", as some people have suggested,
or must it be set to the server's actual document root? What would be the
right way to configure the Path Mapping, and can I get the project to be
published out to the server like I used to?
I pasted part of her message because I have exactly the same question but I
suppose this is the right thread to ask for it.
"Artemis Mendrinos" <artemis@mendrinos.com> wrote in message
news:dc3aa34398793f40a5f698551b2d3480$1@www.eclipse.org...
Re: 'Publish files to Server" checkbox disappeared [message #69054 is a reply to message #63048] Fri, 18 April 2008 21:29 Go to previous messageGo to next message
Originally posted by: bill.hooperandtoolson.com
Any updates on this awol feature? Since I was relying on being able to
publish locally, I need to go back to the version that supported this
feature. Anyone know where I can find it? Thanks!
Re: 'Publish files to Server" checkbox disappeared [message #69178 is a reply to message #69054] Tue, 22 April 2008 10:56 Go to previous message
Does any one know how to report this in Bugzilla? Maybe no one from the
development team is listening because this list is of lower priority than
actually reporting it as a bug.
"Bill" <bill@hooperandtoolson.com> wrote in message
news:67aec28a9db71baa850e5f824bed01c9$1@www.eclipse.org...
Previous Topic:Code Assist not working for Informix functions
Next Topic:"Creating php model" every time Eclipse opens
Current Time: Sun Jul 13 18:41:06 EDT 2025
Powered by FUDForum. Page generated in 0.05111 seconds
