Home » Eclipse Projects » Remote Application Platform (RAP) » RAP in tomcat
RAP in tomcat [message #5660] Mon, 12 March 2007 14:11 Go to next message
Originally posted by: pedro.s.silva.criticalsoftware.com
If I develop my RAP Application in eclipse how do I then putt it inside
Tomcat?
Maybe it is something simple but I didn't figure it out yet.
Pedro Silva
Re: RAP in tomcat [message #5758 is a reply to message #5660] Mon, 12 March 2007 19:39 Go to previous messageGo to next message
Originally posted by: jkrause.innoopract.com
Hi Pedro,
A general introduction on how to do that can be found here:
http://www.eclipse.org/equinox/server/http_in_container.php
The org.eclipse.equinox.servletbridge project contains an ant script to
create the folder structure. You also need the
org.eclipse.equinox.servletbridge.feature project to reference the
plugins you want to include into the build.
I could create and deploy a demo app, access the osgi console, but had
problems accessing the rap servlet. We will look into this shortly.
Jochen
Pedro Silva wrote:
> Tomcat?
> Pedro Silva
Re: RAP in tomcat [message #5829 is a reply to message #5758] Tue, 13 March 2007 06:16 Go to previous message
Hi Jochen,
Thanks for helpingfull answers :)
I just tried to do the same and I had some problems doing it.
First I exported the helloworld example as a jar to the eclipse
directory in the bridge webapp. Then I did a installed it with install
command and started it with start command. after this I've got a
dependency error:
osgi> start 14
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Require-Bundle: org.eclipse.rap.jface;
bundle-version="0.0.0"
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:294)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
org.eclipse.osgi.framework.internal.core.FrameworkCommandPro vider._start(FrameworkCommandProvider.java:239)
org.eclipse.osgi.framework.internal.core.FrameworkCommandInt erpreter.execute(FrameworkCommandInterpreter.java:145)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.do command(FrameworkConsole.java:293)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.co nsole(FrameworkConsole.java:278)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.ru n(FrameworkConsole.java:213)
at java.lang.Thread.run(Thread.java:619)
If I do:
osgi> diag 14
file:\\\C:\Projectos\Software\apache-tomcat-5.5.20\webapps\b ridge\WEB-INF\eclipse\plugins\org.eclipse.rap.helloworld_1.0 .0.jar
[14]
Missing required bundle org.eclipse.rap.jface_0.0.0.
Missing required bundle org.eclipse.rap.rwt_0.0.0.
Missing required bundle org.eclipse.rap.ui.workbench_0.0.0.
Missing required bundle org.eclipse.rap.w4t_0.0.0.
I get a lot of dependency problems.
Should I install each missing bundle or is there way to automatically
resolve the dependencies?
Pedro Silva
Jochen Krause wrote:
> Hi Pedro,
> Cheers,
> Jochen
> Pedro Silva wrote:
>> inside Tomcat?
>> Thanks,
>> Pedro Silva
Previous Topic:DateChooser
Next Topic:Problem accessing RAP demo
Current Time: Sat May 10 04:33:34 EDT 2025
Powered by FUDForum. Page generated in 0.02575 seconds
