Home » Modeling » TMF (Xtext) » Comment line rule in Xtext
Comment line rule in Xtext [message #63002] Sat, 25 July 2009 02:56 Go to next message
Since Comment lines can appear anywhere, what is an ideal grammer to
include in the Model for accommodating this?
Should all Sections be apppended with a (COMMENT)* option?
Grammer would look too awkward if I do it like that. Any help
regards
Binu K Idicula
Re: Comment line rule in Xtext [message #63004 is a reply to message #63002] Sat, 25 July 2009 12:57 Go to previous messageGo to next message
Xtext includes default terminals for single-line and multi-line comments
that are in the C-style.
http://www.eclipse.org/Xtext/documentation/latest/xtext.html #Defaulttokens
You can override these in your grammar by specifying a terminal rule
with the same name. If you make any terminal 'hidden', it's not
necessary to specify it in grammar rules as its token becomes hidden
from the parser.
> regards
> Binu K Idicula
Re: Comment line rule in Xtext [message #63006 is a reply to message #63002] Sat, 25 July 2009 12:58 Go to previous messageGo to next message
Binu,
Comment lines are handled very nicely by default. See the Hidden
terminal symbols section in the docs and
http://www.eclipse.org/Xtext/documentation/0_7_0/xtext.html# Defaulttokens.
Were
you tying to customize the behavior?
Miles
> regards
> Binu K Idicula
Re: Comment line rule in Xtext [message #63017 is a reply to message #63002] Mon, 27 July 2009 03:13 Go to previous message
Hi Idicula,
the default behaviour of Xtext for comments should work pretty fine
except from the case where you want line comments to be part of your
semantic model. If that is your use case, you should go with the
"awkward" grammar.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 25.07.2009 8:56 Uhr, schrieb Idicula:
> regards
> Binu K Idicula
Previous Topic:Workflow for writing a value converter
Next Topic:Providing hover documentation
Current Time: Mon Jul 21 21:43:30 EDT 2025
Powered by FUDForum. Page generated in 0.05862 seconds
