Home » Archived » BPMN Modeler » Adding and editing annotations dynamically
Adding and editing annotations dynamically [message #5656] Wed, 07 January 2009 10:27 Go to next message
hello,
is there any opportunity of adding several annotations dynamically in run
time,
so that the user is able to add and edit annotations for elements in the
property view (in the property tab "Annotations")?
Many thanks in advance!
Sven
Re: Adding and editing annotations dynamically [message #5700 is a reply to message #5656] Wed, 07 January 2009 19:10 Go to previous messageGo to next message
Hello Sven,
please have a look at EclipseCon2008
http://www.eclipse.org/newsportal/post.php?type=reply&id =81&group=eclipse.bpmn-modeler
Exactly this code may be interessting for you:
BPMNVisual2ProcessGenerator generator = new BPMNVisual2ProcessGenerator();
TextAnnotation textA = generator.addTextAnnotation(null, bug.getSummary());
Map<String, String> details = new HashMap<String, String>();
details.put("state", String.valueOf(bug.getState()));
details.put("number", String.valueOf(bug.getNumber()));
generator.addAnnotation(textA, BUG_ANNOTATION_SOURCE, details);
regards
/Sam
Re: Adding and editing annotations dynamically [message #487845 is a reply to message #5700] Thu, 24 September 2009 10:44 Go to previous messageGo to next message
Hi there,
Sam the link u gave is broken...
I am using the BPMN Modeler in a Eclipse Galileo
where I plugged the BPEL Modeler and the BPMN2BPEL plugin too.
I have a diagram where some elements has the annotations attribute fill with
some commands.
For example the pool element has:
KEY
BPEL: annotation
VALUE
namespace mns="http://www.uatx.mx/lang" @ "lang_defs.wsdl";
process SayHelloLang {client sayhelloPL = mns:SayHelloPT
(mns:SayHelloLang @ SayHelloPort); };
var input |mns:SayHelloRequestMessage|;
var output |mns:SayHelloResponseMessage|;
My question is how to add in annotations attributes? i do not find the way.
thanks in advance
Marcello
[Updated on: Thu, 24 September 2009 10:48] by Moderator
Re: Adding and editing annotations dynamically [message #499296 is a reply to message #487845] Fri, 20 November 2009 11:56 Go to previous message
Originally posted by: atoulme.intalio.com
He meant that link:
http://wiki.eclipse.org/STP/BPMN_Component/EclipseCon2008
Marcello wrote:
> Hi there,
> with some
> commands.
> Key Value
> BPEL: annotation namespace mns="http://www.uatx.mx/lang" @
> "lang_defs.wsdl";
> client sayhelloPL = mns:SayHelloPT (mns:SayHelloLang @ SayHelloPort);
Previous Topic:Problems when connecting two elements
Next Topic:Resizing swim lanes
Current Time: Tue Jul 08 08:14:31 EDT 2025
Powered by FUDForum. Page generated in 0.07553 seconds
