Home » Modeling » TMF (Xtext) » XText Grammer for String assignment
XText Grammer for String assignment [message #62962] Fri, 24 July 2009 05:03 Go to next message
I have a requirement to get the below mentioned assignment operation
pass with xtext grammer
variable1 = This is the variable Value
variable2 = ?
variable3 = 12
I could not figure out a way to get the String assignment as a value. I
used STRING as well as "string" in the type. But none worked as is.
Model :
(variables += Variable)*;
Variable returns as Variable :
name = ID '=' value=(STRING | INT);
This doesnot work. Any help?
Re: XText Grammer for String assignment [message #62966 is a reply to message #62962] Fri, 24 July 2009 05:38 Go to previous messageGo to next message
Hi Idicula,
which version of Xtext do you use? There have been changes from 0.7.0 to
0.7.1 for this usecase. However, since STRING and INT do not have a
common supertype, I do not know what you try to achieve. What's the type
that you expect for the attribtue Variable.value?
If you are on 0.7.0, you may try the following workaround:
Variable:
name=ID '=' (strValue=STRING | intValue=INT);
I would prefer a cleaner solution and use:
Model:
variables += Variable *;
Variable:
StringVariable | IntVariable;
StringVariable:
name=ID '=' strValue=STRING;
IntVariable:
name=ID '=' intValue=INT;
Regars,
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 24.07.2009 11:03 Uhr, schrieb Idicula:
> variable2 = ?
> variable3 = 12
> Model :
Re: XText Grammer for String assignment [message #62968 is a reply to message #62966] Fri, 24 July 2009 05:44 Go to previous messageGo to next message
Hi Sebastian,
Thanks for the quick reply
What I see in Eclipse Plugin directory is
org.eclipse.xtext_0.7.0.v200906161042. So I assume it is 0.7.0.
But when I give strValue=STRING , it doesnot accept the first line
variable1 = This is the value of the variable
Which is what I am stuck at.
Re: XText Grammer for String assignment [message #62972 is a reply to message #62966] Fri, 24 July 2009 06:01 Go to previous messageGo to next message
> Model:
> Variable:
> StringVariable:
> IntVariable:
I think, this is not LL(1).
"Too many cooks spoil the broth." I do prefer something like this:
Model:
assigns += Assign* ;
Variable: name = ID;
Assign:
variable = Variable '=' value = Value ';';
Value: INT | STRING | ... ;
terminal INT returns ecore::EINT : ... ;
terminal STRING : ....;
=== end ___
Ciao, Micha
--- Original-Nachricht ---
Absender: Sebastian Zarnekow
Datum: 24.07.2009 11:38
> Hi Idicula,
> Variable:
> Model:
> Variable:
> StringVariable:
> IntVariable:
> Regars,
> Sebastian
Re: XText Grammer for String assignment [message #62974 is a reply to message #62968] Fri, 24 July 2009 07:34 Go to previous messageGo to next message
Hi Idicula,
STRINGS are expected to look like 'This is the value of the variable'
(including the quotes).
You should try to alter you grammar to match your syntax.
Please have a look at the reference documentation at
http://www.xtext.org for detailled information about the common terminal
rules and about terminal and data type rules in general.
Sebastian
Am 24.07.2009 11:44 Uhr, schrieb Idicula:
> Hi Sebastian,
Re: XText Grammer for String assignment [message #62976 is a reply to message #62972] Fri, 24 July 2009 07:36 Go to previous messageGo to next message
Hi Michael,
you are right, it is not LL(1) but LL(*). This should not expose a
performance problem in this case. However, if you want to stick with
LL(1), I'ld prefer something like:
Value:
IntValue | StringValue;
IntValue:
val=INT;
StringValue:
val=STRING;
Sebastian
Am 24.07.2009 12:01 Uhr, schrieb Michael Burkhardt:
> > Model:
> > Variable:
> > StringVariable:
> > IntVariable:
> Model:
> Assign:
> === end ___
> Ciao, Micha
>> Hi Idicula,
>> to 0.7.1 for this usecase. However, since STRING and INT do not have a
>> type that you expect for the attribtue Variable.value?
>> Variable:
>> Model:
>> Variable:
>> StringVariable:
>> IntVariable:
>> Regars,
>> Sebastian
Re: XText Grammer for String assignment [message #62997 is a reply to message #62974] Fri, 24 July 2009 15:23 Go to previous messageGo to next message
Hi Sebastian,
As you said, I tried with terminal rule
Model :
(variables = Variable)?;
Variable returns Variable:
(decls+=Decl)*;
Decl:
( name=ID '=' (valueInt=INT)|(valueStr=PLAIN_STRING));
terminal PLAIN_STRING :
( '\\' ('b'|'t'|'n'|'f'|'r'|'"'|"'"|'\\') | !('\\'|'"') )* |
( '\\' ('b'|'t'|'n'|'f'|'r'|'"'|"'"|'\\') | !('\\'|"'") )* ;
But the below code cannot validated with the above grammer. Is there
anything wrong in the PLAIN_STRING - which is " and ' removed from the
original value.
test1=This is the value
test2=234
Any suggestions to improve the greedy PLAIN_STRING?
Re: XText Grammer for String assignment [message #62999 is a reply to message #62972] Fri, 24 July 2009 15:39 Go to previous messageGo to next message
I tried the following grammer as well. But no success so far in getting
a plain String as a token
Model :
(decls+=Decl)*;
Decl:
( name=ID '=' value=PLAIN_STRING);
terminal PLAIN_STRING : !('\n'|'\r')* ('\r'? '\n')?;
to parse the below
variable2 = This is another variable value
I was wondering - properties file have similar syntax and there must be
some grammer already written for this style. Can anyone give pointers (
other than reference book - it is not clear) :-)
Re: XText Grammer for String assignment [message #63015 is a reply to message #62997] Mon, 27 July 2009 03:02 Go to previous messageGo to next message
Hi Idicula,
I guess data type rules will be more helpful then terminal rules in your
use case. It is kind of difficult to understand the semantic of your
language from your short examplary snippet. Is the newline at the end of
your "string" mandatory?
Do you want to create a grammar for property files?
A first shot may look like this one:
Variable:
VarDecl '=' Value;
Value:
StringValue returns ecore::EString hidden():
(ID | WS | INT)+ '\n';
Although this would not allow quoted values on the rhs of your assignment.
Hope that helps,
Sebastian
Am 24.07.2009 21:23 Uhr, schrieb Idicula:
> Hi Sebastian, As you said, I tried with terminal rule
> Model :
> (decls+=Decl)*;
> Decl:
> original value.
> test2=234
Re: XText Grammer for String assignment [message #63092 is a reply to message #63015] Mon, 27 July 2009 06:12 Go to previous messageGo to next message
Hi Sebastian,
The value can contain any character ended by a new line. This would
mean all of the below are valid
variable1 = Hello World!
variable2 = hhhjjj + jhjhjsad _ kkh ~@;
stringValue - anything till the end of line after the equals.
regards
Binu K Idicula
Re: XText Grammer for String assignment [message #63105 is a reply to message #63092] Mon, 27 July 2009 06:29 Go to previous message
Hi Idicula,
I don't know your usecase but it seems as if regular expressions may be
a good match. The only way that comes to my mind and will match your rhs
of an assignment without ambiguity is a terminal rule that starts with
an assignment operator '=' and consumes everthing until the end of the line.
Hope that helps,
Sebastian
Am 27.07.2009 12:12 Uhr, schrieb Idicula:
> Hi Sebastian,
> The value can contain any character ended by a new line. This would mean
> regards
> Binu K Idicula
Previous Topic:Providing hover documentation
Next Topic:Ecore meta model to Xtext grammar
Current Time: Tue Jul 22 14:49:00 EDT 2025
Powered by FUDForum. Page generated in 0.03488 seconds
